Question about Samsung SCX 4521F All-In-One Laser Printer
SAmsung printer SCX-4521F
Paper jam when printing. The first sheet only goes approx one quarter of the way then get jammed.. Would it be possible for you to suggest some troubleshooting tips
  • sklazinga Nov 14, 2008
    I have the same problem. It is not acctually a paper jam, although the printer treats it as one. The paper is not getting picked up by the next roller and stays in the paper tray. Simply putting a finger on the not-accepted paper and pulling back causes the page to return to it's starting position. This happens on nearly every page I print. I have to pull the paper back, then open and close the front of the printer to get it to resume (and probably not take the page again). Repeated occurances can leave some black marks on the top edge of the page in question, and the incessant beeping of this machine is maddening (a strip of duct tape over the speaker hole on the left of the machine makes it considerably quieter, and has lowered my bp). This printer is not worth the buy and should be taken off the shelves. The only reason I use it is because I do not have one of my own, and it is what was donated to the service organization I am a part of, and I do all of our printing.
  • branrotwig Apr 09, 2009
    re, paper jam when printing,first and every sheet goes aprox quarter way in
    i have same problem with paper feed ,i have tried solutions listed but problem remains. i thought it may have been replacement cartridge however i had printed aprox 200to-300 pages after fitting the cartidge before this problem appeared.i can only get rotten thing to print same way that the other user [sklazinga]with same problem has.
  • Samsung Master
  • 4,338 Answers
Run a print job,then when the paper jams, open the cover and remove the toner cartridge.
If the paper is past the area under the toner cartridge, then it is the fuser that is causing the problem. If it is not getting that far, I would clean the rollers that you see with a damp cloth(almost dry cloth).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 13, 2008
Open door, remove toner, look towards back with flashlight where black rubber roller picks up the paper. clean roller  with rubbing alchohol and q-tip. let dry and run. might not be permanent fix but its been working for me.
Posted on Dec 03, 2008
  • bobmmmmm Dec 03, 2008
    IMHO, the problem is the roller is not grabbing the paper and pulling it into the printer.  The dark rectangular mark on the top of the jammed page is in essence a "skid mark" from the slipping roller.
    Try not to load tray with too much paper. the thicker the stack, the more friction, the more friction, the harder the roller has to pull.
My samsung printer scx-4521f show message: paper jam 01
Dear
Paper jam 1 caused du to the photo interupture and the lever connected at SMPS. Check the lever and sensor.
Thanks.
Jul 07, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX-4521f Document Jam with no paper jammed
u can clean sensor in your printer, i mean all sensors.
Jul 05, 2014 | Samsung SCX-4521F Laser Printer
Samsung scx-4521f "paer jam 2"_ i've checked paper inside but i can't see any thing is jammed. if i turn off and on that time 1 paper will be printer ofter one same problem is repete. any advice sir
Sanjay,
I think you should take all unused papers out, close tray and predd print button. If there is paper in the system, it may come out. A red light may also flash asking you to load papers. Now lod the papers and the red light will go off. Put a printed paper and try copying. If it copies, you are ok. Now print from your cpmputer command. If it prints you are ok. If it does not and you get paper jam warning, there may be a small piece of paper stuck in the system. You have to open each feeder and see if you find anything. Good luck.
Jun 02, 2014 | Samsung SCX 4521F All-In-One Laser Printer
My paper is getting stuck on roller for laser printer scx-4521F, when remove paper and open door to reset printer, paper goes through and then jams again on new job.
open the front door and take the cartrige out.
if it jams at the black roller. you must clean the pickup roller.
you will see it at the back of the unit in the center.
Nov 11, 2009 | Samsung SCX 4521F All-In-One Laser Printer
On receive of a fax it goes directly into memory without printing it??? SAMSUNG SCX-4521F
This may be due to paper jam,toner cartridge is about to finish.
These are the possible issues. Even after changing the cartridge if the same thing persists let us know.
Rafique
Jun 15, 2009 | Samsung SCX 4521F All-In-One Laser Printer
PRINTER DID NOT TAKING PAPER AFTER PRINT OPTION AND PRINTER STOPS AFTER 2INCHES PAPER
hi
I guess its a coz of paper jam in your printer.
Heavy cardstock and certain types of slick or coated paper can cause frequent paper jams. To better isolate the cause of your problem (machine or paper), try a new **** of regular 20 lb copy or laser paper.
  • Don't Overload
    Overloading your paper tray can cause paper jams. Your manual may say that your input tray can hold 250 sheets -- but if you keep getting jams, try loading 225 sheets instead.
  • Check the Paper
    Check the minimum/maximum paper weights that your printer can handle. Paper that is too thick, or too thin, can cause jams.
  • If you still get paper jams after this may be its time to clear the internal of the machine..You might want to have a look at the following link..
  • http://lasertoners.blogspot.com/2005/10/laser-printer-jam-fix.html
hope u will b helpffull
thankyou.
May 08, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Paper jam-2
samsung scx-4521f paperjam2 check inside
Mar 22, 2009 | Samsung SCX 4521F All-In-One Laser Printer
SCX 4521F multi/f keeps reporting "Document Jam"
Hello there,
If the paper is lodged too far into the printer and can't be removed: Press the power button to turn the printer off.
Pull firmly on the paper to remove it. If you can't reach the paper because it is too far in, raise the front cover and remove the paper from the front of the printer.
Close the front cover.
Press the power button to turn the printer back on.
Resend your document to print.
Ensure that:
The paper is a recommended paper for Laser printers.
You do not force the paper down into the printer when you load it. For example, if you are loading letter or A4 size paper, the top edge of the paper should extend above the top of the sheet feeder.
The printer is on a flat, level surface.
The left paper guide is against the side of the paper.
You do not load too much paper in the sheet feeder. Depending on the thickness of your paper, the sheet feeder can hold up to 100 sheets of paper.
The left paper guide does not cause the paper to bend in the sheet feeder.
Your printer feeds regular paper as expected. If regular paper feeds without causing problems, load the envelopes vertically against the right side of the sheet feeder. Make sure the paper guide is against the side of the envelopes.
Envelopes or the appropriate specialty papers are selected in the printer driver.
You are using a paper or envelope size supported by your printer.
do not forget to rate this solution....good luck
thanks for using FixYa
Feb 12, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
749 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
