I am way out ot warranty. My laptop will not hold power from the internal buffer cmos battery. Whenever turned on I always have to reset the bios clock. I have tried placing the unit on charge for days and hours but still no joy. I do not know where to locate the the internal batter within. Disassembly appears quite difficult. I have tried but can not get the case to open. Please advise how to solve this problem. Regards Ian
Hey man!I think I can help ya!I have an AMILO D 7830.I hope that yours is like mine. Turn the laptop upside down and then you'll see it's bottom!:P Alright now you can see two sides that can be unscrewed.The one that is to the opposite side of the cd drive is the one that can really be unscrewed.The other one has more screws that are covered.So,unscrew the side I said before and then you'll be seeing the battery the ram cards and some other stuff I don't know what they are.:P Now look closely to the opposite side of the battery and under the metal case.Somewhere there in the dark is your battery lying and waiting for you!I hope I 've helped you enough!
the cmos battery can be anywhere, under the lcd screen, under keyboard, in a plastic holder under motherboard, my advice is to take to qualified repairer, as you can end up damaging more than the price of a battery.
As run2thehills said when you turn the notebook over and remove the bottom cover and steel plate you will clearly see the cmos battery. It is about 18mm in diameter(Round Silver) remove that get the correctly rated replacement battery from your local electronics dealer/computer shop (PS Looks like a standard desktop cmos battery)and replace and voila!
Was this helpful?
Yes
No
Popular Solutions for Fujitsu Siemens AMILO D-7830
Whilst typing on screen the cursor drops to the bottom of the page at random - has anybody any idea...
(More)
Whilst typing on screen the cursor drops to the bottom of the page at random - has anybody any idea what the problem might be. It is totally random - and not connected to my touch pad!
On startup after the Fujitsu logo screen, I get the ami screen with the following message: CMOS...
(More)
On startup after the Fujitsu logo screen, I get the ami screen with the following message: CMOS settings wrong CMOS date/time incorrect Press F2 to run setup No keys work so pressing F2 does nothing. The laptop worked fine 2 days ago. I have renewed the internal battery but still get the same message. I cannot move pass this error screen Can you help? Thanks, BR Peter
audio molto basso, le casse esterne o cuffie non funzionano inoltre quando si inseriscono non...
(More)
audio molto basso, le casse esterne o cuffie non funzionano inoltre quando si inseriscono non disabilitano le casse interne
My new Fuj-Siemens Amilo laptop has a different cable socket to the earlier standard external...
(More)
My new Fuj-Siemens Amilo laptop has a different cable socket to the earlier standard external monitor and projector cable sockets! Is there a converter or special cable available and from where. What is its official description. I want to connect to a standard projector. The socket on the rear of the Amilo has a logo of an oval with an arrow and square bend sign!! Your advice would be appreciated.
