Question about Panasonic Televison & Video
I'm after a diagram for the back of a TH-42PA20
  • thiele Nov 13, 2008
    Thanks for that, I've moved into a new place and they left the wall mounted plamsa. I'm trying the sorted out the connections without removing it from the brackets. They all however appear to be RGB's and no Scart, no you know if they made it like that or do you think there is some sort of adaptor being used??
    Yea they definitly look like RGB cable three cable pre set. I'm at work atm so I will have a closer look when I get home now I know what it's meant to look like...I will let you know how I go. Thanks for you help
  • 44 Answers
Not much to it, whacha trying to do? Component (RGB) and some Scart connectors. Let me know if I can help?
Posted on Nov 13, 2008
  • Cyweb Nov 13, 2008
    Sounds like some adapted configuration. Are they definitely RGB ? 3 cables per set? What do you have for audio connections - BNC? (2 cables in a pair) How many cables in total come out of the back of your set?
I need the pairing code for Panasonic flat screen TV model TH-42PA20 please and thank you.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
May 29, 2016 | Panasonic Televison & Video
Panasonic TH-42PA20 blinks 12 times
12 blinks Sound SOS H Board. Check and replace its audio output card. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also ckick the [Home] tab to the latest updates. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Nov 26, 2012 | Televison & Video
I have a Panasonic th-42pa20 will not turn on. Red light flashes 7 times. What's the problem. Thanks
Check this site for more details. Blinking codes for Panasonic brand TVs are described in detail there. It is not possible to give you such illustrations and details by this window. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1250 posts to different brand TVs now. Pull up older posts there.
Nov 21, 2012 | Televison & Video
Th magna wiring diagram
We do not have diagrams for this model. USA only, Sorry.
Aug 06, 2012 | 1999 Mitsubishi Galant
I need the deck belt routing diagram for my John Deere 185 42" deck.
I fiound some beautiful pictures in a manual for the 48" mower deck by John Deere. I haven't
found the 42" diagrams yet, but I can TELL you how it goes on (or is supposed to). Loosen the sheaves (pulleys) and belt guides. The inside of beltl go on back side of each of th 2 blade pulleys. On the discharge side it will come around to the back side of smaller pulley. On left side it will come to back side of the foward pulley. Then it will go around the jacksheave on the engine shaft. Just remember, th notched side or inside of belt will always go to the v side of pulley and the back side or flat side of belt will go to the flat pulleys. Good luck
Jun 18, 2011 | Garden
It's at top dead centre on th crank the cam pully marks at top of head and inlet valve just on opening th dizzy pully marks are lined up with the crank locator when you look from th marks and have taken...
You have the wrong valve openong. To time an engine properly the Exhaust valve opens when you go past TDC, n ot the intake. The intake should be closing as you come up on TDC. Just pull the dizzy back out and give the engine one complete turn and put it back in. Hope this helps.
Jan 26, 2011 | Ford Futura Cars & Trucks
I need the belt routing diagram for a John Deere 160 lawn tractor.
Loosen the sheaves (pulleys) and belt guides. The inside of belt will go on back side of each of th 2 blade pulleys. On the discharge side it will come around to the back side of smaller pulley. On left side it will come to back side of the foward pulley. Then it will go around the jacksheave on the engine shaft. Just remember, th notched side or inside of belt will always go to the v side of pulley and the back side or flat side of belt will go to the flat pulleys.
Jul 07, 2009 | Garden
Panasonic th-42pa20 plasma 42 inch tv
Try to replace the Main Power Supply board first.
Dec 29, 2007 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Televison & Video Logo
48 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
