Question about Refrigerators
Westinghouse Fridge mode RP423 leaking water bootm right hand side of door
woodchuck789
  • 4070 Answers
SOURCE: the upside down fridge freezer has started leaking
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Posted on Oct 14, 2009
SOURCE: maytag fridge leaks under the
Check your defrost drain line it may be clogged
Posted on Jul 25, 2008
Sea Breeze
  • 4655 Answers
SOURCE: Westinghouse RP423 Freestyle fridge cooling failure
I am going to assume you are in the UK. the voltage is higher than most household refrigerators here in the USA. Disconnect power to refrigerator and check continuity on two of the three terminals of the compressor at a time until you measure the resistance in the windings all the way around. The terminals should be marked R, S and C. (Run, Start and Common) you should get a reading with your multimeter all the way around. When you have done this and have the readings I want you to touch one end of your multimeter to the metal pipes or any clean metal outside the compressor and the other to one of the three terminals one at a time like you tested before. With your multimeter set up the same, see if you get a reading from metal housing to the three pins, or terminals c, r and s. You should get no reading. If you do, the compressor is a burn out and on the first test if you don't get a reading on the two at a time test between two post that is considered to be open or broken windings. The compressor does have an internal overload that may be open also. But if cool at time of test, and it shows up the compressor in bad. Let me know what you find...Thanks, Sea Breeze
Posted on Apr 24, 2009
  • 323 Answers
SOURCE: Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Posted on Oct 24, 2009
allbrands
  • 600 Answers
SOURCE: westinghouse 522 fridge leaking oil
Hello, Thank You for using FixYa. I will be helping you today.The only thing that has oil is the sealed system. So if there is oil leaking you would have a leak and the unit will stop cooling.Are you sure something didnt just spill and is leaking out?
Thank You and please rate my answer if it was helpful..
Posted on Jun 10, 2011
Have purchased a westinghouse aurora double door fridge frezzer second hand in the middle off doors its very warm and the fridge side doesnt seem to be as cold as it should be. Frezzer side fine any...
There is a heating coil in those for defrosting purposes. You need to check and see if there is a defrost timer and see if it is stuck. Since you did not post the make and model number, that is as far as I can advise
Oct 27, 2017 | Westinghouse Refrigerators
Hi i have a Westinghouse side by side fridge freezer WSE6970SA there is no water at the dispenser . how do you remove the front panel from the water dispenser to remove it ?
https://www.bing.com/videos/search?q=replacing+water+switch+on+westinghouse+fridge+door&qpvt=replacing+water+switch+on+estinghouse+fridge+door&FORM=VDRE
Apr 19, 2017 | Westinghouse Refrigerators
How old is my fridge
most electrolux/ westinghouse products you can use the serial number to identify the production date ( eg: 345978 ) the first number represents the year( eg: 3 45978 )( 1993 or 2003 ) hope this helps
Apr 08, 2014 | Westinghouse Refrigerators
Kitchenaid kbfs25ewms2 freezer leaking water
Normally I would agree a water line is the issue however on this particular fridge this is not the case. If you open the freezer door, notice the placement of your hand. Unless it is dead center of the handle this is the cause of the problem and what I believe is a major design flaw. Depending if left or right handed, every time the door is opened the metal tracks that hold the door are being bent. If you remove the bottom freezer basket you will notice the back support bar that is attached to the metal rails is not longer straight.What ends up happening is, certain times when the door is pushed closed it seals completely and other times it does not. The times it does not, there is inch gap between the rubber seal on the door and the fridge itself(left or right side). The freezer warms up and items start to melt. As the cycle of freeze and thaw continues you end up with the entire basin full of ice. Eventually when the door does not shut properly and the ice melts it has nowhere to go expect your floor. This is why sometime you will have a pool of water and sometimes you won't but it always leak from a corner. Learned this first hand and ending up ruining 30sq of hardwood floor
Feb 02, 2012 | KitchenAid KBFS25EW (24.8 cu. ft.) French...
Refrigerator is leaking/dripping clear water, but the ice maker lines have no leaks and it appears to be coming for the middle of bottom of the box somewhere.
You may have a leak from the water supply line that is attached to the fridge from the house hold line near the bottom right corner of the fridge.
Jan 29, 2010 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Water in the bottom of the fridge this unit is 15 years old
the seals or door gaskets leaking will cause fuzzy ice to grow in freezer and water to collect in frige and run alot
Dec 27, 2009 | Westinghouse WWS833ES Super Capacity Top...
There is a slow leak coming out the front right hand side of the dishwasher. How do I stop this?
Check the door gasket on the right hand side. See if it is damaged or not aligned properly. You may need to replace the gasket.
Sep 13, 2009 | Westinghouse Dishwashers
Apr 23, 2009 | Refrigerators
Leak - water not evapourating
check your doors may be not clossing (ajar) or check control to high
Apr 02, 2009 | Westinghouse Refrigerators
Water leak
I am having the same problem. I do have a light layer of ice at the bootm of the freezer.
Apr 01, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
Refrigerators Logo
443 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
