Sylvania SST4273 stuck on CC screen, unaffected by remote control
I have tried unplugging it and using every button on universal remote, nothing is working.
SOURCE: black box in the center of screen
If the tv is an LG with built in sky then the tv is faulty.
Poor connections on microprocessor
Posted on Jan 16, 2008
SOURCE: philips universal remote - tv codes for Sylvania
Only one code worked (out of the 13 codes provided for Sylvania TVs with my Philips Universal Remote) so I could program my Philips Universal Remote to operate my Sylvania 6413TC 13" TV: 0520
After manually turning on the TV:
1. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button.
2. Press and release the desired Mode button (in your case - TV). The red indicator blinks (very quickly), then stays lit.
3. Enter the 4-digit code (0520), and if it's valid, the red indicator should turn off. (Supposedly, for an invalid code, the red indicator flashes. However, when I tried all 13 codes, the red indicator turned off, yet only one code actually worked. Go figure.)
4. Press CHANNEL UP. If your TV responds, no further programming is required. Although, some buttons on your Universal Remote may not operate your TV. (They all worked for me, yeah!)
If 0520 does not work for you, here are all the codes provided by Philips: 0807, 0002, 0502, 0115, 0520, 0919, 0324, 0247, 0402, 0408, 0109, 0715, 0717.
Posted on Sep 08, 2008
SOURCE: Sylvania TV stuck in Game mode remote no longer works
just go to channel setup and add/delete channel, it should exit the game mode. then do nothing unti the add/delete option exits the bottom of the screen.
Posted on Sep 14, 2008
Opelmanz
  • 62 Answers
SOURCE: cannot get charter universal remote to work with tv
it is very hard to do. keep trying every code again in order until you get it. It's hard to enter so many codes without error, usually one of the codes is right.
Posted on Dec 09, 2008
Several people in the on-line forums suggested inputting the brand search codes for Philips and Magnavox sets -- but it didn't work for me. Someone else suggested that Funai Corp (China) now makes some Sylvania sets, and their rep said that universal remotes don't work for their products. My Philips Universal Remote says to enter "0" for the brand search code, and that will instruct it search for all the codes installed in it. But there are approximately 300, so be very patient. And it didn't work for me anyway. . . but maybe it will for you.
If you do find an answer/solution, pl post it, OK? Thanks.
Donna
Posted on Mar 29, 2009
Tv stuck in service mode
Unplug for several hours, press and hold power button for 5 seconds, wait half hour more, plug back in and try. Or press and hold either channel buttons at same time or volume buttons at the same time to see if that exits the mode.
Nov 18, 2009 | Sylvania SRT2232S 32" TV
Needed codes for RCA312W to control Sylvania tv sst 4273
code 1192 works using my rca model rcr4358 universal remote with my syvania sst4273 tv
Jul 19, 2009 | Televison & Video
Innovage jumbo remote locked up my sylvania tv
I suspect you have simply switched to an unused input. If you use the original remote you can probably switch the input readily back to what you want.
Dave
Jul 04, 2017 | Sylvania SRT2232S 32" TV
27" sylvania tv stuck on one channel
unplug tv for about half a hour and replug it back in to reset it and see if that works..I also have that big remote and it worked find for me the first time so maybe tv just needs to be reset. hope that helps
Apr 05, 2009 | Televison & Video
Hola
Hola,
Aca tenes un manual de tu tv:
http://www.sylvaniaconsumerelectronics.com/pdf/om/SST4273.pdf
La pantalla esa que te quedo fija debe desaparecer a los 10 sec si no apretas ninguna tecla.
Creo que antes de hacer nada con tu tv te recomiendo que seria bueno que te consigas el control remoto original de tu televisor.
aca tenes una opcion a 24 dolares ---->>>
http://www.funai.newremotecontrol.com/catalog_item.php?catnum=NE121UD
y aca el original por 34 dolares ---->>>
http://www.remotes.com/store/sylvania/sst4273.html
Seguramente con el remote original desbloqueas tu televisor.
Espero que soluciones tu problema pronto.
Dejame saber como te fue
This will fix your problem.
Please don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Oct 19, 2008 | Electrical Supplies
Can't turn subtitles off
I want to thank whomever suggested the following...it works. I had been trying for days. Here is the solution:
Turn off the cable box and hit the menu button on the universal remote. The screen with the closed caption selection appears. Scroll down to the line regarding subtitles and turn it off.
Jan 18, 2008 | Philips Magnavox 27MS343S 27" TV
Sylvania SST4272
I had the same problem with a Sylvania SRT2227S. I kept trying to fix it using the remote but after reading your posting I pressed the Volume (down) button, which cycled through the same menus you mentioned. Then I pressed the Power button on the TV and that fixed it.
The problem started for me when pressed PIP, CC, and Guide buttons on a Philips universal remote control. My TV does not support these functions and it seems to put it in this "service mode". Now I can fix it by pressing Volume (down) or Menu then the Power button on the TV (do not use the remote as it is useless when the TV is in this mode). I hope this works for you too.
Nov 25, 2007 | Sylvania 6419TC 19" TV
Televison & Video Logo
67 people viewed this question
Top Televison & Video Experts
