Question about Microsoft ZUNE JS8BRPBDLUG MP3 Player
Syncing I cannot get my zune software to update anymore, and the device is no longer showing up in it. I have a 30 GB Zune, and only got to add some music and videos once, after that problems. When i try to uninstall and reinstall from the Cd, it is doing it quickly like an update and the software is loading without some of the features eg I don't see the word settings anywhere. Please help me. CAB
  • 7 Answers
If your running vista on your computer you have to update your computer. but if your running any thign other than vista im not sure other than there may be no more updates you can get
Posted on Nov 13, 2008
How can i update zune hd
How to update your Zune player
Overview
If you haven't used your Zune player in a while, you might need to update it in order to get the latest features and improvements.
Steps to update
  1. On your computer, start the Zune software.
  2. Connect your Zune player to your computer by using the USB cable that was included with your player.
  3. If a newer version of the Zune firmware is available, you'll see a notice to update your player. You can also manually check for new player updates in the Zune software. Go to Settings (located at the top of the screen), Device (located in the upper-left corner), and then Update (located in the list at the left).
  4. If you receive a notice to update your player, follow the on-screen instructions. Important During the update process, don't disconnect your Zune player it until the update finishes. The update might take several minutes. During this time, your Zune player might restart several times.
Mar 31, 2015 | Microsoft Zune 30 Gb Digital Media Player...
Zune won't sync and now some songs will not play all they way through
Go for software update from the zune website it will help you.
Also ensure that the settings are not changed .
Sep 25, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
How do I restore my devices firmware for my zune 30gb
How to restore your Zune device software:------------
When you restore your Zune device software, the startup partition and the data partition are removed and rebuilt. In addition to removing the Zune device software, this process also erases all audio, videos, podcasts, and pictures that are stored on the Zune device.
Warning To restore the Zune device software, you must have a Windows-based computer that has an Internet connection. That computer must have the Zune software installed. And you must be able to connect the Zune device to a USB port on that computer by using a Zune Sync Cable. Do not perform the following steps if you do not have any one or more of these things immediately available.
After you start to restore the Zune device software, you cannot again use the device until you complete all the steps. You will not receive any confirmation or warning on the Zune device after you start the following procedure.
To restore the Zune device software, follow these steps:
1. Set the Hold Switch to unlocked.
2. Press and hold the Back button at the same time as you press and hold the top of the Zune Pad. When the Zune device begins to power up, release the buttons.
3. Immediately after you release the buttons in step 2, press and hold the following special button combination, depending on your Zune model:• If you have the 4GB Zune, the 8GB Zune, or the 80GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune Pad and the Play/Pause button. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
• If you have the 30GB Zune, immediately press and hold the Back button at the same time as you press both the left side of the Zune pad and the center of the Zune pad. Continue to hold these buttons until your Zune device restarts and "Please wait" appears on the screen.
Note "Clearing contents. Please wait" appears, followed by “Connect Zune to your PC."
4. After “Connect Zune to your PC” appears, connect the Zune device to the computer that has the current Zune software installed, and then update the device to the current Zune device software.
----------- Click this link directly for more troubleshooting:-- http://support.microsoft.com/kb/944909 -------- If error problem while restoring then click this link below:-- http://support.microsoft.com/kb/945278 ---------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 03, 2010 | Vacuums
Can't put music on zune!
1. Sync the Zune with its "home" computer. Each Zune has a specific "home" computer that it automatically syncs with. Use your Zune-specific USB cord to connect your device to this computer, and then sync your device as you normally would. This will solve most software hiccups and will generally get your Zune out of a "frozen" state.
2. Perform a soft reset. If syncing your device doesn't work, you can reset your software by holding the "Back" and "Up" buttons on the central control pad. Your screen will flicker, and then the Zune logo will appear with a status bar. Within a few moments, your software should be returned to normal.
3. Perform a system restore. However, doing this will erase all of your music, videos and photos, so only do this if you have exhausted both of the other troubleshooting steps. You can restore your Zune by connecting it to your computer, selecting it from the "Devices" list, and then pressing the "Restore" button. The process may take a few minutes, depending on how much content you had on your device. Once the restore has finished, your Zune will be completely blank.
Sep 30, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
I can't sync music to my zune anymore!
it depends on where you get your songs from....if you get them from lime wire....frostwire...or zune.com....the songs are already formated for you to download it to your zune
My 4 gb Zune was charging and now it wont come back on!
I found this on the Zune technical support (if this does help, be sure to rate my solution please):
Your Zune device is not detected by your computer or the Zune software
View products that this article applies to.
SYMPTOMS
When you try to use Zune Software, you experience one or more of the following symptoms:
• The Zune device is not detected by the computer.
• The Zune device is not detected by Zune Software. In this case, when you pause on the device icon in the lower-left corner, you receive the following error message:
No Zune device connected
• If you restored the Zune device software, the following messages are displayed on the Zune device:
On your PC, open the Zune software and restore the Zune device firmware
THINGS TO TRY
To resolve this issue, follow these steps:1. Update the Zune software on the computer. To do this, click settings, click software, click GENERAL, and then click CHECK FOR UPDATES.
If the issue is still not resolved, go to the next step.
2. Restart the Zune device.
To do this, follow these steps: a. Set the Hold switch to the unlocked position.
b. Press and hold the Back button as you press the top of the Zune pad.
When the Zune device begins to restart, release the buttons.
3. Disconnect the Zune device from the computer, restart the computer, and then reconnect the Zune device.
4. Connect the Zune device to a different USB port on the computer. Use a USB port on the back of the computer. Do not use a USB hub.
5. When you connect the Zune Sync Cable to the connector port of the Zune device, make sure that both ends of the sync cable click into position. Additionally, make sure that the sync cable is not connected to the device at an angle.
6. Connect only one Zune device at a time. If you already have a Zune device connected to the computer, any other Zune that you try to connect will not be detected by the Zune software. Disconnect any additional Zune devices, and then try to connect again.
7. If a full-screen battery image appears when you connect the device to the computer, you must let the device charge for several minutes before the device will start and be detected by the computer.
For more information about how to charge a Zune device, click the following article number to view the article in the Microsoft Knowledge Base:
927348 (http://support.microsoft.com/kb/927348/) How to charge the battery in your Zune device
8. If you are using Windows Vista, install the Cumulative update rollup for USB core components in Windows Vista software update. This update resolves some reliability issues in the USB core components in Windows Vista. You will achieve better reliability in various scenarios by installing this update.
For more information about this update, click the following article number to view the article in the Microsoft Knowledge Base:
941600 (http://support.microsoft.com/kb/941600/) Cumulative update rollup for USB core components in Windows Vista
If you are not using Windows Vista, or if the issue is still not resolved, go to the next step.
9. Examine Windows Device Manager. To do this, follow these steps:a. Click Start, right-click Computer, and then click Properties.
b. Click Device Manager. Zune should be listed under Portable Devices.
Note If the device was installed incorrectly, Zune may be listed together with a yellow exclamation mark (!). Or, it may be listed under Other devices as USB Device.
Double-click Zune, and then click the Driver tab. The current version of the driver that is installed should be 2.3.1035.0.
If Windows Device Manager indicates a device problem, or if the version of the driver that is installed is not the current version, you must update the driver. To do this, follow these steps: 1. Right-click Zune or USB Device, and then click Properties.
2. Click the Driver tab, and then click Update Driver.
3. Click Search automatically for updated driver software.
4. Click Install if you are prompted to do this.
5. After the driver installation is complete, click Close.
If Windows Device Manager found the drivers, click Close. If you want to locate the drivers manually, follow these steps:1. In the Zune Properties dialog box, click Update Driver.
2. Click Browse my computer for driver software.
3. Click Browse, locate the \Program Files\Zune\Drivers folder, and then click OK.
4. Click Next.
5. Click Install if you are prompted to do this.
6. After the driver installation is complete, click Close, and then click Close again.
10. Examine the computer for conflicts that involve the USB host controller or the root hub. To do this, follow these steps:a. Click Start, right-click Computer, and then click Properties.
c. Expand Universal Serial Bus controllers.
d. Verify that no errors appear in the list of USB devices. A yellow exclamation point or a red "X" next to a device indicates errors. If any errors appear, contact the manufacturer of your computer.
For more information about how to troubleshoot conflicts in Device Manager, click the following article number to view the article in the Microsoft Knowledge Base:
310126 (http://support.microsoft.com/kb/310126/) Troubleshooting device conflicts with Device Manager
11. Try using a different Zune Sync Cable.
Apr 10, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Hello how put a movies in the zune
The Zune software lets you add to your collection audio and video in a variety of formats and codecs. Just download media from the Web or rip songs from a CD, and the Zune software automatically adds the downloaded (and ripped) items to your collection and syncs them to your device.
The Zune software will convert many video formats during sync so they can play on your Zune device. This automatic transcoding can take a while.
Sep 23, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune 30GB won't sync
please chek if u r using the proper version of ur device!!
plz rate this post
Aug 27, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Downloading podcasts
On your computer, you can set your podcasts to sync to your Zune automatically or one at a time by dragging them to the device icon.
SET PODCAST SYNC OPTIONS
  1. In the Zune software, click the device icon, then click Settings, Podcasts.
  2. Choose your podcast sync settings.
What and how you want to sync is completely up to you. You can choose to:
  • Sync all downloaded episodes.
  • Sync all unplayed or partially played episodes.
  • Sync only the first unplayed episode. This setting saves a lot of space—only one episode lives on your Zune at any time.
  • Don't sync any episodes.
You have to use the proprietary Zune software to sync podcasts - the instructions are vague, so I would go to the Zune support forum to get further instructions on this:
http://www.zune.net/en-us/support/usersguide/gettingstarted/setupfaq.htm
Jul 01, 2008 | Microsoft Zune JS8-00001 Digital Media...
Microsoft ZUNE JS8BRPBDLUG MP3 Player Logo
76 people viewed this question
Top Microsoft Audio Players & Recorders Experts
Mark Chaney
Mark Chaney
john h
Ap12
Ap12
Are you a Microsoft Audio Player and Recorder Expert? Answer questions, earn points and help others
