Question about Oreck XL2200 Bagged Upright Vacuum
Vacuum billows dust
My Oreck Upright has started to billow dust from the front end - whats' wrong?
  • 328 Answers
Its clogged. It needs to have a thorough clean out and this can be done by removing the sole plate / floor head where the beater bar is and checking to see that all the air ways or the dust channel that flows through t he main spine neck at the back is clear, checking the main spine at the back is clear and finally to check that there is no clogging at the top of the back spine as well. Oreck XL can become clogged quite quickly due to its relatively small suction tube openings and small motor.
Posted on Nov 18, 2008
Why does my Oreck upright. Acumen keep shutting off after a couple of seconds?
Atek,
Sounds like you have one of the Oreck's that has a sensor that looks for the brush turning and you received the wrong brush. Look to see if there is a metal ball embedded in the wood about a quarter or a third of the way down from the end opposite the belt end. If there is not the metal ball, you have the wrong brush roll. Getting the proper brush roller should make all the difference for you. Hope this helps!
Feb 24, 2015 | Oreck XL Platinum Pilot Bagged Upright...
I have an Oreck XL 2310RS. What bag number do I need for it? Thanks.
All oreck uprights take bag type CC. I would Recommend buying oreck brand bags. they have the only patton on the bags. off brand bags will work but they will leak and tear and break.
Sep 08, 2011 | Oreck XL Ultra Bagged Upright Vacuum
My oreck halo starts and stops when vacuuming. you get two or three motions and it stops. my hand tingles when i vacuum. can you tell me what is wrong. it was bought in March of 2009
sound like you have a loose wire inside the unit, " DO NO USE TILL ITS FIXED ". Carefully start taking apart in the locations where the wire runs through. Pay attention to all the wiring, any little nick could be the problem. Somewhere in there a wire is touching the inside of the unit. You might want to get intouch with Oreck, that is a manufacturing defect, and not worth a law suit if you get electricuted from it. Thats what the tingleing is, your getting juiced by it.
Mar 06, 2011 | Oreck HALO100 Bagged Upright Vacuum
Vacuum smells like rubber burning. Replaced belt. same result
My vacuum's belt fell off, So I fixed it. Two days later my vacuum wouldn't turn on, so I opened it up again and took out a dust ball in between the electrical wires. I turned it on and sparks and snapping sounds came form the motor. Also burning rubber smell, What wrong? Is my vacuum fixable?, or should I buy a new vacuum?
Jan 15, 2010 | Oreck XL2000 Bagged Upright Vacuum
Oreck upright hard to push
If hard to push, only a few things to check:
(1) Rear wheels will get hair or thread wrapped around axles, dust, etc. and be hard to turn. Make sure each wheel turns easily.
(2) Small wheels on newer models (since about 1997-98) toward front are worn, missing or have same problem as item 1.
(3) Brush roll not turning. The brush roll actually helps pull this unit along the floor, as it rotates in the "forward" direction. If the belt broke, and you do not realize it, it may suddenly seem harder to push.
Oct 11, 2009 | Oreck XL2000 Bagged Upright Vacuum
Dirty Oreck bag
yes but separately from other clothes
Aug 09, 2009 | Oreck XL Ultra Bagged Upright Vacuum
My upright Oreck Vacuume XL 2
the main tube is clogged.
unplug it, open bag area, remove bag look for clog.
if clear, take off lower coller, pull up tube, remove blockage, either in tube or fan area.
if clear, look in bottom by intake area for blockage.
fan can not run backwards.
good luck.
Jun 07, 2008 | Oreck XL Ultra Bagged Upright Vacuum
Dust blowing out of hoover
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618781&thid=617336
Dust blowing out of Hoover
Posted by Lunagus on May 23, 2008
When I start up my year old Electrolux Loopie Petlover vacuum a large amount of dust comes out of where the HEPA filter is - can you suggest reasons?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck Upright 014T XL Pro 14 Upr Vac
In answer to your question, if the HEPA filter is leaking then you should replace it because it has lost it’s filtration – but my question is – is it on the Oreck, Hoover or Electrolux --- all three have HEPA filters and needs replacing and to make sure that the HEPS filter is installed correctly or other wise the filter will leak and if that happens then contact your local vac dealer in your neighborhood. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 23, 2008 | Oreck UPR014T XL Pro 14 Upright Vaccum...
Reassemble of handle on upright
place handle half with the posts that hold the screws facing up.
silver pole with hole that goes completely throuigh goes over lower screw post (Long side)
static wire - L shaped end goes in small hole on opposite side of handle just below
vacuum switch hole, curve of wire should follow curve of handle and fits into top of
silver pole and pushes againt it providing push to hold siver pole.
hope this helps
Apr 02, 2008 | Oreck XL2200 Bagged Upright Vacuum
Oreck XL2200 Bagged Upright Vacuum Logo
247 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
