Question about HP Computers & Internet
Intermittent internal wireless modem. sometimes it works, other times it doesn't: even though I have my laptop in the same location in my house. This is an HP Pavilion dv2500 Notebook PC with Vista.
  • wb2bmh Nov 13, 2008
    We do have other wireless items (phone, hifi speakers). I'll share this info with my husband and see if he agrees that re-setting the router might be the solution.
    Thank you,
    wb2bmh
  • wb2bmh Dec 19, 2008
    Problem finally solved! It was so simple, it's embarrassing to relate. I called HP Customer Service AGAIN (1st time they couldn't solve the problem) and it turns out there is a teeny tiny switch on the front (left side) of the computer. Every time I handled or cleaned the computer (with an alcohol swab) I was inadvertently turning this switch on and off. For wireless to work, the switch has to be slid to the right (a blue light comes on). Even my husband, who used to build computers, never noticed this switch. Nor is the switch evident when I looked at any diagrams of the set up on the HP. Anyway, I really appreciate your help. I've been out of town and neglected to get back to you. My apology. This solution reminds me of the times I would call my Help Desk at work to say my computer wouldn't work and they'd ask, is it plugged in? Once it turned out that the night cleaning crew had indeed knocked the plug out from the wall! Thanks again. Love this site -- you were prompt and helpful.
    Scholar:
  • 69 Answers
There are many reasons that the signal can vary from place to place and can change drastically just inches away.
a few sources for interference are:
  • cordless phones
  • baby monitors
  • basically anything wireless
You see some of the above work at 2.4 ghz frequency and can block and distort data coming from your router to your pc.Luckily there are quick fixes that sometimes work for instance:
  • setting your router to another channel:
You can do this by going into your routers wireless settings and changing the transmit channel from say 1 to 2 and so on and try that for a bit.
How do I get to the router settings you ask? Good question, well its pretty simple but it varies greatly from router to router so you will have to look in your manual that you threw away when you bought it :) or just check on the internet and search for "(make and model) settings" at the product website.
if you'd rather provide the make and model here id be happy to search for you and find out how you can configure your router.
That said my main suggestion is to get an Ethernet wire to that stationary pc, it will surf a whole lot faster unless the wires are a pain. Most home wireless speeds pale in comparison to hooking directly up to that same network.
Posted on Nov 13, 2008
  • Stellyx
    Stellyx Nov 13, 2008
    If it works or doesnt work feel free to come back and comment as to what you did then i can help you further.. good luck
Why doesn,t my computer connect with my modem & doesnt even connect though a wired conection ???wifi says no nework in range??? when the modemis right beside it???
If you have a laptop check all sides to see if there is a switch to turn it on, if not look at the keyboard and see if there is a wireless icon on any of the keys .If found Press the FN key and the wireless key to turn on.
Oct 03, 2014 | IBM ThinkPad Computers & Internet
Acer aspire wireless problem fix
Have you done all your Laptops updates, windows updates? Are you moving the laptop about the house and losing a signal? Is the laptop static and losing the signal? Many thing will interfere with a radio signal(wireless) Is the wireless Secured? Have you tried other channels?
Dec 30, 2012 | Computers & Internet
I am not able to connect through internal wifi(wireless) network device in my Toshiba Satellite L505D Laptop. I am able to connect net through a external USB wireless network adapter.What is the problem...
Locate the wireless switch and turn it on? if it is on you might need to reset the modem from your service provider. Just go and hit the reset button on the modem or turn it off completely. Power it up again and make sure that the switch is turned on if you have one for this lap top some are automatic.
The switch is usually located on the left or right front of the lap top housing in the front or on the keypad. You may have to push the FN key if the key is blue highlighted. Hit FN and press the wireless key if applicable. Make sure all is on and switched then reset the wireless modem or connection.
Jan 28, 2011 | Toshiba Satellite L505DGS6000 Notebook
I have a wireless modem for a PC and laptop, but because i do not have a telephone jack where my PC is i am using a d-link wireless adapter. The distance from my PC and the modem is about 20-25 feet. For...
The wireless card in the PC may not be as good as the one in laptop or the signal strength is weaker where the PC is located.
Try moving the D-Link around or in a higher location to improve the signal strength.
The PC may be near a source of interference such as a microwave oven.
Oct 13, 2010 | D-Link AirPlus G DWL-G122 802.11g/b...
Keep losing the wireless signal on my laptop.Checked the Router everything is fine,the laptop has a built in reader.stops working even if it is next to the Router,and sometimes goes altogther.
1. Disable or remove Norton Security (usually the problem with intermittent wireless).
If that doesn't work:
2. Disable any wireless TV transmitters you have in your house. 3. Turn off all PCs, then restart the router. Wait until all the lights have stopped blinking, then start up the PC(s).
Aug 29, 2010 | Acer Aspire 5100 Notebook
My 2wire modem keeps on shutting down on its own.
Replace it since its operation is intermittent and sooner or later it will quit for good.
Sep 05, 2017 | 2wire 2700HG-B Router (2700HGB)
I have a Dell XPS 1330 laptop and a DI-524 wireless router.
Unsure what your problem is exactly but here is something to try. Power off all computers, modem and router. Power up the modem first, and wait until it is completely up before proceeding. Next power up the router and wait until it is completely up, the only light that probably wont be lit is the LAN light. Then power up each computer, they can all be powered on at the same time, that part really doesnt matter. See if that fixes the problem.
Aug 11, 2009 | D-Link AirPlus DI-524 Wireless Router
Low signal(wireless MAXg ADSL Gateway USR9108)
1.TRY siting in a place wth less people ... actually wth my USR9108 i get disconnected even if some one is standing infrront of the modem so stay in a open place wth less people.
2.RESET your modem 3 tymes and configure ur modem by the settings given from the Telecom company.
3.Check ur modem antennae ... bcoz its modem is very FRAGILE... it sometimes have an internal wire break ,,,,
TRY installing ur BRothers antannae on ur modem nd den use it....
ALI KAZMI
May 01, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
Wireless Connection limited range and intermittent
1. Access the router's setup page then go to wireless tab and change the current wireless channel to a different one.
2. You may also upgrade the firmware of your router.
Nov 08, 2008 | Linksys WRT300N Wireless Router
Wireless
The weak signal is due to either physical barriers - walls etc, distance from transmitter (router) or interferance (other netowoks broadcasting) You may be able to improve things by
  1. raising the router up higher
  2. move to a more centeral location in house
  3. changing the supplied antenna for a high gain antenna
  4. placing an "external" antenna on the router EG ensure it physically connects to your router though before buying - check you router manual for the correct connector type. Also some routers donot have detachable antennas
  5. change channel that wireless router operates on
The one that will not connect what OS are you running?
what have you tried so far
Post back and I'll try to assist you further
Jul 05, 2008 | Computers & Internet
Computers & Internet Logo
47 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
