Question about Lexmark E320 Laser Printer
Lexmark Optra SC1275 printer smears
Print comes out fine, both color and b/w, but there is also always smears that appear to be a greatly offset smeared shadow of what was printed. Happens on every page. Looked at visible rollers and removed fuser assembly- nothing wrong that I can see. Manual just says to call for service for this issue- anything I can do on my own to correct this?
  • Hanial Feb 03, 2009
    it is getting worse, every print out has grey tone smear shadow everywhere, can not use it for work. any service available?
    President:
  • 2,712 Answers
Looks like a problem with the laser unit or the drum unit or both, which may have to be replace. The website is correct. Best call for service.
Posted on Nov 13, 2008
I have a lexmark optra sc 1275 I just downloaded the drivers and tried to print but it takes 3 minutes a page. What is wrong?
Probably nothing. This is a very slow 13 year old printer, claiming 7.5 pages per minute for black and .5 ppm for color. Make sure your settings are for black only to get the maximum speed. Even then, manufacturer claims are often high for print speeds, so 3 minutes a page, especially for color, is probably about right.
Mar 05, 2011 | Lexmark Optra SC 1275 Laser Printer
How i can solve the 913 service motor error lexmark sc1275 my printer?
913 Transfer Roller Error
The printer fails to completely transfer the image to the paper or does not transfer it at all.
The image transfer roll does not lift when paper is passing over it.
Suspect either the transfer roller solenoid or transfer roller motor malfunction.
The printer would have to be professionaly serviced by authorized service centre.
http://www1.lexmark.com/content/en_us/technical_support/find_service_provider.shtml
Copy and paste link above for Lexmark Service Centers.
Pre
Jan 14, 2011 | Lexmark Optra SC 1275 Laser Printer
Don't have CD for installation. How can I download through computer?
Hi You can download a driver Software from my website then you can use the driver to set your printer up.
Just click on this link and it will download for you, and it is best to save it on your desktop so you can find it.
This is for the Lexmark-Optra-Color-1200-XP-and-Mac
Link= http://www.4all2sell.com/driver/Lexmark-Optra-Color-1200-XP-Mac-.EXE
Ones you have downloaded just double click and it will take you through the installing
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one and to go on helping.
All The Best: Pineworks
Feb 04, 2010 | Lexmark Optra Color 1200 Led Printer
I have a Lexmark 1200 printer. Colour promlems
It could be that the cartridge has become dry.
you have to try several head cleans using the printer software and if that doesnt help then the cartridge needs to be replaced.
Nov 03, 2009 | Lexmark Optra Color 1200 Led Printer
I HAVE A LEXMARK OPTRA S 1855 DISPLAY NOT READABLE HOW DO I PRINT A TEST PAGE UNHOOKED FROM THE COMPUTER?
Hello, Leo.
Here are the steps:
  1. Turn the printer power off (O).
  2. Press and hold Select and Return together.
  3. Turn on the printer.
  4. Release the buttons once Performing Self Test appears on the operator panel display.
  5. The printer performs its normal POR cycle, then prints one copy of the Print Quality Test pages.
Hope this helps.
Oct 15, 2009 | Lexmark Optra S 1855 Laser Printer
Lexmark Optra 1275sc - 900 Service - Software Error
I have the same problem, but the error only occurs when I try to print a .pdf file (Adobe Reader) using the "Lexmark Optra SC 1275 PS" driver. For some reason the PS driver didn't like .pdf files! My solution was to always print .pdf files using the alternative " Lexmark Optra SC 1275 (MS)" driver, which Lexmark also offers on its website.
Apr 01, 2009 | Lexmark Optra SC 1275 Laser Printer
Hooking up a Lexmark OPTRA E Printer to a Vista - USB Port
I do not believe that the Optra E is supported by Lexmark on Vista.
Not all products from the Optra family (if any) can meet the demands of that platform.
Feb 10, 2009 | Lexmark Optra E Plus Mac Ready Laser...
Error code Lexmark Optra 1275 Printer - 84 PC Missing
Usually there is more to this message particulary if this is a color printer. Basically the printer is telling you that tyhere is a problem in the Photoconducter area of the print cartridge. Normally I would expect to see a 84 PC end of life. Can you tell me if you left some information out, please?
Sep 03, 2008 | Lexmark Optra SC 1275 Laser Printer
Lexmark 1240...
With the Lexmark printers communication subsystem you MUST let the driver ask for you to plug in the printer. DO NOT plug the printer into the USB port until told to do so.
To fix a fouled install:
(1) Uninstall the Lexmark drivers in Add Remove Programs
(2) Shutdown the computer
(3) Disconnect the printer from the USB port
(4) Restart the computer
(5) Run the Driver Installation software
(6) Cancel ALL attempts by windows to auto install the printer
(7) When the software asks for the printer connect it and continue
Aug 10, 2008 | Lexmark Optra Color 1200 Led Printer
My problem with the Lexmark optra sc 1275
Lexmarks use a silicone oil cleaning pad on top of the fuser, try to locate a door on top towards the rear, take it out you might see a long black piece, when you take it out it has a felt on the bottom it is used to clean excess toner off the fuser it should be replaced everytime you change your toner ( usually comes w/the toner).
Oct 11, 2007 | Lexmark Optra SC 1275 Laser Printer
Lexmark E320 Laser Printer Logo
136 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
