Question about Avaya AT&T Merlin BIS 34D Telephone
No dial tone, only when speakeron
When handset is lifted, there is no dial tone. however, when speaker is on, only then do you get a dial tone.
Replace the handset and cord
Posted on Nov 13, 2008
Why has the phone reversed, dial tone works only when phone is hung up why?
If I understand you correctly, when you leave the handset in the cradle and press a line, you can hear the dial tone. But, if you lift the handset and then select a line you don't hear anything through the headset. If this is correct, I suspect the handset is damaged, the cord is damaged, or if you're lucky, the clips may not be plugged all the way in on both sides. If you have another phone that is the same, you can switch handsets to test this theory.
Oct 19, 2014 | NEC 22b Hf Aspirephone-bk Stock No....
No dial tone but dial tone on hands free
The battery in the handset may be faulty/flat. If it does not charge up then replace the battery.
Feb 06, 2012 | Lands Phones
Dial tone
You need to disconnect all the cables on each side of the handset and then reconnect. You can also reverse the cable and see if it will help
Nov 27, 2011 | Uniden Lands Phones
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
How do I change time and date on Toshiba DKT2020SD
Toshiba DKT2020 set work with a lot of different Toshiba systems. That being said this should get you in the right direction.
Date
  • From receptionist station, without lifting the handset, press "Intercom"
  • Dial "#651"
  • Dial the time in YY:MM:DD format.
  • Press "Redial" or "#".
  • Press speaker.
Time
  • Dial "#652"
  • Dial the time in military format HH:MM:SS.
  • Press speaker.
Day of the Week
  • Dial "#653"
  • Dial the day of the week (1-7).
  • Press speaker.
Nov 09, 2010 | Toshiba Lands Phones
Call forwarding
Lift the handset, press the FWD/DND button, dial 2 and the extension you want your calls to forward to, you should get a comformation tone, hang up the handset.
Cancel the fordwarding by lifting the handset, press the FWD/DND button, dial 0 , get tone, hang up.
Good Luck
Jul 30, 2008 | Panasonic KX-T7730 Corded Phone
Emmerson Phone Manual EM2248
Emerson (EMSEM2646WH) I need to know how I can set up the speaker phone and in a way that will be clear and loud. I lost my manual, could you send another one to me?
thanks
Nov 05, 2007 | Emerson EMSEM2646WH Phone
Programming instructions for used phone
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Aug 27, 2007 | GE Corded Speakerphone with 2 Cordless...
Cordless phone keeps reading, "lift handset"
This would normally happen when the cordless handset was still in the charger stand. Are you saying it will still tell you to lift the handset after it's removed from the charger stand or base? I would not waste money buying a new battery as it is most likely not the problem but if you have more than one handset you should try swapping batteries. Removing and re-inserting the battery may reset the phone and clear up the problem as well.
Jul 05, 2007 | Coby CT-P8700 Phone (CTP8700)
Lands Phones Logo
371 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
