Question about Hoover H120M Front Load Washer / Dryer
Hoover WDM120 My washer dryer will wash but will not spin or dry. We have checked the belt which is intact. Waht else could it be ?
    Novelist:
    Champion:
  • 244 Answers
This will be your carbon brushes which are situated at your motor in a plastic cover with a wire is attached if these are low then it will not spin must be at least 8ml long for it to work they start off about an 1inch in length
Posted on Aug 22, 2007
SOURCE:
Hoover WDM120 scraping noise heard when drum spinning with a load in washing machine.
have come across this prob before the noise you describe sounds like an underwire from a bra or the condencer on the back of the mach some had a baffle plate fitted just where it goes onto the backof your mach on some this came loose and caused it to scrape of the back of the drum hope this helps .
Jun 07, 2011 | Hoover H120M Front Load Washer / Dryer
Changing dryer belt for lse7804ade washer dryer stacker
If the washing machine / tumble dryer / spin dryer seems to be making the right sort of noises, but the drum is not turning, unplug it, take the rear cover off and check to see if the drive belt is still intact and on the pulleys.
Mar 09, 2010 | Washing Machines
Hoover Washer/Dryer WM120 : Dryer function - drum not turning
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
treru
Jan 25, 2009 | Hoover H120M Front Load Washer / Dryer
Programmes
Dear Flying fish,
happy to help,
Here is a location for this hard to find washer manual!
http://www.4domex.co.uk/cgi-bin/product.pl?PID=1081943
Please leave a solved rating before you leave the site,
Sep 28, 2008 | Hoover H120M Front Load Washer / Dryer
Hoover washer dryer saver 1300
I have inherited a hoover saver 1300 in new flat, the dials have worn away and it goes onto drying mode after wash, how can i have it on wash and spin only - NO DRYING? Thanks
Apr 12, 2008 | Hoover H120M Front Load Washer / Dryer
Hoover wdm120
more than likely that yor pump hasnt let all the water out try getting your outlet hose from under the sink and place into a bucket low to the ground if water comes out than your door will open after a short while if water does come out than make sure your pump or drain hose is not slightly blocked if not then your pump is on its way out also if water doesnt come out of drain hose than take it off at the pump if it comes out then,then your hose is blocked m8
Aug 20, 2007 | Hoover H120M Front Load Washer / Dryer
Hoover Aristocrat Front Load Washing Machine
i think you will find the carbon brushes r worn out they r mounted on the side of the motor held on by 2 5.5mm nuts or 2 screws 1 brush on each side of the motor switch off at the mains b4 you start work good luck
Aug 19, 2007 | Equator EZ 3600 CEE Front Load Washer /...
Hoover H120M Front Load Washer / Dryer Logo
287 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Steve F
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
