Question about Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive
Corrupt portable drive
My wd 250 gig passport portable harddrive has several folders with subfolders and files that appear corrupt. Names changes to random characters and squares. No viruses were detected. Any ideas on the best way to get back the correct data? Also, a folder of mp3s has many songs jumbled together in a file. Some songs are shaky, play fast or are a mix of two or more songs. Any ideas how to fix them or get rid of the bad ones, without listening to all. (I have 1000's)
I don't think the below product id is correct.
  • 2 more comments
  • Tejas Shah Nov 28, 2008
    I have Western Digital WD1800 ME 160 GB external Hard disk. I also see lot of folders and files have got wierd names and I am not able to use them or delete them.
  • lotuni Dec 19, 2008
    yea, same here. I don't even want to restore the folders, I just want to delete them and clean that folder off.
  • TSellers2 Jan 10, 2009
    Same problem, second time it's happened. chkdsk just wipted them. Trying different programs to recover them now from the MiniPE Disk.
  • Anonymous Mar 06, 2009
    i can't access my portable hard drive. the mesage that comes up is, I is not accessible, the file or directory is courrpted and nureadable.
I had the same problem with my WD passport. Most of the folders displayed wierd characters and couldn't access those folders. Thanks to Zero Assumption Recovery software, I had successfully recovered all my files. Check this link on how it works:
http://www.z-a-recovery.com/unformat-tutorial.htm
If your hard drive is detected by your computer you can use this software for data recovery.
Thanks
Sid
Posted on Dec 21, 2008
My partner has managed to corrupt a number of folders on my WD Passport drive! Whereas the folders now appear to be files and the data (Excel files) are now no longer accessible
It's hard to say from your description what the problem is but the first thing to do is determine the condition of the drive. You can check if there are problems with the drive using the free trial version of http://www.hdtune.com/
If it checks out ok then you can try to recover your data with Recuva it's free http://www.piriform.com/recuva
Or if you need data recovery help this a good choice for low cost and fast data recovery. All data recovery work is performed remotely over the Internet from a boot cd that you download and the best part is they just ask for donations if you are happy with the results: http://FreeDataRecovery.us
Sep 19, 2011 | Western Digital WD Passport 250GB Portable...
Why wont my Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive work?
Several possibilities:
* bad USB port in your computer (try another USB port)
* messed-up copy of Windows (try connecting to a different computer)
* damaged USB cable between computer and the Passport (replace it)
* bad disk-drive inside the enclosure (replace it)
* bad USB-to-disk-drive adapter (buy a new "empty" enclosure)
Check the warranty on it, to see if W.D. will replace it, at minimal cost to you. If the warranty has expired, W.D. has a "Customer Loyalty" program -- buy a new Passport through their web-site, and you qualify for a discount on your purchase.
Oct 30, 2010 | Western Digital WD Passport 250GB Portable...
Accidentally removed WD My Passport for Mac without ejecting first. All files are still there, but I get an error when trying to open them. How can I fix this. TONS of stuff I can't lose...
click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
good luck with this
Sep 11, 2010 | Western Digital WD Passport 250GB Portable...
Watch movies and music off Wd harddrive conencted to PS3
If you want to hook up any kind of external HDD or flash drive via USB to your PS3, it needs to be formatted in FAT32.
Sep 29, 2017 | Western Digital WD Passport 250GB Portable...
How do I restore my files on my passport to my internal hard drive
Why not make it KISS (Keep it simple and stupid). Go to your my Passport folders or files that you want to copy, Click on it and Copy (ctrl c) or Cut it (ctrl x), now go to your internal drive (C:\ or D:\,etc) and do Paste (ctrl V. You can also copy or cut multiple files or folders.
Sep 03, 2009 | Western Digital WD Passport 250GB Portable...
Directory corrupted - unreadable.
try to run chkdsk (checkdisk) ---- chkdsk c: /f /r
also probably you need recovery software (easy recovery professional)
Jun 29, 2009 | Western Digital Passport 320GB External...
My WD portable 250 gb hard drive
Had similar issue with my WD passport , it turned out that it didn’t like my USB 2 ext lead, as i am unable to access my PC’S USB socket i was a bit stuck ...... i have now found that a low cost “POWERED” USB hub solved the issue .....good luck
Apr 22, 2009 | Western Digital WD Passport 250GB Portable...
Can't load a 13 gig avi file onto wd drive with 90 gigs free
Typically this is because there aren't large enough fragments to load. Run defrag several times and try again. You might also run the cleanup program and remove any temporary files, temporary internet files and anything in your waste basket before you run defrag.
Please let me know how this turns out.
Nov 23, 2008 | Western Digital Passport WDXML800UE...
Western Digital Passport WDXML800UE (WDXML800UETE) 80 GB Hard Drive Logo
781 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
