Computers & Internet Logo
Posted on Nov 13, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I nee to reset a jumper on my new dvd burner.But don't see what I am looking for
JDTec
Level 3:
  • Master 4,338 Answers
  • Posted on Nov 13, 2008
JDTec
Master
Level 3:
Answers
4338
Questions
0
Helped
2127009
Points
14653
On the back of the drive, you can see a set of jumpers next to the IDE connector, You should see a jumper already there. From the right, the first 2 pins are for the master drive (MA), the next 2 pins are for the Slave (SL) settings, and the 3rd set of pins are for Cable select (CS). Above the pins you will see the marking that are in parentheses here.
If it is the only CD/DVD drive, you need to set it as MA (master)
If it is a second CD/DVD drive, you need to set it as SL (slave)
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Anonymous
Level 2:
Scholar:
  • Expert 69 Answers
Anonymous
Expert
Level 2:
Scholar:
Answers
69
Questions
0
Helped
25362
Points
193
Hi david,
Lets get you up and running.
Its on the back of the dvd burner so you have to take it out of the pc to really get a good look at it. it will be really close to the where you connect the power wire and the IDE cable (flat pc cable) .
you can see a picture of them here (although your model will be a little different)
It is possible that there are just little metal spikes (looks kinda like a plug) and no jumpers in sight. In that case you have to get a jumper from somewhere, i recommend a old hard drive, from a friend etc because they only sell in bulk and you don't need 300 jumpers.
Once you find what your looking for, there will be a small diagram right next to them that shows you how to set the jumpers.
I hope this helps you.
  • Anonymous Nov 13, 2008
    oh and the jumpers are the middle set of spikes and the black thing covering the two (of the six) is the jumper.
My number is 0544834751 and i nee the cam plaese
Your request is simply unclear. I don't have a clue what your wanting or what your problem is. "I nee the cam plaese" doesn't make any sense.
Jumper setting in cpu
Not sure what the CPU has to do with anything! The following might help with CD/DVD drive jumper settings:
http://www.computershopper.com/storage/howto/installing-a-new-dvd-burner4
1helpful
ASUS 22x Internal CD/DVD Burner not working
Look into the little jumpers on the back.
If its SATA its np But if its IDE you need to set the jumper to master or slave or cable sellect.
2answers
I installed the new cd/dvd driver, but the compter won't install it.
If this is the only drive on your PC you have to make sure that you have set up the jumper to master. the jumper is located in the back of the drive. you must also install the driver for the drive to work properly.
My lg dvd-rw is not detected but has a power in it
Disconnect the "data" and "power" cables from the drive.
Remove the drive.
Look at the labels on the "back".
You should see some pairs of gold-coloured pins:
MA(ster)
SL(ave)
C(able)S(elect)
Move the small jumper to the 'CS' position.
Reinsert the drive.
Reconnect the "data" and "power" cables.
Restart your computer.
Now, it should be detected.
If not, move that small jumper to 'MA', and try again.
If that still fails, move the small jumper to 'SL' and try again.
1helpful
2answers
Newly installed LG DVD drive not playing DVDs
Ok some where on the DVD drive ther is a diagram of those 6 pins and the jumper. Or if you look on the bottom and the top of the drive you may see 3 abbreviations as follow MA, SL, CS. Place the jumper verticle on the pins that are directly above or below CS. That refers to those pins for the jumper to be on for the drive to be set to Cable Select mode. Cable Select means whatever part of the cable the drive is on it will automatically set the drive to Master or Slave.
3helpful
I need the jumper settings for CD-Master 40E MODEL SC-140. FCC ID A3LSC140B Thank You
When you look at the cdrom driver connectors, the following are the right jumper setting for all CDROM drives.
Left - Cable Select
Middle - Slave
Right - Master
1helpful
Dvd burner not working
There should be something on the label or if you look neer the pins you might see ms, cs, and sl showing you what goes where. most of the time slave is no jumper.
1helpful
2answers
Installing a second dvd drive
old dvd drive jumper should be in one ''MA'' (master) and new drive jumper should be in ''SL'' (slave). http://www.pcguide.com/ref/hdd/op/jump_IDE.htm
Grand Canyon Tech
Grand Canyon Tech
