Question about Hampton Bay 52 In. Huntington III with Quick Install in Antique Brass Fan
Fan clicks My ceiling fan has begun clicking when turned on. The sound is eminating from the base of the unit. I've checked & tightened all screws, and the clicking continues. It is not a grinding or a popping, nor is the clicking regular. It just occasionally will click intermittently when the fan is on. When I inspect the fan, I can replicate the clicking if I very gently push/pull on the fan blades. Any idea of how I can correct this?
    Scholar:
  • 48 Answers
Upon the first sentence, that sounded somewhat like a wiring fault, due to the intermittent clicking sounds. However, if you can duplicate the sound by shifting the blades, it could potentially be a motor fault. Try shutting off the breaker to that fan, and seeing if the sound continues when you move the blades. If it does not, then you're looking at a wiring problem, probably on the pivot joint at the base. If it does, you may just have a slightly creaky fan unit, at which point there's not much to suggest, as lubricating the pivot joint could cause the fan to spin at odd angles, or lose control if the fan becomes unbalanced. Also, try reversing the blade direction by toggling the switch on the motor unit, or just below. If the problem persists, please post again with the additional details.
Posted on Jun 04, 2007
Fan has begun to "hum"/squeek" when turned on and keeps me awake at night. I can't find a point to lubricate it. Home and fan are only 2.5 yrs old. Thanks for helpful tips.
Sounds silly, but tighten the fan blades - the blade is fastened to the metal at the top of the blade by two or three screws or bolts.
Apr 01, 2017 | Dryers
The fan is installed but fell down or looks like it was not completed , what do i do to screw the base from the wall to the base of the fan ?
In a typical ceiling installation, the fan assembly is attached to a downrod which, in turn, is securely attached to a junction box in the ceiling.
Dec 13, 2015 | Hunter (25417) Ceiling Fan
My ceiling fan is making a clicking noise on low and medium speeds
Make sure all screws are tighten, Since this is a store brand for Home Depot it could be the bearings. You get what you pay for. Low-end fans are made from cheaper parts.
Apr 20, 2013 | Hampton Bay 24002 Ceiling Fan
Hampton bay ceiling fan broke. How to screw it back up
It already looks like it's "screwed up". ( LOL) BEFORE BEGINNING READ ALL OF THIS FIRST< PLEASE> First turn off the breaker that supplies power to the fan. Take down the whole unit up to the ceiling mounts. It looks like the wood is broken that the screw bracket used to mount the fan is on. If it is you will need to reinforce the wood and rescrew the fan mounting bracket on it. THe ball carrier from the bracket should now be secure and ready to mount the swing ball of the fan at the top of the fan unit motor. Next rewire the fan to the wires in the ceiling with the wire nuts you removed. Tighten the ball screw and push the cover plate up to the ceiling, fastening it in place with the screws provided to the ceiling plate...Done!
Jan 01, 2013 | Heating & Cooling
Someone helped me install a ceiling fan. I told them that I here a clicking noise still , they said to go back and tighten every screw. I did that but the clicking noise is still their. What are my...
Check that all the blades are aligned when the fan spins. If one blade is higher or lower than the others it throws the fan out of balance and makes a clicking noise. Also check that the pitch on all the blades is the same, this has the same effect. The blades can usually be bent just a bit to correct any misalignment.
Jun 09, 2011 | Hunter (25417) Ceiling Fan
Need to get replacement electric fan motors for bathroom exhaust fans. 1-Model # F33HXCFJ-1187 and 1-Model # F33HXBME-903. Both made by Emerson 1/100 hp, 120 v
Hello
Using a stool positioned directly beneath the inoperative fan, grasp 2 opposite sides of the plastic fan cover and pull cover down 2 to 3 inches until wire holding clasps on each side are exposed.
Squeeze the 2 wires on each clasp together until the fan cover is released and set aside fan cover.
Locate fan electrical plug and unplug the connection from the electrical outlet.
Locate the screw securing the fan unit to the ceiling. This is often found directly adjacent the electrical outlet. Some fan models will have 2 securing screws. These will be located on opposite sides of the fan base.
Use flat-head screwdriver to remove securing screw, pull fan out of the fan well and set old fan aside.
Align replacement fan in position to allow electrical plug to be inserted in electrical socket and plug into electrical outlet.
Insert fan into ceiling well and secure by inserting and tightening securing screw(s).
Test fan by turning on wall switch. If fan fails to operate, check to be certain that the plug is fully inserted into the electrical outlet. If fan still does not operate, check circuit breaker and reset if necessary.
Replace fan cover by holding cover in place with 2 wire clasps just below the slots in the fan base. Squeeze the 2 wire ends of each clasp together and insert these into the the slots on opposite sides of the fan base. Once properly inserted, the ends of the wire claps will spring into place.
Push the fan cover up allowing the wire clasps to be fully inserted into the slots on the fan base, at which point the clasps will spring open securing the cover in place.
THANK YOU FOR VISITING FIXYA
Jan 31, 2011 | Home
Lightning causes ceiling fan to make clicking noise
sounds like surge shorting
call in an electrician to check the installation of the unit
Aug 06, 2017 | Hunter 20761 52'' The Stratford II Brushed...
My fan is clicking. Does it need oil?
If this bis a ceiling fan, then most likely the blades need tightening.
The bearings on MOST common ceiling fans these days are permanently-sealed, no oiling required or possible. Some older fans such as some of the Hunter units can and should be oiled.
Aug 23, 2009 | Chateau Dryers
We have a hampton bay fan and can not get it off the ceiling how do you remove it?
I have no experience with ceiling fans and for me removing the housing didn't get me anywhere. For our fan (Model 23758) there was a nearly invisible ring of material at the base of the fan where it meets the ceiling. This was in place for apparently aesthetic purposes as it hid the screws that secured it to the ceiling bracket. By rotating this ring and pulling down, we were able to to remove it.
Jun 30, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Hampton Bay 52 In. Huntington III with Quick Install in Antique Brass Fan Logo
213 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
