Question about Kenmore 62872 Electric Dryer
Kenmore Dryer Model 66801692
Kenmore Dryer #66801692 is at least 15 years old. Right before it quit working, it smelled like something was burning. Dryer was immediately shut off. Lint screen checked and dryer was restarted but would only run for 10 seconds. I tried to start dryer next day and it sounded like motor was making a humming noise when start button pushed. I did this a couple of times then it sounded like internal breaker shut unit off. I waited 10 minutes, pushed button and now dryer is working normally, however, dryer does not seem to dry as quickly. Is this worth a service call due to it's age? Thank you.
  • tom_blattner Nov 14, 2008
    Thank you for your advice. I'm going to take it. I appreciate you taking your time to respond.
When I pull start button at lessdry or more dry or any minute I can pull it but dryer do not start at all.
Posted on Feb 16, 2009
    President:
  • Kenmore Master
  • 2,651 Answers
At leas 15 yrs old??? think it's done its time, its a great machine andwould reccomend replacing with a whirlpool/kenmore unit again.no tworth servicing in my opinion, average call here in new york 150-225, anbd those are for simple issues. id rather put money into new unit! bit be sure to check your venting id say 85% of dryers taking too long to dry are vent related issues
Posted on Nov 13, 2008
Kenmore elite front load dryer squeaking and burning smell
you have a bearing in the drum support that has frozen and now the rubber wheel is burning up. The bearing needs to be replaced ASAP. You could damage the dryer if you continue to use it.
Feb 16, 2014 | Dryers
My amana dryer smells like something's burning
You will need to open the dryer ans clean the internal duct work.
May 22, 2012 | Amana NED7200TW Electric Dryer
Dryer has a burning smell. repair man came and looked at it and said mechanically the dryer looked brand new (its only 11months old). He suggested we repair the exhaust tube and vent (which we did). ...
do you have pets ie a dog that moults, as quite often its is foung that pet hairs get inside on the elements and cause a burning smell. if so disconnect from supply. Remove back cover by removing screws and hoover the elements. Make sure electric is off hope this info is useful.
Dec 16, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer smells when on.
WELL DONE FOR HAVING A DRYER SO OLD AND STILL WORKING, THE PROBLEM COULD BE YOUR DRIVE BELT COULD BE TIGHT AND AND BURNING RUBBER .
Oct 21, 2009 | Dryers
Kenmore Electric Dryer Series 80 Model
Disconnect the dryer from your vent completely,. pull dryer out 3 ft. from wall and test to see if the smell continues, You have to test for a few minutes to clear out any burning lint from vent restrictions. If the smell hoes away then you know you have venting problems. Also check on the grate that covers the element( the part you look through when you see the orange glow from the element) sometimes plastic or clothing burns onto this grate and needs to be cleaned off. I the smell remains, you will have to tear down the dryer to see if you can find the cause of the smell.
Sep 21, 2009 | Kenmore 62802 Electric Dryer
Dryer shutting off too early. Faint smell of something burning?
Check the vent for clogging condition that will turn off unit and cause it to overheat. If vent goes up to roof check up there also - that is where mine was clogged with a sort of paper mache clog!!!!!
Sep 02, 2017 | Whirlpool LER4634J Electric Dryer
Will not agitate
Bad pump Pump bearing locked up something up in pump brazzierre underwire shoulder suppet thing IN pump. Check pump
Feb 13, 2009 | Kenmore 63942 Dryer
Electric Dryer shutting off
Do you store clothes or anything on top of it that covers the top area? If so please take that stuff off of it and never place anything on top which insulates it and makes it over heat. make sure you have good air flow out the exhaust and all the way out your house Good Luck
Nov 17, 2008 | Kenmore 63942 Dryer
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 62872 Electric Dryer Logo
267 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
