The washing machine is not draining water either during the wash, rinse on spin cycles. Is there anyway that I can fix this problem myself
I recenty moved house and my machie would not empty water then i realised that the drain hose still had stopper in it !
Possible your outlet filter is blocked. After disconnecting electrical input from wall socket, remove the back panel of washer to see if the pipe from the tub is blocked, clear, also check the outlet filter, clean. If u have the users' manual check how to clean your outlet filter
As previous posting, my machine does not release any water during any cycle and does not spin. I have had the pump off the clear any blockage and found a curtain hook in it, which has been removed. Cleaned the pump and put back in the machine. It washed a couple of washes fine then packed up again. Do you think its the pump?
