Geting serial printer Scribe 612 to work with my computer
Scribe 612 has cable from mini DIN to RJ-45, also adapter from RJ-45 to DB-9 or DB-25 serial.
OS is Win XP Home, SP-3
No Plug and Play, can't find any drivers for it
Regards,
Liegnitz
  • 1 more comment
  • liegnitz Nov 13, 2008
    Has anybody else had this problem? There are certainly lots of Scribe 612 around...
    It seems such a waste to use a 8 1/2 x 11 for an email that could go on a 4 x 4 or less..
    Go Green!
    Regards,
    Liegnitz
  • crowesam Jan 14, 2009
    Can't find anyone to support this with driver download.
  • Tommy2Guns Jan 21, 2009
    I am having the same issue of trying to get the scribe612 to work with my pc. Can not find drivers. Bought the usb to serial cable and still no luck!! Does anyone have any idea how to make scribe612's work with a windows pc or are they just old junk? Tommy2Guns
5 Suggested Answers
CowboysFanZ
  • 99 Answers
SOURCE: will not plug and play
If you are using a printer on a USB port, you must configure the PORT if XP won't find it. Run the Printer Setup Wizard as a printer connected to your PC. When windows xp doesn't find it, choose to CREATE A PORT, and choose to create a local port, and name it for the printer you want to install. Follow the prompts and you should be good to go.
//CowboysFanZ
Posted on Apr 24, 2008
Junoon007
  • 1011 Answers
SOURCE: Drivers For Paxar 9855
sir,
Click this link for driver.....
http://www.paxar.com/support/service_utilities.html#WindowDrivers
Click the link and below they have the list of driver. Download it....
thanks
good luck
Posted on Aug 15, 2008
SOURCE: driver
Taka9}I{e xyema, rge 6JI9gb gocmamb eToT e6y4uu' gpau'Bep!? cykuHax
Posted on Oct 28, 2008
duckles10
SOURCE: ian_harte
Some of the credit card printer supliers sell a cable that you need. I don't know the exact pin out myself.
Posted on Mar 24, 2009
nenalex2002
  • 134 Answers
SOURCE: USB 2.0 to RJ-45 LAN Ethernet Network Adapter driver required
SMC2206USB/ETH Drivers
SMC2208USB_ETH Driver
SMC2209USB/ETH Drivers
If it's an SMC with a little luck you'll find the drivers for your specific model number, Otherwise, go to SMC Site and search for your model number. If it's not an SMC device, let me know what brand and model number it is.
Alex
Posted on Mar 26, 2009
How do I connect to SAN switch with serial cable
If am not mistaking I believe the is an port on the switch for a serial connection. There should have been a serail cable that came with the switch. It should be RJ-45 to RJ-45 and on one end of this cable there should be an RJ-45 to RS232 adapter.
Connect the one end to the switch and the other to the computer, with or without the aforementioned adapter. I do not recall the COM setting needed but you can visit the HP support website for the manuals of your switch. The HP part number you want to search is A7987A. This is basically a Brocade switch under the hood.
Good luck.
Jun 16, 2014 | HP Hewlett Packard A7987A New SAN Switch...
Building custom parallell adapter from j45 to b25 need colr code
If you mean DB25 connector you can try this:
RJ 45 Pin 1 to 5 Volt power
RJ 45 Pin 2 n/c
RJ 45 Pin 3 Gnd (DB Pins 18 -25)
RJ 45 Pin 4 n/c
RJ 45 Pin 5 to DB Pin 1
RJ 45 Pin 6 n/c
RJ 45 Pin 7 DB Pin 14
RJ 45 Pin 8 DB Pin 2
More info about DB-25 connector can be found here.
Jan 07, 2012 | Epson TM Office Equipment & Supplies
I can't reset the DSR8035 to factory default values. I am connecting using a null modem cable through COM port 1 on my laptop. The HyperTerm settings I am using are 9600 8-N-1. I don't get a...
ehm the 8035 doesn't have a comp port but an RJ 45 port, the unit comes with a rollover cable and an Avocent Adaptor which should be used to access the unit.
The parts are the following items:
540-604-501 Adapter [RJ-45 to DB-9 DCE Female]; equivalent to Equinox 210095
540-605-501
Cable [RJ-45 Reversing Modular Cable]; equivalent to Equinox 690226
May 11, 2011 | Avocent DSR 8035 (DSR8035001) 32-port KVM...
DID this HDD (Western Digital Caviar Blue WD5000AAKX 500GB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive) can atach in ASUS K8U-X, Thank you, Nikola
ASUS K8U-X - motherboard - ATX - Socket 754 - ALi M1689
1.0 x PCI - Socket 754,
2.0 x Processor - DIMM 184-pin,
4.0 x AGP 8x,
1.0 x Memory
  • Storage Interfaces ATA-133 - connector(s): 2 x 7pin Serial ATA - RAID 0 / RAID 1 / JBOD,
    Serial ATA-150 - connector(s): 2 x 40pin IDC
  • Interfaces 1.0 x Keyboard - Floppy interface - RJ-45,
    1.0 x Hi-Speed USB - SPDIF output - 6 pin mini-DIN (PS/2 style),
    4.0 x Network - Generic - 34 pin IDC,
    1.0 x Audio - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25),
    1.0 x Audio - Ethernet 10Base-T/100Base-TX - 9 pin D-Sub (DB-9),
    1.0 x Parallel - Generic - 4 pin USB Type A,
    1.0 x Serial - RS-232 - 6 pin mini-DIN (PS/2 style),
    1.0 x Storage,
    Mouse
  • Power Connectors 20-pin main power connector,
    4-pin ATX12V connector
  • as long as the PSU and motherboards power and lead connections are the same as the hard drive
    hope this helps
    May 10, 2011 | ASUS K8U-X Motherboard
    My gigabyte motherboard will support single chip 2gb ram and i have to upgrade my ram into ddr2 533mhz to ddr2 667mhz or 800mhz it is possible for my motherboard
    Gigabyte GA-945GZM-S2 - motherboard - micro ATX - LGA775 Socket - i945GZ specifications
    • it looke like the supported RAM
    • Supported RAM Technology DDR2 SDRAM
    • Supported RAM Speed 533 MHz , 400 MHz
    • hope this helps
    • General
    • Product Type Motherboard - Micro ATX
    • Cache Memory None
    • Chipset Type Intel 945GZ Express / Intel ICH7
    • Max Bus Speed 800.0 MHz
    • Processor Socket LGA775 Socket
    • Max Processors Qty 1.0
    • Compatible Processors Core 2 Extreme , Celeron D , Core 2 Duo , Pentium D , Pentium 4
    • Memory
    • Max Supported Memory 2.0 GB
    • RAM Features Dual channel memory architecture
    • Graphics
    • Graphics Controller Intel GMA 950
    • Memory Allocation Technology Dynamic Video Memory Technology 3.0
    • Audio
    • Type High Definition Audio (8-channel)
    • Audio Codec Realtek ALC888
    • Compliant Standards High Definition Audio
    • LAN
    • Network Controller Marvell Yukon 88E8001
    • Network Interfaces Gigabit Ethernet
    • Modem None
    • Expansion / Connectivity
    • Expansion Slot(s) 1.0 x Processor ( 1.8 V ) - LGA775 Socket ( x4 mode ) , 4.0 x PCI Express x16 - DIMM 240-pin , 3.0 x Memory , 1.0 x PCI
    • Storage Interfaces Intel ICH7 : ATA-100 - connector(s): 4 x 7pin Serial ATA - 4.0 device(s) , Intel ICH7 : Serial ATA-300 - connector(s): 1 x 40pin IDC - 2.0 device(s)
    • Interfaces 1.0 x Audio - Floppy interface - Mini-phone stereo 3.5 mm , 1.0 x Storage - Line-out - 6 pin mini-DIN (PS/2 style) , 1.0 x Audio - RS-232 - 25 pin D-Sub (DB-25) , 4.0 x Serial - VGA - Mini-phone 3.5 mm , 1.0 x Microphone - Line-in - 15 pin HD D-Sub (HD-15) , 1.0 x Keyboard - Generic - 6 pin mini-DIN (PS/2 style) , 1.0 x Display / video - IEEE 1284 (EPP/ECP) - 4 pin USB Type A , 1.0 x Audio - Line-out (center/subwoofer) - Mini-phone 3.5 mm , 1.0 x Network - Generic - 34 pin IDC , 1.0 x Parallel - Line-out (side surround) - RJ-45 , 1.0 x Audio - Line-in - Mini-phone stereo 3.5 mm , 1.0 x Hi-Speed USB - Line-out (rear) - 9 pin D-Sub (DB-9) , 1.0 x Audio - Input - Mini-phone stereo 3.5 mm , 1.0 x Mouse - Ethernet 10Base-T/100Base-TX/1000Base-T - Mini-phone stereo 3.5 mm , 1.0 x Audio - 4 pin MPC
    Apr 09, 2011 | Gigabyte GA-945GZM-S2 Motherboard
    I have a D102GGC2 motherboard with intel pentium 4 processor 524 , LGA775 Pkg 3.06GHz,.So please tell me about related drivers and chipset and how to download from intel site ?
    Link for download of drivers etc. is at the bottom. Choose Operating system, etc and what you need (drivers, software, etc.).
    I don't know if it will come to you as a hyperlink or not. If not you will have to copy and paste or type in address bar as one long string.
    Manufacturer:
    Intel
    Part Number:
    BOXD102GGC2
    General
    Product Type
    Motherboard
    Form Factor
    Micro ATX
    Width
    9.8 in
    Depth
    8.6 in
    Celeron D ,
    Pentium 4 ,
    Pentium D
    Processor Socket
    LGA775 Socket
    Multi-Core Support
    Dual-Core
    Chipset Type
    ATI Radeon Xpress 200 / AMD IXP 450
    Max Bus Speed
    800 MHz
    Storage Controller
    ATA-133,
    Serial ATA-150
    Power Connectors
    4-pin ATX12V connector,
    24-pin main power connector
    Processor
    Installed Qty (Max Supported)
    0 ( 1 )
    Memory
    DDR2 SDRAM
    RAM Installed ( Max )
    0 MB / 2 GB (max)
    Supported RAM Speed
    PC2-3200,
    PC2-4300
    RAM Features
    Video
    Graphics Controller
    ATI Radeon X300 Shared video memory (UMA)
    Audio
    Audio Output
    Sound card
    Audio Codec
    Realtek ALC861
    Compliant Standards
    Telecom / Networking
    Networking
    Network adapter - Realtek RTL8101L - Ethernet,
    - Fast Ethernet
    Features
    BIOS Features
    ACPI support,
    SMBIOS support,
    Rapid BIOS boot
    Hardware Monitoring
    System voltage,
    CPU fan tachometer,
    Chassis fan tachometer
    Sleep / Wake Up
    Mouse wake up,
    Keyboard wake up,
    Wake on USB port,
    Wake on LAN (WOL),
    Wake on PCI device,
    Suspend to RAM (STR)
    Expansion Slots Total (Free)
    1 Processor - LGA775 Socket,
    2 Memory ( 1.8 V ) - DIMM 240-pin,
    1 PCI Express x16,
    1 PCI Express x1,
    2 PCI
    Storage Interfaces
    Serial ATA-150 - connector(s): 4 x 7pin Serial ATA - 4 device(s),
    ATA-133 - connector(s): 2 x 40pin IDC - 4 device(s)
    Interfaces
    4 x Hi-Speed USB - 4 pin USB Type A,
    1 x Parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25),
    1 x Serial - RS-232 - 9 pin D-Sub (DB-9),
    1 x Mouse - Generic - 6 pin mini-DIN (PS/2 style),
    1 x Keyboard - Generic - 6 pin mini-DIN (PS/2 style),
    1 x Network - Ethernet 10Base-T/100Base-TX - RJ-45,
    1 x Display / video - VGA - 15 pin HD D-Sub (HD-15),
    1 x Storage - Floppy interface - 34 pin IDC,
    1 x Audio - Line-in - Mini-phone stereo 3.5 mm,
    1 x Audio - Line-out - Mini-phone stereo 3.5 mm,
    1 x Microphone - Input - Mini-phone 3.5 mm
    http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%c2%ae+Desktop+Board+D102GGC2
    Hope this helps.
    Nov 27, 2010 | Intel D102GGC2 Motherboard
    What is the maximum memory of P5S-MX-SE motherboard and what is thge type of video card should I use
    memory support 4 gb ddr 2 1 x Audio - line-In - MPC 4 pin , 1 x memory - floppy interface - IDC 34 pin , 1 x parallel - IEEE 1284 (EPP/ECP) - D-Sub 25 pin (DB-25) , 1 x serial - RS-232 - D-Sub 9 pin (DB-9) , 1 x display / video - VGA - D-Sub HD 15 pin (HD-15) , 1 x keyboard - generic - Mini-DIN 6 pin (type PS/2) , 1 x mouse - generic - Mini-DIN 6 pin (type PS/2) , 1 x network - Ethernet 10Base-T/100Base-TX/1000Base-T - RJ-45 , 4 x Hi-Speed USB - USB Type A 4 pin , 1 x Audio - line-out - jack stereo 3,5 mm , 1 x Audio - line-out (side surround)/line-in - jack stereo 3,5 mm , 1 x Audio - line output (cental/subwoofer) / microphone - jack 3,5 mm
    Nov 12, 2010 | ASUS Computers & Internet
    Does this model has built in wi-fi card
    Dell Latitude D600 Notebook Computer for Business specifications
    • General
    • Recommended Use Small business
    • Platform Technology Intel Centrino
    • Built-in Devices Keypad , Wireless LAN antenna , Stereo speakers
    • Width 12.4 in
    • Depth 10.1 in
    • Height 1.2 in
    • Weight 4.6 lbs
    • Color Gray
    • Bundled with Port replicator
    • Notebook type Thin-and-light (4-6 lbs.)
    • Wireless capabilities IEEE 802.11b
    • Processor
    • Processor Intel Pentium M 745 1.8 GHz
    • Data Bus Speed 400.0 MHz
    • Chipset Type Intel 855PM
    • Cache Memory
    • Type L2 cache
    • Cache size 1.0 MB
    • RAM
    • Installed Size 512.0 MB / 2.0 GB (max)
    • Technology DDR SDRAM - 266.0 MHz
    • Memory specification compliance DDR266/PC2100
    • RAM form factor SO DIMM 200-pin
    • Environmental Parameters
    • Environmental standards EPA Energy Star
    • Min Operating Temperature 32.0 °F
    • Max Operating Temperature 95.0 °F
    • Humidity Range Operating 10 - 90%
    • Max Altitude Operating 9840.0 ft
    • Storage Controller
    • Storage controller type IDE
    • Storage
    • Floppy Drive None
    • Hard Drive 80.0 GB
    • Storage Removable None - None
    • Hard drive type Portable
    • Optical Storage
    • Type CD-ROM - Plug-in module
    • CD / DVD read speed 24x
    • Optical Storage (2nd)
    • 2nd optical storage type None
    • Display
    • Display Type 14.1 in TFT active matrix
    • Max Resolution 1024 x 768 ( XGA )
    • Widescreen Display No
    • Color Support 24-bit (16.7 million colors)
    • Video
    • Graphics Processor / Vendor AGP 4x - ATI Mobility Radeon 9000
    • Video Memory 32.0 MB DDR SDRAM
    • Audio
    • Audio output type Sound card
    • Audio output compliant standards AC '97
    • Audio Input Microphone
    • Input Device(s)
    • Input device type Keyboard , Touchpad , Track stick
    • Telecom
    • Modem Fax / modem - PCI
    • Max transfer rate 56.0 Kbps
    • Protocols & Specifications ITU V.92
    • Networking
    • Networking Network adapter
    • Networking / Wireless LAN Supported Yes
    • Data link protocol IEEE 802.11b , Fast Ethernet , Ethernet , Gigabit Ethernet
    • Networking standards IEEE 802.11b
    • Expansion Bays 1.0 x Front accessible
    • Expansion Slots Total (Free) 1.0 ( 1.0 ) x Smart Card - Type I/II , 1.0 ( 0.0 ) x CardBus - SO DIMM 200-pin , 2.0 ( 1.0 ) x Memory
    • Interfaces 1.0 x Mouse - VGA - 280 pin docking ( On expansion base ) , 1.0 x Peripheral - IEEE 1284 (EPP/ECP) - 4 pin USB Type A ( On expansion base ) , 1.0 x Docking / port replicator - Ethernet 10Base-T/100Base-TX - RJ-11 ( On expansion base ) , 1.0 x Keyboard - Phone line - 25 pin D-Sub (DB-25) ( On expansion base ) , 1.0 x Display / video - Generic - 15 pin HD D-Sub (HD-15) ( On expansion base ) , 1.0 x Hi-Speed USB - S-video output - Mini-phone stereo 3.5 mm ( On expansion base ) , 2.0 x Display / video - Line-out/headphones - 7 pin mini-DIN , 1.0 x Audio - Generic - Mini-phone mono 3.5 mm , 1.0 x Infrared - SPDIF - 29 pin combined DVI , 1.0 x Microphone - Input - 9 pin D-Sub (DB-9) , 1.0 x Serial - DVI-Analog/Digital - IrDA , 1.0 x Modem - RS-232 - 6 pin mini-DIN (PS/2 style) , 1.0 x Parallel - 4 pin USB Type A , 1.0 x Audio - 6 pin mini-DIN (PS/2 style) , 1.0 x Network - RJ-45 , 2.0 x Hi-Speed USB , 1.0 x Display / video
    • Miscellaneous
    • Included Accessories Carrying case
    • Features Administrator password , Hard drive password , Security lock slot (cable lock sold separately) , System password
    • Compliant Standards FCC Class B certified
    • Power
    • Power device form factor External
    • Voltage Required AC 120/230 V
    • Power provided 65.0 Watt
    • Battery
    • Technology Lithium ion
    • Installed Qty 1.0 / 2.0 (max)
    • Battery capacity 48.0 Wh
    • Operating System / Software
    • OS Provided Microsoft Windows XP Professional
    • Software Drivers & Utilities
    • Manufacturer Warranty
    • Service & Support 3 years warranty
    • Service & Support Details Limited warranty - 3 years - On-site
    • Sustainability
    • ENERGY STAR Qualified Yes
    Jun 01, 2010 | Dell Latitude D600 Notebook
    Does my dell dimension 2350 have a dvi port?
    No, it does not.
    Check the specs of your desktop PC here:
    Ports and Connectors
    Externally accessible:
    Serial
    9-pin connector; 16550C-compatible
    Parallel
    25-hole connector (bidirectional)
    Video
    15-hole connector
    Keyboard
    6-pin mini-DIN connector
    Mouse
    USB
    two front-panel and four back-panel USB 2.0–compliant connectors
    Network
    RJ-45 connector
    Audio
    three back miniature connectors for line-in, line-out, and microphone
    Headphone
    one front miniature connector for line-out
    Serial
    Parallel
    Video
    15-hole connector
    Keyboard
    Mouse
    USB
    Network
    RJ-45 connector
    Audio
    Headphone
    http://support.dell.com/support/edocs/systems/dim2350/specs.htm#1107078
    Jul 26, 2009 | Dell Dimension 2350 PC Desktop
    Just wanted to know if the mother board 865GM3-LS supports 1Ghz of AGP graphics card..
    Motherboard has a AGP 8x ( 1.5 V/ 0.8 V ) slot.
    Check the specs on the graphics board you are going to install. Make sure that it meets these specs.
    Here are the specs for your motherboard: General Product Type Motherboard Form Factor Micro ATX Width 24.5 cm Depth 24.5 cm Compatible Processors Pentium 4, Pentium 4 Extreme Edition 64-bit Processors Compatibility Built-in Processor Socket Socket 478 Chipset Type Intel 865G / Intel ICH5 Max Bus Speed 800 MHz BIOS Type Award Storage Controller ATA-100, Serial ATA-150 Processor Installed Qty (Max Supported) 0 ( 1 ) Memory Supported RAM Technology DDR SDRAM RAM Installed ( Max ) 0 MB / 2 GB (max) Supported RAM Speed PC2100, PC2700, PC3200 RAM Features Two DDR channels Video Graphics Controller Intel Extreme Graphics 2 Video Memory Shared Video Memory (UMA) Audio Audio Output Sound card Signal Processor Intel 865G Audio Codec Realtek ALC655 Sound Output Mode 5.1 channel surround Compliant Standards AC '97 Telecom / Networking Networking Network adapter - Realtek RTL8100C - Ethernet, Fast Ethernet Features BIOS Features Hyper-Threading Technology Expansion / Connectivity Expansion Slot(s) 1 ( 1 ) x processor - Socket 478
    2 ( 2 ) x memory ( 2.5 V ) - DIMM 184-PIN
    1 ( 1 ) x AGP 8x ( 1.5 V/ 0.8 V )
    3 ( 3 ) x PCI ( 3.3 V/ 5 V ) Storage Interfaces Serial ATA-150 - connector(s): 2 x 7pin Serial ATA
    ATA-100 - connector(s): 2 x 40pin IDC Interfaces 1 x storage - floppy interface - 34 PIN IDC
    1 x serial - RS-232 - 9 pin D-Sub (DB-9)
    1 x display / video - VGA - 15 pin HD D-Sub (HD-15)
    1 x parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25)
    4 x Hi-Speed USB - 4 PIN USB Type A
    1 x audio - line-In - mini-phone stereo 3.5 mm
    1 x audio - line-out - mini-phone stereo 3.5 mm
    1 x microphone - input - mini-phone 3.5mm
    1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
    1 x keyboard - generic - 6 pin mini-DIN (PS/2 style)
    1 x mouse - generic - 6 pin mini-DIN (PS/2 style) Additional Connectors (Optional) 4 x Hi-Speed USB Miscellaneous Software Included Drivers & Utilities Compliant Standards Plug and Play
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Jan 10, 2009 | Computers & Internet
    488 people viewed this question
    k24674
