Question about Frigidaire PLMV169DC Microwave Oven
There are spots in the glass in the door can you take it appart
There are spots that appear to be between the glass in the door how do you get rid of the spots/dirt
  • joekspot_lei Nov 21, 2008
    Thanks, but the spots appear to be inside the glass not just behind the screen.
  • 108 Answers
There is a screen behind the outer glass of the door which protects you from harmful microwave emmisions. Residue will build up here over time. Trying to clean this screen may damage it and subject you to serious problems. I have been using Microwave ovens for 35 years with no problems. I dont worry about this because germs will be eliminated by the emmisions.
Posted on Nov 13, 2008
  • Ray Nov 22, 2008
    If the spots are not accessible from the inside or outside, you will have to live with them Joek. Please don't try to take the door apart.
    Ray
How do I clean inside of glass on door of AMV5164BAQ?
You can use normal glass cleaner or bleach with anything but metal abrasive pads
Mar 02, 2015 | Amana AMV5164 Microwave Oven
VMTK301ss front glass in door is lose. How do I take the door appart to reattach front glass?
Any door repair like this has to be done by a technician who has a
certified 'microwave survey meter' according to DHHS rules. The maximum allowable leakage is 5 mW (milliwatts) per cm2 (square centimeter).
Oct 28, 2013 | Viking Professional Series VMTK301SS
Removal of front glass panel
The glass is not removable, due to safety reasons when the unit is being used.
Feb 07, 2010 | Maytag MMV5165 Microwave Oven
Ge jvm1542bf001 has rust discoloration on glass part of door. Took door off, removed handle. Is there a way to access the inner surface to rid grid of rust?
It would appear that no one knows how tofix this problem. I have the same problem and the only sugestions I get is to replace the door.
Jan 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Black circle
hi my name is mark, the spot probably is a hot spot. something is absorbing some of the microwave energy.or something that food was cooked on in oven got hot enough to cause spot. you can check taking a glass or bowl of water setting it off to the side of the spot, and after it times out, carefully feel spot to see if it heated up. thanks for your question.
Mar 15, 2009 | Microwave Ovens
Microwave door has burn spots on the glass of the door...
i have the same problem, there is a brown spot about 3 inch
by 2 inch at the bottom of the glass, I cannot clean it, it looks
like its in between the glass.
May 01, 2008 | Whirlpool MH6150XMS Microwave Oven
Glass door
It doesn't appear to have been involved in a recall, but since its a non-US model, I probably can't get much more info on it.
Many if not most glass suppliers from the phone book will handle tempered glass too.
Apr 27, 2008 | Microwave Ovens
Just out of box microwave problem
Could we get a picture of this?
Jan 03, 2008 | Microwave Ovens
The brown spots are usually grease / smoke deposits. Usually there are indeed two sheets of glass in the door. If the grease is not arcing or smoking, and the metal screen / mesh (that blocks microwave leakage) is not damaged, then it's likely better left alone. It might be useful to boil a few cups of water with a little vinegar inside the microwave to help dissolve the deposits. In case you want to take it apart, I have attached a photo from a similar model that illustrates disassembly of the door. It is not necessary or advisable to remove the door or hinges when disassembling the door.
Jun 25, 2007 | Goldstar MV-1501 Microwave Oven
Frigidaire PLMV169DC Microwave Oven Logo
225 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
