Question about Coleman Powermate Premium Plus 6250W Portable Generator
Motor runs but have no power coming out of outlets of mygenerator
The generator is a coleman powermate 5000 watt , model # pm0435001.Is there something Ican do?
  • 169 Answers
1 - Check the circuit breakers on the front of the panel where the outlets are located.
2 - Make sure the black molex plug on the back of the panel where the outlets are located is plugged in securely.
3 - Carefully take the plastic endbell off the generator ( you'll need a 7/16 inch wrench and socket) and look for broken or missing brushes, broken wires, etc.
4 - If you're not up for #3 take it to a good repair shop. :-)
Posted on Nov 29, 2008
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
I have a coleman powermate 6250-5000 running watts-generator. The generator starts and runs but does not produce current to outlets,the outlets are fine-they have continunity,I removrd the armature and...
You may have just lost residual magnetism in your rotor. Start genset then apply 12 vdc to 120 v outlet for less the 1 seconds. This will be enought to restore the residual magnetism to the rotor and the unit should be producing power now.
Nov 17, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Generator not Making Power
actually, it sounds like the diodes are blown. Check our diodes.
As for checking stator, find the two wires, typically labeled L1 and L2 that are going to it. Measure with a multimeter. If there is no visual signs of damage, continuity can indicate a good stator. You should not have continuity between either wire and the stator frame.
The same goes for the rotor as well. The resistance measurements will not be the same for each one though.
Unfortunately, Powermate is out of business, and service information is scarce.
Aug 16, 2009 | Coleman Powermate Powermate 5000W...
Coleman Powermate 5000 no electricity, runs fine
Hello;
Take a look at your outlets. Some of these units use pretty cheap outlets and short out. You will know if it is bad when you look at it. Hope this helps.
Thanks;
Rich
RPM Northwest
Jan 16, 2009 | Coleman Powermate Premium Plus 6250W...
Need to know about this generator. Coleman Powermate 6250 Gen power 305 5000 running watts Model PM0545008 Serial # E06601199B
To find a manual for this generator go to powermate.com and search your model and serial number. Good luck!
Dec 05, 2008 | Coleman Powermate Premium Plus 6250W...
Powermate 5000
20kw means 20 KILOwatts (kilo=1000), so 20kw=20,000 watts
So the Powermate 5000 refers to wattage. 5000=5kw
Sep 04, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
529 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Rivera
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
