Question about Linksys Wireless-G WPS54G Print Server
Have print server, was working great now nothing!!
I have not been able to print from my network, even though I've uninstalled and re-installed the drivers. It worked fine up until about 2 weeks ago.
    Scholar:
  • 69 Answers
HI Irwilliams,
when you uninstall and reinstall a printer on the network you have to let windows attempt to detect it again. i would recommend opening the control panel>printers and deleting the one you want to use. then click on add a printer and allow windows to detect a printer on your network.
please tell me how this goes.
Posted on Nov 13, 2008
How i solve the blank print on a3 paper on autocad
It seems you are using a print server to connect the printer 1280 to your LAN. Uninstall the printer software and printer server driver. Connect the print server to the network and first re-install the print server driver. Then connect the printer to the print server and install the printer software. Refer user manual for assistance. Bot the print server and printer software should be compatible with your operating system.
Jan 07, 2015 | HP DeskJet 1280 InkJet Printer
Why would my Trendnet Print server TE100-P1U not be seen by all computers on the network even though it can be pinged. I can't install it on these computers even though it can be pinged
May requires software loaded on every computer - software that will create the non-std print server "port".
More expensive print servers like the HP jetdirect print server use std tcp/ip ports.
Nov 13, 2013 | Trendnet 1-Port Print Server TE100-P1U...
We believe the problem with our LaserJet 5000 GN is the JetDirect 610N network connection on the back. It prints its own internal documents just fine, so we know it's not that. And the network itself seems...
New Part Number is J7934A it is newer version and costs about $75.00 . To test the jet direct, press menu and then information, print the configuration page, if more then 1 sheet comes out 1 will be for the jet direct if this prints there is nothing wrong with the Jet Direct. however if you are printing through the network and you are getting any type of special characters like $%^ it is most likely a driver issue, uninstall the printer and reinstall using PCL 6. You can go to HP's wesite for driver support. Hope this helps.
Jan 03, 2011 | HP JetDirect 610N Print Server
Connecting sharp AR 5316 to a wireless network for office use
With great difficulty.... Seriously though, you MUST get the driver for each operating system, Install each Driver on each machine, and then simply connect each computer to the printer as a "Networked" printer. I may be efficacious, to have all drivers on every PC, all in same Directory so that each is available to each other...Right ALL machines, must be in same WORKGROUP, ALL have a password, The printer MUST have a name, Install the drivers as Administrator.
May 12, 2010 | D-Link Air Plus DP-G310 (dpg-310) Print...
I had a PS101 hooked up to an older wireless router. It was working fine on my new Vista Machine. The router died and just installed a NETGEAR WGR614 Wireless Router 802.11g. Now it doesnt see the print...
This was more hastle than it was worth. So I bought a new print server (twice), neither worked either. Might be the router, but after spending 2 hours on the phone with INDIA, I said forget it and took it back, bought a parallel card and gonna hook it up with a cable!
Jan 01, 2010 | NetGear PS101 Mini Print Server Print...
Vista 64 cannot print using USR5461 print server
sir chuck, try NETWORK MAGIC it can fix your problem from PRINTER & file sharing and others. It fix network problems regardless of Operating System , windows, linux, mac etc.
May 04, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
DP-G301
Update the firmware of your Print Server.
Mar 04, 2009 | D-Link AirPlus G DP-G301 (DPG301) Print...
Not working on window 2003 server as a network printer
I have had a similar issue with both laserjet 3005N and 1320N machines setup as network printers on a windows 2003 print server. Both machines install correctly and print test pages but once you push to much of a print job to it (in my case it was a 12mb pdf file) the printer stops printing and never prints again for some reason. After a quick reboot a test page will print but what gives?? Buffer issues? Not enough ram? None of this makes sense since the printer displays nothing and just stops printNo test pages or anything. I tried re-installing it and rebooting it. Nothing.
Jul 12, 2008 | HP LaserJet 1320 Printer
Print server thinks printer is offline
This printer works only with selected printer and they do not work with other print sever to know the print server which they work please click on this link and then click
Hide/Show Additional Results
http://search.lexmark.com/printer/US/en/22N5000
This server will cost $149 instead you can buy wireless Lexmark printer X6570 at the same price,
Good luck..................
Jun 21, 2008 | Lexmark X5470 All-In-One InkJet Printer
Microsoft word.... no go
search your hard drive for nomal.dot and delete it
Dec 20, 2007 | Dell 3300 Print Server
Linksys Wireless-G WPS54G Print Server Logo
155 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
