Question about GE Dryers
Makes growling noise when first started, quits once warm.
When you first push the bottom button to start the GE front loader dry that is some 7 or 8 years old it makes a growling noise for a second or two then stops, runs and drys fine but next time you go to start it when its cold it does the same thing. Have looked at the drum belt and it appears ok.
    Genius:
  • 1,028 Answers
Suspect noise from motor repair cost may exceed value but may want to ck rear drum bearing also this will mean pulling tub out bearing is on rear drum shaft not a hard fix but will need some mechanical know how ..good luck
Posted on Nov 13, 2008
When started, dishwasher making growling (hungry stomach) noise before filling with water
That would be your pump priming, however I would check the sump or filter in the bottom sometimes they get debris caught in them. Some have a filter others have a screen.
Jan 07, 2015 | Dishwashers
Why will my dryer not start, but makes a clicking sound?
If the motor runs and the drum doesn't turn the belt may be worn or broken...or you may have a faulty idler
Regards,
Dennis
Aug 15, 2014 | GE Dryers
I have a ge profile refrigerator and it works fen except it ekes buzzing. The ice lock/lock function, no body is pressing the button but it keeps locking and unlocking itself and the buzzing/beeping i
The switch that does the lock/unlock has got wet inside.
Make sure you can see the back panel of the switch and use a hair dryer to warm the panel back and the front of the switch. When it gets warmer it may dry out and start working normally.
Dec 21, 2013 | GE Refrigerators
My '06 Honda Odyssey has gotten noisy recently.
If it is filled up to the "full hot" mark then you are okay, fluid wise. It almost sounds like once it gets warmed up, it starts running better. The "growling" noise (especially when turning) could be from it not getting enough fluid. Other than that, your power steering pump maybe on its last legs, and it is taking time to warm up before it starts pumping fluid correctly. Just make sure that you power steering resevoir is completely filled to the proper mark.
Aug 10, 2013 | Cars & Trucks
Dryer won't start. Press the start button and it just makes a buzzing noise.
Is it growling at you? That is a sign of dry bearings. You can sometimes bring em back with a little lubrication. I wrote about it and posted some photos Here
Aug 17, 2011 | Dryers
My Kenmore Elite front loader HE3 washer will not start.
The door lock is not telling the control the door is locked. Faulty door switch or failed control or loose wire.Try pushing in on the door while it tries to start. Advanced trouble shooting may be required.
Eric
Jun 20, 2009 | Kenmore Elite 45986 Front Load Washer
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
Kenmore dryer hums but will not start
If it just hums the motor is probably on it's way out. If it makes a growling noise, it's the motor.
Nov 04, 2007 | Dryers
GE Washer WPSQ4160T
TRY REMOVING FRONT OF WASHER YOU WILL SEE 4 SHOCK LIKE PISTONS TAY GET DRY AND MAKE GRINDING NOISE OR SQUEEKS LUBERCATE ALL REAR HARD TO GET AT MAKE SURE YOU GET TOP AND BOTTOM (RAY)
Dec 07, 2006 | GE WBSE2090A Top Load Washer
Dryers Logo
167 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
