Question about HP Office Equipment & Supplies
I have the HP Photosmart C6280 All-in-One Printer/scanner/copier; what ink cartridges do I need for replacement? And how do I put them in??
  • 44 Answers
Well you've got a nice printer! With 6 different ink cartridges, you only need to replace the one(s) that is low. Black - C8719EE
Cyan - C8771EE
Magenta - C8772EE
Yellow - C8773EE
Light Cyan - C8774EE
Light Magenta - C8775EE
Simply turn off the printer, open the cover to reveal the bank of ink cartridges. Pop up the white-ish plastic covering tab, pull out the old cartridge (this should not require too much pressure). Then pull off any protective film from the new cartridge, re-insert one at a time. Power up printer wait for self test, should be all set to go
Posted on Nov 13, 2008
HP Photosmart C6280 - Where is the printhead???
ALWAYS USE HP CARTS....HP IS REAL FINNIKY ABOUT AFTER MARKET CARTS...
Dec 05, 2012 | HP Photosmart C6280 Printer
Replaced empty ink cartridges in hp c6280 printer but computer says they're empty. help?
Did you remove the protective cover / tape, you re put the cartridge.
Jul 25, 2012 | HP Photosmart C6280 Printer
PRINT INK CARTRIDGE ALIGNMENT FAILED HP C6280
If the alignment failed on HP Photosmart C6280, Try to check if any of the cartridges are low on ink. if so replace them and try to re-align
If that is not the issue, Remove the Cartridges from the printer and clean the contacts with lint free cloth and put them back in. The printer should go thru auto - alignment..
If this fails too, Press Cancel button on printer and Press the Menu button ( setup button ) and scroll to Tools menu - Press OK - Under tools option you will find Clean Cartridges - Press OK.
If this process too does not fix the issue, mostly likely your printer has gone bad. It needs replacement.
The best i can suggest you will be to Call HP support - 1-800-474-6836 and check best deal they can offer you on upgrade printer.
Regards,
Suhail
May 20, 2012 | HP C6280 All-in-One Printer
I bought my HP Photosmart C6280 in Switzerland, using cartridges 363. Now I have moved to South Africa and I can only buy cartridges 177. When I put them into my printer it says "Incorrect Ink...
it is likely that you havr a mix of trade and host supply of ink cartridges. Even though HP363 and HP177 are compatible cartridges it is not the issue. Refer this article.
Hope this helps.
May 18, 2011 | HP Photosmart C6280 Printer
My hp photosmart C6280 prints but no ink comes out on the page at all. It thinks it is printing fine.
This is due to either dry or clogged printer cartridges. You can try removing the cartridges from the printer and cleaning the metal contacts with alcohol and a Q-tip, but more than likely they will need to be replaced. This can happen if the printer has not been used in a while.
Mar 15, 2011 | HP Photosmart C6280 Printer
HP Photosmart C6280 "Ink System Failure"
The ink failure error is caused by air in the ink feed tubes in your printer. This happens when the ink in your cartridge runs out and the printer sucks up air instead of ink. This is a very common problem with this series of printer. We have a step by step repair solution for this error posted on our web site at: www.ccl-la.com click on the printer repair pages and follow the links to your printer series.
I hope this helps, If so pleae rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Aug 26, 2009 | HP Photosmart C6280 Printer
False error empty cartridge
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jun 01, 2009 | HP Photosmart C6280 Printer
You must replace all cartridges with new GENUINE HP carts to get a sucessful alignment.
This is how HP makes their money.
Jan 15, 2009 | HP Photosmart C6280 Printer
90 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
