Question about LG DLE5977 Electric Dryer
Dryer not drying clothes
I have a old kenmore dryer,at least 10-`15 yrs old. It will not dry the clothes! It takes so long for it to dry a load. Could it be the heater? Is it worth for me to have this fixed? It took me almost all afternoon to get sheets dry from a queen size bed.
  • hswan80 Nov 14, 2008
    This is not a electric dryer! so now what?
  • 44 Answers
I'm guessing it is electric? Do the clothes get very hot? If not, one or both of your elements may be bad. If it does get hot inside after running for 15mins, then perhaps your exhaust piping is clogged up. Can you tell if the output blowing from your dryer is a weak or powerful flow?
Let me know.
Posted on Nov 13, 2008
  • Cyweb Nov 14, 2008
    OK, so back to basics, after running for 15mins open the door & feel the clothes. Are they very hot? They should be, if they are cold your gas is most likely not igniting. If they are hot, your output piping is probably clogged. Check the tubing leading out of your dryer for blockage. With the system running, their should be plenty of output of warm air through the tubing. Back to cold clothes, that indicates either your pilot is out or the electronic ignition is not firing to trigger the gas to turn on.
Same way towels take 2hrs to dry , white take an hour. this is insane after pending that much on a dryer that is only maybe 1 1/2 yrs old
Have the dryer vent checked and the venting from the wall to the exit of the home. a 50% blocked or crushed vent line will have a direct impact of the dry time.
How to check : disconect the dryer vent from the wall and ((((OPTIONAL--- put some old stocking -(( pantie hose )) on the end of the dryer vent to keep the lint and dust to a minimum.
run the dryer with a load of cloths and see if they dryed on time. If they did, then you have a cloged vent.
Jan 12, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer is hot, clothes arnt getting dry. blower? less that 1 year old Kenmore
Remove the vent hose from the dryer and dry a load of clothes . If they dry , then dryer is pushed too far back , kinking vent hose , or the vent from the dryer to the outside is blocked somewhere . A dryer either heats or doesn't heat (except for maytag associated dryers ) in which the blower wheel could be stripped out . But Kenmores don't have blower problems .
Aug 09, 2009 | Kenmore 600 7965 Dryer
Kenmore dryer 400series electric not gettin hot enough to dry
you might have a open heating element. ohm out your heating elements.
Feb 20, 2009 | Kenmore 62602 Electric Dryer
It takes a long time to dry a load of clothes
sounds as if you may have an issue with a blocked/clogged ventin, perhaps wher it leaves the home, a unit that is not able to expell the heat will tend to not dry the clothes properly, 2-3x to dry a good sign of venting issue
Jan 14, 2009 | Kenmore 98702 Stacked Washer/Dryer
New dryer, not drying clothes, vents cleaned, old dryer worked ok
repl/ thermistor and coils,,, remember these machines have moisture sensors,,,,,,,
Dec 30, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryer heats up but does not dry clothes
first take the venting off the back of the dryer and dry a load if dryes normal replace venting if takes a long time to dry have a repair man clean the dryer
Jun 12, 2008 | Kenmore 74602 Gas Dryer
Dryer won't dry
There are three possible parts that can cause this.
1. Thermal fuse
2. Thermostat
3. Flame sensor
You can check the first two with a meter to see if they are ok. If they are then you should replace the flame sensor.
Mar 25, 2017 | Dryers
Washing machine spin cycle
if a second spin dries the clothes as it should then i would be looking for blockages in the pipes that either go to the pump from the drum, or go from the pump to the outlet connector on the wall or sink, hope i have been of some help, if so please rate me, thank you
Oct 06, 2007 | Kenmore 22622 Top Load Washer
LG DLE5977 Electric Dryer Logo
161 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
