Question about Paolo Gucci PG873WU Wrist Watch
Aunthenticity I would like to know how I can find out if my watch is authentic,are there certain markings,signs? The bracelet has made in China which has made me suspicious or this common?
0 characters
1 Points
most likely when you see this but the only real way of knowing is to get the back removed
Apr 17, 2014 | Cartier Roadster Mens X-Large GMT Watch...
Is my ARMANI AR1410 authentic
You really have to have somebody look at it. Some of us can just take the watch from your hand and tell its fake from the feel. Some knockoffs are much more convincing. Serial number could be inside the watch too. I opened a "Swiss made" watch once, and on the inside the actual watch movement said "made in China". They had used the case for the real thing but put an el cheapo movement inside!
Mar 31, 2014 | Emporio Armani AR1410 Mens Ceramica Rose...
Need to replace my leather watch band on my goofy watch with an authentic disney band. it is leather with no characters on the band & underside is stamped with disney made in china. Need size &...
If you need an authentic Disney watch band, try asking at a Disney store. However, non-Disney watch bands will fit this watch and may be both better quality and less expensive. Almost any jewelry store, department/discount store jewelry counter, or shopping mall watch kiosk will be able to measure your watch and determine the right size band. Many women's watches in this general style use a 14mm or 16mm band, but you should measure your watch to make certain.
May 05, 2011 | Disney Goofy Brown Leather Strap #D075S007...
How do you remove a link off the Casio Men's Edifice 10-Year-Battery Analog Bracelet Watch #EF106D-2AV?
Have a look at the links nearest the clasp.
These should have markings on to say which are removable. An arrow or some other indication.
Not sure if this watch has press pins that go through the whole bracelet or flip up catches on each band.
Please dont forget to vote this answer was helpful.
Many thanks
Mar 01, 2011 | Casio Edifice 10YearBattery Bracelet...
Adjust the band on my merona watch
at the back side of bracelet you can find direction mark, use fine and strong pin with tiny hammer to remove pin out. if there no mark , just look at both side of bracelet, thru narrow hole push your pin, then fastening pin come out thru wider hole
Feb 23, 2010 | Bulova Watch
You better prepare a plain cloth to avoid scratch a piece of jewelry screw and ponson pinch ,if you cannot secure a ponson, find a big needle or sharp nail,take your watch put a piece of cloth to protect from scratch,hold your watch firmly that cannot slipt.In the side of links,there is a screw marks, or pinch marks lock,if you see screw marks you should use the screw ,if pinch mark ,use the needle or the nail to punch out the lock and detach it ..Again punch it in so it locks or screw it in.That s all you do patswan...
hope this may help;
Jul 24, 2008 | Watches
Is my watch authentic?
no need for serial number- look on the dial, if the 'x' marking the ten o'clock has 'cartier' written on it, your watch should most definately be authentic.
Jun 13, 2008 | Cartier Tank Francaise W51001Q3 Wrist...
Paolo Gucci PG873WU Wrist Watch Logo
Top Paolo Gucci Watches Experts
Arturs Kalnins
Arturs Kalnins
ray gallant
Walking Bear
Level 1 Expert
Are you a Paolo Gucci Watch Expert? Answer questions, earn points and help others
