Question about Craftsman 4 Cycle Blower/Vac
My craftsman leaf blower wont start
Was running perfect and one day i tried to start and nothing so what do i do to troubleshoot my starting problem
    Problem Solver:
  • 16 Answers
I have this type blower -25 cc craftsman 358.794741 model. took my first one back aftwer it run for awhile. they fixed it. ran for awhile and then stopped. found out sears sets these things to very lean to pass cali. emmision standards. adjusters on carb. need a speacial tool --- so they say. took a 1/8 in socket with a raised neck. think it was 3mm. ground down the outside a bit. tool set perfectly down onto adjusting screw. turn counter clockwise 1/4 turn started everytime after that. .
Posted on Nov 19, 2011
  • 1 more comment
  • chip Nov 19, 2011
  • chip Nov 19, 2011
  • chip Nov 19, 2011
    i think all carbs are set up like this
I found the bolt on the bottom of the blower fan was loose and when I pulled the cord the piston was not going up and down. After I tightened the bolt it was looking like it might start but it would only fire when the primer button was used, there was no gas coming from the carb into the motor on it own. I saw nothing wrong with the carb but I did not check the head yet. I am looking for a manual but nothing so far, I need a breakdown of the carb and what the setting of the idle screw should be.
Posted on Nov 17, 2008
I had a similar problem and found that the cylinder head had loosened up due to vibration. I tightened the cylinder head and it worked find.
Posted on Nov 15, 2008
    Scholar:
  • 132 Answers
HI THE FIRST THING TO DO IS REMOVE LEAD OFF SPARK PLUG TOP THEN REMOVE SPARK PLUG ITSELF YOU WILL NEED A SPARK PLUG REMOVER OR A SOCKET TO DO THIS AFTER REMOVING THE SPARK PLUG CLEAN OFF EXCESS OIL BY DIPPING IN CLEAN PETROLAND CLEANING WITH TOOTHBRUSH LET DRY THEN WITH A FOLDED PIECE OF WET AND DRY SANDPAPER GENTLY RUB BETWEEN THE SMALL GAP AT END OF SPARKPLUG THEN REPACE SPARKPLUG AND IN MOST CASES IT SHOULD START FIRST GO BESTALUCK GLENN
Posted on Nov 13, 2008
My craftsman 25cc leaf blower wont start
pull the plug, plug into wire, touch head of plug to metal on engine. hold by rubber boot while touching pull starter, see if you get a spark across the plug gap, its small but you can see it. if no spark check switch. if plenty of spark clean fuel system and check primer
Nov 04, 2014 | Garden
Leaf blower craftsman manual
Is it getting gas? Have you tried a spray of Starter Fluid in the Carburetor? to see if it will start on that?
10% Ethanol Gas is a carburetor killer. If the engine hasn't been run in few months, chances are the Ethanol caused problems in the Carb.
Write your congressman and tell then to stop the Bill that has us using this do-nothing Ethanol gas .
Oct 26, 2013 | Garden
I have a Craftsman 794774 leaf blower/vac w/25cc engine that won't start.
Many of these small blowers have an alloy key moulded into the flywheel, if this has sheared it will knock the ignition timing out, and will never run.
Feb 23, 2013 | Garden
Won't start --has gas--has spark craftsman leaf bower
most likely the air filter is clogged, take it out blow it out or spray water through it and allow it to dry completely.
alterinavely, just pouring a small amount of gas onto the filter should make it work, i would do that even if you do clean it properly.
this method works for cars too!
Nov 07, 2009 | Craftsman 4 Cycle Blower/Vac
Hi. My craftsmal leaf blower runs OK for 3-5 then dies????
Could be a blocked vent on your fuel tank - is there a vacuum in the fuel tank immediately after it stalls?
Oct 25, 2009 | Craftsman Garden
My craftsman leaf blower will not start, its firing, getting fuel. will not start even if you put gas in the sparkplug hole
It sounds like the engine is worn out. Have you done a compression test on the engine? If it is not at least 100 psi, the engine will not try to run.
I would get a compression test done on the engine, then take out a loan and go get you a commercial grade blower.
Good day.
Oct 07, 2009 | Craftsman Garden
Leaf blower wont dstart
try replacing the spark plug.
Nov 11, 2008 | Craftsman 4 Cycle Blower/Vac
Craftsman 4 Cycle Blower/Vac Logo
1,000 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
