Question about Ricoh Aficio IS420 Flatbed Scanner
Ricoh IS420 has 4 flashing lights
I bought this scanner on Ebay to scan newspaper pages. When I hooked it up, everything worked fine for the first scan. I then moved it to a more convenient position. When I scanned the next several pages, there was a large darkened area at the "top" of the scan. Then, I scanned a page and it was almost completely faded out. Now, it won't scan at all and the 4 lights (2 for ADF and 2 for scanner) just blink--even when I have totally disconnected the SCSI cable. I've tried the reset button and it didn't work.
  • 1 more comment
  • mikesdaddy1 Nov 13, 2008
    Still no help. Reset didn't work. Reloaded and re-connected everything. All four lights are flashing. My manual says that it is s system problem. Worked the other day when I first got it. Help!
    I found the problem. One corner of the ADF was a tiny bit open.
    Sergeant:
    Champion:
  • 283 Answers
1.uninstall and reinstall the scanner driver
2.shutdown desktop and your scanner then turn on it back
3.unplug all its cable then plug it back
If nothing change, try to go ebay service center.
Thanks for using fixya. please dont rate me if you are not satisfied.tnx
Posted on Nov 13, 2008
    Genius:
  • 2,035 Answers
Open the scanner unit ..Lock lever of scanner unit is locked.Ricoh IS420 has 4 flashing lights - f812120.jpg
Unlock the lock lever of scanner unit.
Good luck...
    President:
  • 1,952 Answers
Common problem like bulbs and replacement holders and power problem
  • 1 more comment
  • mohammed marika thambi
    mohammed marika thambi Nov 13, 2008
    tried to unistall and reinstall and unpluged then pluged
    Put your printer on a switched cord, then turn the switch off when you're not using the printer.
    it detect anything at boot while the card is searching for devices? you
    might have bent a pin on the connector, make sure its terminated
    properly and the id number isnt the same as the cards.
    Genius:
  • 1,847 Answers
Try reset the scanner and then try.
  • Legin Varghese
    Legin Varghese Nov 13, 2008
    try the following:
    unplug the all the cables and replug.
    reinstall the drivers and software.
    hope this will do some good.. do let me know the status ...thanks...kevin
How do I scan small documents with custom sizes with Ricoh 3025 Africo scanner
Look at page 107 of the user guide
http://support.ricoh.com/bb_v1oi/pub_e/oi/0001027/0001027657/VB7678707/B7678707.pdf
Dec 23, 2014 | Ricoh Office Equipment & Supplies
I have a ricoh 1515 and can not get scan to file to work
You need to tell the machine it has a delivery server, this can be done by selecting user tools/system settings/file transfer/delivery option/On. After doing this you may have to remove and readd the I/O device from within scanrouter.
Oct 18, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
How to scan in text formate in ricoh2030
You need an OCR (Optical Character Recognition) program such as Textbridge or Omnipage ect. The program should use your scanner to scan and then read the page(s) and save as text.
Jun 11, 2009 | Ricoh Aficio IS420 Flatbed Scanner
MY RICOH 2020D PRINTER, IS VERY SLOW AND IT DOES NOT SCANNED AT 20PPM, PLUS THE FAX MEMORY ONLY HOLDS UP 40 PAGES, WHAT CAN I DO?
You must have your resolutions set much higher than the default.
Scanner: Go to "user tools", "Scanner features", "scan Settings", "default Scan settings", "resolution".....set to 200dpi
Fax: Resolution may be set to "detail" or "fine" by default , rather than "Standard" ...is either light lit?
This would dramatically reduce memory capacity.
To set this to default standard resolution is a needlessly difficult task. You can either manually turn it off when sending a fax or change the default "user parameter settings" for the "home position". You can find instructions in the Fax manual (Advanced settings). Download here:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/x2016_20/x2016_20en.htm
How to set parameters and understand them (sort of ) is on page 80
How to set home position is on page 86
Mar 09, 2009 | Ricoh Office Equipment & Supplies
Dark area on scanner output
you need a new CIS array, or the lamp is going bad. With all due respect buying office equipment on ebay is like shooting craps.
http://www.websitetoolbox.com/mb/copierquestions
Nov 13, 2008 | Ricoh Aficio IS420 Flatbed Scanner
Only scans one page ata a time it says it can't recognize paper for ADF
The bulb has nothing to do with the paper feeder.
Open the door and ther has three or to tires or rubbers so clean them with glass cleaner or 98% alcohol if after that dose not feed again you should replace the feed rubbers
Aug 23, 2008 | Ricoh IS450DE Flatbed Scanner
Will not scan
Release the lock underneath the scanner. Had the same "problem".
Dec 07, 2007 | Canon CanoScan 4400f MultiFunction Color...
Can't scan to e-mail multiple page
may be the scanned pages are going tiff format.select multi page pdf in the scan settings of aficio 3025
Aug 14, 2007 | Ricoh Aficio 3025 All-In-One Laser Printer
Ricoh IS420 is not evenly scanning text pages - light side edges not do to obvious cleaning, what next? If I switch to custom resolution and manually adjust contrast, can get text but also blackens edges....
Dear David, I bought a second hand IS420 on ebay, and bought a service manual at: www.electronicsrepair.net/scan.shtml See #86 You can buy it for $10. Good luck, Brad
Aug 03, 2006 | Ricoh Aficio IS420 Flatbed Scanner
Ricoh Aficio IS420 Flatbed Scanner Logo
131 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Bernard D'Souza
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
