Question about Philips 9P5534C 55" Rear Projection Television
Screen now has 3 small boxes in middle - one red, one green, one white
I have had this set with no problems for about 8 years. About 6 months ago when I would turn the TV on it would start going in and out on the sides. As time went by it took longer and longer for the set to stay on. It was almost like an hour glass effect. Then one day there was just three small boxes in the middle of a black screen - one red, one green, and one white. I know it will probably cost more to fix than it is worth but I really do like the TV and cannot afford to buy a new big screen. Any help would be appreciated. Thank You!!
  • mcat Jul 18, 2008
    Also have similar problem; picture went in and out for months, now no picture at all (maybe there are 3 boxes but we gave up on this TV for now)
    What exactly am I looking for to repair it?
  • Philips Master
  • 3,459 Answers
Its easy to fix and cheap. Check www.magnavoxhelp.com for chip kits.
Posted on Jun 29, 2008
SOURCE:
Wiring for 6 pin oricom mic plug
I too have an Oricom 6 pin mic with wires broken pin 1 is white, 2 is black and 5 is screen, this does not match any of the above answers and the green blue & red are off with 2, 3, 4, & 6 available
Kevin H
Jun 03, 2013 | Radio Communications
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
Need help with the green wire ground and white wire neutral
as long as the GREEN wires connected to the dryers metallic case your fine
Mar 08, 2012 | Frigidaire Dryers
51F59A red screen all the time
1. entire grill below front screen must come off (usually held in place by screws in back on either side.)
2. locate and remove inspection plate dead center behind it.
3. Locate small black plastic block with 6 black controls built in; three (look carefully) left to right are focus--DO NOT TOUCH THOSE.
The other three are Screens and will be marked with tiny letters r g b (red, green, blue) and green is always middle.
Locate the red screen (not FOCUS).
With set on adjust red down just slightly(usually less than 1/8 turn.
Since the set will be on TAKE CARE NOT TO TOUCH ANYTHING INSIDE THE SET WHEN YOU DO THIS.
IF YOU HAVE QUESTIONS ASK BEFORE YOU TRY THIS.
Nov 20, 2011 | Hitachi 51F510 51" Rear Projection...
Picture calibration settings for 42lg70
Picture Menu
Picture Mode: Expert1
*Backlight: 16
*Contrast: 83
*Brightness: 53
Sharpness: 50
*Color: 55
*Tint: 0
Expert Control
  • Fresh Contrast: Off
  • Noise Reduction: Medium
  • Gamma: Medium
  • Black Level: Low
  • Real Cinema: On
  • TruMotion: Low
  • Color Standard: HD (N/A w/HDMI)
  • White Balance: Warm
  • **Method: 10-Point IRE
    • 10 IRE
      • **Red: 1
      • **Green: 2
      • **Blue: -16
    • 20 IRE
      • **Red: -6
      • **Green: 0
      • **Blue: -7
    • 30 IRE
      • **Red: -5
      • **Green: 0
      • **Blue: -4
    • 40 IRE
      • **Red: -8
      • **Green: 0
      • **Blue: -4
    • 50 IRE
      • **Red: -4
      • **Green: 4
      • **Blue: -4
    • 60 IRE
      • **Red: -6
      • **Green: 6
      • **Blue: -5
    • 70 IRE
      • **Red: -8
      • **Green: 3
      • **Blue: -10
    • 80 IRE
      • **Red: -8
      • **Green: 7
      • **Blue: -16
    • 90 IRE
      • **Red: -9
      • **Green: 5
      • **Blue: -18
    • 100 IRE
      • **Red: -10
      • **Green: 4
      • **Blue: -9
Color Management System
  • Red Color: 0
  • Red Tint: 0
  • Green Color: 0
  • Green Tint: -15
  • Blue Color: 0
  • Blue Tint: 11
  • Yellow Color: 15
  • Yellow Tint: 2
  • Cyan Color: -15
  • Cyan Tint: 0
  • Magenta Color: 0
  • Magenta Tint: -1
lg70 nice tv excellent processor just to bad there is no intensity control on color management oh well still better than what the three s are pushing block out the hype lg will be number 1 in a few years haters are starting to come around and well leds coming,
p.s. i dont work for lg just tired of losers bashing stuff because they dont own it.
im isf certified those settings are right on the money straighter than a ruler
Oct 05, 2008 | Televison & Video
Red , Green And Blue.
Heres the best way to set a phillips screen controls. Go into the picture controls and set picture or contrast to roughly 75%, then set brightness to 50% and then set the color level completely off. Then adjust the screen with the 3 color controls untill you recieve the best black and white picture as possible. If you are unable to achieve a good black and white picture change the coolant in the green and blue tubes. But if you can get a good black and white picture stop there then turn your color level back up and the picture should be correct. Let me know if you need further assistance.
May 22, 2008 | Televison & Video
I have a Philips wall jack model number ph69636. and i need to know how to wire it up with a cat5e cable
Pin Std Phillips
1 White/Orange BLUE
2 Orange Orange
3 White/Green Black
4 BLUE Red
5 White/Blue Green
6 Green Yellow
7 White/Brown Brown
8 Brown White
May 16, 2008 | Computers & Internet
Philips 300wn5 green stripe on screen
I have a similar problem, what is the fix?
Mar 23, 2008 | Televison & Video
Screen Green Tint
Turn down your color and see if the screen has a normal black & white screen. If it doesn't then the CRT is bad (picture tube). If it is black & White then you have a either lost your red or blue.That problem will be in your video driver circuit of which a service center can handle.
Feb 18, 2008 | RCA 20V500T 20" TV
Problems with green arching lines
yes there is a small black box with 6 controls on it, take off the bottom front of the tv, behind that you should find a black piece of plastic you can remove by taking out 2 more screws. the black box should be in the upper rhs.now i don't remember if the top 3 are the screen controls or the focus controls. the rows should be labled, you are looking for the screen control row. the green control is the middle one. you can try turning down the control till you no longer see the green lines. try adjusting in a dark room, it will be easier to see the lines & when they are gone. if you problem is not solved by trying this, then i agree with your tech & the green tube is bad. good luck.
Oct 23, 2006 | Sony KP-65WV700 65" Rear Projection HDTV
Philips 9P5534C 55" Rear Projection Television Logo
59 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
