Question about LG 42LC2D 42 in. LCD HDTV
Tv no picture
MY Lg tvplasma has sound no picture i just heard a loud sound from the tv and the picture went what cause this
  • 139 Answers
Have you checked the input on the tv yet? maybe someone changed the tv input using the video source key on the remote. Also check all the connections from the tv to your equipment like the cable from the cable box or wall. If the connections are good call a repair man. Its just something that happens, maybe a power surge. Call firedog
Posted on Nov 13, 2008
To begin with I have Dish network my TV went off and since then in order to have picture and sound i have hookup HDMI cable and also video cable to have picture and sound
You need to set up the dish box for the correct resolution ie 720/1080 etc.
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Jan 05, 2017 | DISH Network Televison & Video
I keep getting " No Signal" with any input selection on the tv remote.
What are you connecting to tv have you got something that works on another tv in the house so you sure your source is reliable.
Nov 30, 2014 | Televison & Video
How do I determine if it a power failure or if it is a faulty SC board (TNPA5335)?
That does nost sound normal. I would take a look at the output of the power supply. Look at your electrolytic capacitors on the power supply board. Do they look like the top of them has popped up? If so you can get replacement capacitor kits from www.lcdalternatives.com
Jul 09, 2014 | Televison & Video
Troubleshooting tv
you need to buy tv converter box,
Jun 16, 2014 | Televison & Video
How can I fix blue dots on my Sony TV screen?
Seems like a problem with a lot of Sony TV's. Wish i could be of more help, but check this site. Your not alone! Sony LCD Rear Projection TV Problems hope this helps!
May 23, 2014 | Televison & Video
Do a 2001 GE projection tv have a lamp in it?
Yes course there is a lamp . You can order one from ebay for around $10 .
Apr 21, 2014 | Televison & Video
LG24LN451B
can't turn the tv on.
Mar 12, 2014 | Televison & Video
How could I connect a Daewoo 42sm TV?, I can't afford cable so I use a converter box(analog to digital w/rabbit antenna)on my other TV and I was given this Daewoo TV and would like to watch it;please
If your converter box only has RF outpit connectors "F" type screw on it looks like this my be more of a monitor then tv.I took a quick look at the manual and didn't see any RF inputs so it appears it doesn't have tuners built in Looks like you'll need a box that has RCA output connectors.or others that will match what the monitor has on it for input types
Mar 06, 2014 | Televison & Video
Would like to know the codes for a LG tv, Sony tv, and a TOSHIBA DVD ?
How to Program
Remotes With SET Button
1. Choose and press a device key i.e TV. LED will flash once.
2. Press "SET" Hold until the LED Lights up.
3. Enter the 4-digit Device code (refer code list).
4. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
5. Important - Some brands use other manufacturers to make their devices if the codes available do not work the try the MAGIC search function.
Remotes Without SET Button
2. Press and hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. The LED will flash once as each number is programmed, at the end of the 4th digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process. If the first code does not work then repeat the process with the next.
MAGIC SEARCH FUNCTION
1. The magic search function enables you to scroll through the entire code list one by one by pushing the on/off button. Each time you push the on/off button the remote automatically switches to the next code in the list and sends a signal to the device you have chosen.
2. Choose and press a device key i.e TV. LED will flash once.
3. Press and hold the SET button or if no SET button then hold BOTH the CHANNEL UP AND VOLUME DOWN button until the LED Lights up.
4. Enter the 4-digit Device code (refer MAGIC list) i.e TV is 0001.
5. The LED will flash once as each number is programmed at the end of the 4 digit the LED will turn off immediately if correct. If the LED flashes then something went wrong in the process.
6. Start scrolling by pushing the ON/OFF button as soon as your TV or Chosen device turns OFF lock the code in by pushing the DEVICE key again.
Mar 27, 2013 | Televison & Video
Need instructions to add TV button to AKB36157102
1. While pressing and holding down the TV POWER button, press the CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on (or turned off if you had it on). 2. Release TV POWER button when the TV turns on or off. The remote's TV POWER button will now control the TV.
Jul 19, 2009 | Televison & Video
LG 42LC2D 42 in. LCD HDTV Logo
97 people viewed this question
