Question about Bose Wave Radio
75 ohm antenna connection ''disappeared''
My model AWRC-1G works fine except no antenna.
1: How do I open the case? I removed the 3 obvious screws but wouldn't open.
2: I assume when I get inside the wiring would be obvious or do I need a schematic.
Thanks ..Bob
  • jembrown Dec 08, 2008
    I have the same problem with my AWRC-1P.  I'm trying to get inside to look at a fuse.  I removed the two screws in the back and the one on the inside of the cd deck, but when I lift up from the back there still seems to be something on the inside that's holding the front down.
  • zanewaldon Jan 15, 2009
    I need to solder a antenna fitting to to the back of radio but have no clue at what points to solder at. Please help !
My antenna connector came off as well. After removing the two screw fron the back (on top), open the CD cover and remove the large screw at the front of the compartment. Now flip the unit over with the front of unit toward you. Insert a small flat screw driver between the cover and the botom on either side. There are two large tabs (either side) on the botom. pry away and up. Flip over and remove the cover. Careful of the ribbon cable inside, it is long enough to lift and flip the cover.
Posted on Dec 14, 2008
Where to attach external antenna on model hta-25f
For the Hitachi HTA-25F, the balanced wire antenna connections are the row of terminal screws on the bottom - inside the blue highlighted box. If using a 75 Ohm coax (unbalanced) wire connection - use the connector in the top right corner of the blue highlighted box instead.
Jul 27, 2015 | Audio Players & Recorders
I moved and cant figure out how to hook my 4030 channel master antenna up again. I have a converter box and hd toshiba tv
INSTALLATION
Channel Master by PCT indoor antennas are designed to provide optimum reception of
UHF / VHF and FM signals. These antennas have 75 ohm outputs, which allow simple,
hassle-free connections to today's newer TV sets that have 75 ohm F type connector
inputs.
Simply attach one end of the supplied 6' cable with F connectors to the output of the
antenna (Fig.1). Attach the other end of the cable to the input of the TV set or VCR
(Fig. 2). Some adjustment of the antenna might be necessary for optimum viewing.
Model CM-4030 includes a built-in amplifier and separate power supply.
1. Follow the same steps as above for antenna to TV / VCR hookup. Note : Model
CM-4030 also allows for two set / VCR hookups with its unique dual output feature.
2. Insert the power injector into the back of the antenna (Fig. 3). Plug in the power
transformer to the closest electrical outlet (Fig. 4).
Google 4030 Channel Master Instruction Sheet for the PDF File with the diagram.
Fig 2a
Fig 3 Fig 4
prohibido por ley.
TV
Fig 1 VCR
Fig 2
Fig 2a
Fig 3 Fig 4
Jan 10, 2014 | Channel Master 4030 Amplified indoor HDTV...
Coaxial FM antenna
Radio Shack has an
adapter catalog number 278-0291. It takes some effort to push the 278-0291
adapter onto the FM UNBL 75 ohm terminal so wait until you have the 278-0291
installed before you connect your 75 ohm coax on to your new adapter.
This will resolve your FM screw on F connector antenna interface issue.
I see others trying to
help suggest using a 300 ohm to 75 ohm transformer match unit, this isn't what is needed. Your receiver antenna input IS a 75
ohm input.
May 22, 2013 | Sony MHC-GX450 CD Shelf System
Where can I find an antenna for this unit?
External FM antennas can be had for as little as $7 for the a simple dipole version (looks like a "T") to a highly directional outdoor type for over $150 at your local Radio Shack below:
http://www.radioshack.com/search/index.jsp?kw=fm&f=Taxonomy/RSK/2032189&categoryId=2032189&kwCatId=2032057&fbc=1&filterName=Category&fbn=Taxonomy/Antennas
The simple $7 dipole is a "twin lead" 300 ohm type that many home stereos shipped with because they are inexpensive, take up little room in the box and work surprisingly well for all but the very distant of stations. These antennas are also found for sale in many department and some hardware stores too. Your stereo may not offer twin lead or 300 ohm hook ups (2 terminal screws near the ANT label) but only a 75 ohm connection (like your cable tv connections), in which case, you'll need an inexpensive 300 to 75 (terminal to cable) ohm balun (or matching transformer) like this one below:
http://www.amazon.com/Parts-Express-Push-On-Balun/dp/B0002ZPIOQ
or to go the other way - from 75 to 300 (cable to terminal) ohm balun like this one:
http://www.amazon.com/75-300-Ohm-Matching-Transformer/dp/B0002ZPIOG/ref=pd_bxgy_e_text_c
Please rate this reply if you found it helpful. Good luck!
Jul 01, 2010 | Philips FW-D5 CD Shelf System
Sony kdl46w5150 with external antenna dropping signal on some channels
1. Check for any loose connections starting at your TV. (Coaxial cables unscrew themselves with vibration...) Check all outdoor connections for corrosion and cut off and replace any cable ends that show corrosion.
2. Check your alignment - (positioning or pointing)
http://www.wowvision.tv/OTAalignment.htm
3. Replace the balun a.k.a. 75 ohm matching transformer.
If these don't work, a larger antenna is needed...
with one exception:
That exception is if your signal is too high. If this is the case, change alignment to reduce signal a little.
Jun 11, 2010 | Sony Televison & Video
I have a Bose Wave radio AWRC-1g. The CD player
Yes you have a defective laser assembly. The 139 is a great price as buying the laser lens alone will cost you around 70 .Bose will also upgrade with any new software and will also provide you with a 1 yr warrenty.
Mar 21, 2010 | Bose & Wave& Music System
Can't find the voltage specs for terk 9330 tower fm antenna
Product Specs: General: Product Type Radio antenna Recommended Use Indoor Width 3 in Depth 16.9 in Height 3.5 in Color Black Localization English Antenna: Wave Band AM, FM / FM: 87.5 - 108 MHz, 540 - 1700 kHz Impedance 75 Ohm Gain Level 42 dB Amplifier Built-in Included Accessories Connector coupler, impedance transformer Connections: Connector Type 1 x FM antenna ¦ 1 x AM antenna Power: Power Device Power adapter - external Manufacturer Warranty: Service & Support 1 year warranty Service & Support Details Limited warranty - 1 yearlet me know how this works out for u
Jan 31, 2009 | Audio Players & Recorders
I have a bose wave model awrc-1g cant set time from military time to regular
Hold the alarm setup button and at the same time hit the on/off button.
Oct 16, 2008 | Bose Wave Radio
External FM antenna
The fix for the problem is simply go to Radioshack and purchase their part number 278-267 which is an "F" jack to 1/8" Male Plug. The cost is $6.09. This should solve your problem. The 75-Ohm antenna plug can now be screwed or connected to the "F" connector.
Aug 31, 2008 | Bose Wave Music System CD Shelf System
Bose Wave Radio Logo
537 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
