Question about E-Machines M2105 Notebook
Restore CD Hi I want to give my old laptop to my kid, and I back up all files and want to restore drive C: on emachines M2105 PC notebook. I went to the first disk and it asked if is OK to delete drive C: after that it said to click any key to reboot. it turn on again but it only shows a black screen and a blinking line. It does not move from there. I choose to start from CD and prompt, it takes me to Drive A:\ I type copy *.* C:\ and it said is a bad command. What I'm suppose to do to restore?
Says windows root>\system32\hal.dll. is missing or corrupt, can't use laptop Please advise, regards Jason
some system on your windows has corrupted, it caused by a virus or bad disk
you need to restore your system to fix this issue
if your laptop build in windows xp and you have a restore disk just follow these steps
1. turn on your notebook
2.quickly press ctr and f11 simultaneously
3. click restore when "Dell PC restore" message appears
4.click confirm (it means you will lost all data in drive which contains your old operation system)
5.wait and click finish when the process of restore finish
if your laptop build in windows vista you can follow these steps
1. turn on your laptop
2. quickly press f8
3. when "Advance Boot Menu" message appears just click repair
4. select language and click next
5. log in and click ok
6. click dell factory restore and click next
7. click yes on the box "format hard drive and restore the system"
8. when the process finish click finish
if you don't have a restore disk build in your laptop you need a windows cd installer to reinstall your os
Jun 06, 2011 | Dell Inspiron 6000 Notebook
How do i reboot my laptop back to factory settings
To reboot to factory setting you need to have the restore disk from the computer, put it in the drive and restart with the cd in the drive, if the startup screen does not start right away you need to type f11 or f6 to change startup order to cd first the the restore screen will startup and click restore factory settings
Jun 04, 2010 | eMachines eMD620-5133 Notebook
How can I get a restore disk for the M2105 E-Machine Laptop
melvint9
The link below is to the site that you can order a replacement recovery CD from for your eMachine.
https://secure.tx.acer.com/RCDB/Main.aspx?brand=emachines
Issken
Jan 15, 2010 | E-Machines M2105 Notebook
On my emachines m2105, the cd/dvd drive no longer reads or recognizes there is a disc in the tray. We have done all the updates necessary and its still not working. We bought an external hard drive to use...
if you have the techie to dissassemble the cd/dvd drive, unplug and reconnect the cables connected to the dvd. or the cmos setup is disable for these drives.
Jul 06, 2009 | E-Machines M2105 Notebook
Hi, Can I take the restore discs for my old emachines m2105 laptop and use them in my current gateway (formally emachines) NX570X laptop. My husband does NOT want vista for his operating system and wants...
no you cant that restore disc has all the bios and drivers for the computer they came with if you do it will mess up the pc and nothing will operate right
Emachine laptop D620: reset password after system restored
Insert OS cd in drive and start reinstalling by selecting repair mode now once all files are loaded system will reboot when you see the Installing Devices progress bar, press SHIFT + F10
this will give you access to your account also you can reset all passwords
Now restart lappy and let the system boot normally without OS cd in drive
now you will come to old screen and previously configured desktop with all intact aplication and icons on desktop and it will no more ask you for password till you set a new one
Thanks and regards
Kindly rate this solution
May 08, 2009 | eMachines M6811 Notebook
Emachines t5212 system restore backup files, please help!!
If you only your files to be copied in the other or any storage disk then you can remove the hard disk of your machine and then attached it to the other functional machine. in there you can browse and copy all the important files. after copying all your files then you can take back the hard drive to your non functional machine and then install new operating system. documentation found here: http://support.microsoft.com/kb/316941
tell me if something wrong with your system when applying the solution.
melnavz
Feb 05, 2009 | E-Machines eMachines Desktop PC
Emachines M2105 laptop wont reboot from restore discs
Using cd resident OS (Knoppix) check driver for consistency
Jan 04, 2009 | E-Machines M2105 Notebook
Help
This means that the system is assuming you are doing a complete system restore to it's original set and condition. For this it will need to know where the restore backup files are kept for it to restore, this may be on a partition of your hard drive or on a backup disc that was supplied with the notebook, unless you were prompted to make a backup disc when youfirst booted up the notebook.
Mar 11, 2007 | E-Machines M2105 Notebook
E-Machines M2105 Notebook Logo
61 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
