Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Oven Temperature NOT Accurate
The oven temperature is not accurate: - Set Oven for 400. The Preheated Alarm goes off and it may only be around 160. - Should I replace the thermostat? If so, how? Thanks!
3 Suggested Answers
SOURCE: oven temperature not accyrate
bad thermostat
Posted on Jun 23, 2008
  • 706 Answers
SOURCE: How do you tell if the oven is preheated to the correct temperature?
Follow this link to the online user manual, it describes the operation of this stove
This should provide you with all the information you need to properly operate this model range,.. Hope this helps you.
Posted on Sep 01, 2008
SOURCE: I would like to know how to change the oven temperature
in nid ip 1000
Posted on May 03, 2009
0 characters
1 Points
Broiler element will not turn off at required oven temperature
My name is Peter. I am a retired field service appliance technician.
You did not provide the model number of your oven, which is located on a metal plate on the upper face of your oven after you open the door.
First, unless you have the latest Accurate model, your oven temp will rise 20-40 degrees F. above the set temperature, then turn off until it reaches 20-40 degrees below the set temperature.
Chances are you have a bad infinite switch and not a bad oven thermostat.
That is all I can tell you until you give me a model number.
Mar 17, 2015 | Kitchen Ranges
Thermador dual fuel oven temperature not accurate and the dials dont match temperature
Faulty thermostat it's the thin copper shaft in the oven that has a skinny tube running from it if you remove the oven knob you will find it goes back to the switch. Needs replacing.
Apr 21, 2014 | Thermador P304CS Gas Kitchen Range
The temperature in my oven is not accurate.... If I set it for 350, it pre-heats and then buzzes [to let me know it's reached temp]....but the temperature is NOT 350; rather, it is at 275 [I have a...
Your oven's manual should tell you how to adjust this. The manual should also have a trubleshooting chart. Also remember, your temperature sensor may be going bad and will need to be replaced. For now, you can set the temperature 75 degrees higher to get the correct temperature you need.
Sep 15, 2011 | Whirlpool Electric Range
Oven temperature is off - when set to 400 it heats up to 450. Do I need to replace the thermostat?
Possibly, but the sensors can be of a couple of different types and one type, a thermistor, isn't very accurate so there may be an adjustment for it.
Dec 01, 2010 | Frigidaire FEF366 Electric Kitchen Range
Tappan Oven #MEF500PBWD heating unevenly
Perhaps the item you are using to check temperatures is not accurate. I my line of work, I use a digital thermometer which records immediate temperature. Perhaps understanding the process will help you see more accuracy in the way you read the temperature in your oven. Allow me to offer this explanation....First of all, place your thermometer near on the top rack as close to the oven temperature probe as possible. This probe is the focal point for your oven and detects the temperature and opens the electrical circuit to turn off the element when the desired set temperature is attained. Set your electric oven to 300 degrees and hopefully, you have a window in your oven to watch. The bake element will come on and the temperature will rise until it reaches 300 degrees. It is at this point when your oven bake indicator light should go out. When this happens....look inside. The element is still bright orange and emitting heat and will continue to raise the temperature in the oven to approximately 325 - 340 degrees. With this noted, you will see the temperature beginning to drop 315, 310, 300, 295, 290, 285 perhaps even 280 or some even lower to 275 and then the indicator lamp will go on indicating the circuit has closed thus turning on the element, Finally there is a variance and no range GAS or ELECTRIC will ever maintain a even 300 degree temperature. The calibration set point is based on the 300 degrees. If your oven light goes off within 20-25 degrees of three hundred degrees, your oven is already calibrated pretty close and I would not attempt to adjust it at all.
Feb 16, 2009 | Tappan TEF242 Electric Kitchen Range
Uneven Temp in Ovens after Self Cleaning
in the users manual there will be a calibrating page. also self clean is hard on the oven a sensor that is meant to read 400 degrees has a hard time being accurate after 900 degrees
Dec 13, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kenmore gas oven temp not accurate. Could be high, can be low.
the oven themperature needs to be calibrated, the set screw it's in side of the oven knob when you remove it in the senter of the shaft there is a very small screw, turn it , beon that replace the thermostat.
Dec 06, 2008 | Kitchen Ranges
Ge stove
Replace the temperature sensor inside the oven cavity. It looks like a small metal rod. Be aware you will never get an accurate temperature reading with those cheap 5 dollar things. After the oven is preheated, you must wait 10 minutes and take a reading. Some models have a temperature adjustment, it's listed in the owners manual.
Oct 28, 2008 | GE JBP69 Electric Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
90 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Barrett Palumbo
Barrett Palumbo
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
