my zire 71 was fully charged yesterday, today it is black and not charging, i tried the reset button, its dead, god knows why... heart attack probably... please help me!!!
-   I have EXACTLY the same problem with my brand new LG Viewty. The battery ran down overnight and I plugged in the charger to give the battery its first charge, but there is absolutely no response. Phone is completely dead. I have tried it with other chargers and the USB but nothing.-   WordLord
May 11, 2008
-   my zire 71 vwill not turn on.-   summermune
May 06, 2008
-   my LG viewty ku990 will not charge up so what do i do?
i plugged it in and it will not say its charging can you tell me what to do for here thanks-   Guest
Mar 03, 2008
-   My PDA has been locked-   Guest
Jan 09, 2008
-   freezing problems with BlackBerry handhelds-   goharsana
The easiest solutions are easily overlooked. 1. Check your charger; a cheap multimeter will do for the voltage check. If the voltage (dc) written on the back of the charger is what you get at the plug, go to (2),if not, change your charger,problem solved. 2.You either have a messed up screen or battery. 3. Check the voltage at your battery terminals after charging the battery for like 1hr. If you do not get a resonable read; 2-5v ,just trash the battery and head for the nearest shop to get a fresh one.In case your battery reads okay,your screen or worse, one of the components on the board of the set has gone kaput.
A hard reset WILL ERASE ALL INFORMATION so make sure you back up everything before performing a hard reset.
To perform a hard reset hold down the power button and at the same time without releasing the power button push and release the reset button on the back of your device. Keep holding the power button until the SECOND palm logo screen comes on. When you see the second palm logo screen release the power button. It should ask you if you want to erase all data push the up button to erase all data. Your device will restart several times. Then to put your information back on your device just perform a hotsync.
My palm zire 71 will not charge. The battery is brand new but the connection on the palm will not...
(More)
My palm zire 71 will not charge. The battery is brand new but the connection on the palm will not charge. If I push the charger in it will charge but as soon as I let it go the charging stops. I tried with 2 different chargers and it does the same thing. What can I do to fix the charging area on the palm
My Palm Zire 71 does not respond to the touch of the sylus . I have done a soft reset. It stays lit;...
(More)
My Palm Zire 71 does not respond to the touch of the sylus . I have done a soft reset. It stays lit; last night I had sound but this morning I do no. I have it connected to my HP Pavilion laptop. I have been working at this off and on for several days. At first I thought it needed to be charged.
I had to wipe my hard drive. When I reinstalled the palm software, my handheld Zire 71 won't sync. I...
(More)
I had to wipe my hard drive. When I reinstalled the palm software, my handheld Zire 71 won't sync. I have the desktop and I hear the sync sound, but no data enters the desktop.
i was cleaning my room when i found the palm zire 71. after 4 years i tried to start it but its not...
(More)
i was cleaning my room when i found the palm zire 71. after 4 years i tried to start it but its not giving any responce. HOW do i fix it????
How do I do a hard reset? My zire 71 battery is totally DEAD and it is not responding at all to the charger. I don't have the instruction book anymore, so when you say "do a hard reset" I have no idea what you mean. Please help! And thanks!
