Xerox Phaser 6100/BD Laser Printer
Problem for Xerox Phaser 6100/BD Laser Printer
Network Printing Issues
By alexredfern on Nov 14, 2006
we have the 6100 as a network printer in our office. one computer sees it fine and wil print to it, the other will install the drivers and recognise the printer as online, yet no program will print anything. nothing happens. when a test page is printed it works fine.
i've tried installing as both a network printer and a local printer, the same happens for both. the laptops are identical, and the first suffered this problem also until suddenly it worke. the second was set up in the same way, but will not work.
thanks
Same Problem
Jul 08, 2008
-   yes-   Guest
Dec 08, 2007
-   lexmark4270 AIO will not install on home network. local,host computer os is xp other computer os is windows me. Lexmark does not have driver support for windows me for this printer on its site Tried Google search no luck so far..Does anyone know a work around for my problem Can you help ?
Thanks-   SAILER
Solution #1
posted on Nov 26, 2006
Somewhat Helpful)
El Duderino
Rank: Wiz
Rating: 90%, 381 votes
Hi alexredfern,
Have you checked that the printer is set to be the default printer on the problem PC?
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Dec 03, 2007
Somewhat Helpful)
trickieone
Rank: Guru  Xerox Expert
Rating: 89%, 282 votes
Have you tried turning off all firewalls you have installed on the computer?
There are times a firewall will block the data from being printed.
You can ping the pinter and otherwise see it, but the firewall will block data.
The second thought is do you have secure print selected?
Make sure BOTH SECURE PRINT and DELAY PRINT are turned OFF after you are sure your firewall is not stopping the print jobs.
Was this helpful?
Yes
No
Popular Solutions for Xerox Phaser 6100/BD Laser
Questions and Unsolved Problems for Xerox Phaser 6100/BD Laser
Do you recommend Xerox Phaser 6100/BD Laser Printer?
Answer
Answer
when i put a high-speed sd card in my printer is says memory card error
Answer
I have an HP Officejet model# J6450 All-in-one printer s/n# MY8362B28F. I installed the software on... (More)
Answer
change language on konica minolta 2450
Answer
I have a "CTD Calibration Error" after I replaced the toners what I have to do?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Xerox Phaser 6100/BD Laser...:
Top Printer Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
