Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
Vacuum making loud noise (like hole in tube)
Our vacuum started making a loud noise and of course we just barely missed the window for our warrenty. It sounds like there is a hole in a tube somewhere. Wondered if anyone had any suggestions or ideas. Would appreciate any help we can get.
Thanks!
  • Shawn Dec 05, 2008
    I have the same problem with the same age Kenmore. I checked for clogs but there were none. The loud noise sounded like a vibration. The noise was so loud you almost couldn't be in the house when using the vacuum. What I found was, the outer rubber housing of the motor/fan was held together by electrical tape and split at the electrical tape (wow, that's a surprise!!). I taped the housing together with fresh tape but the motor housing continued to split when the filters got slightly clogged and higher pressure was generated inside the motor. I suspect that the split was causing some amount of air from the motor to be exhausted into the inside of the vacuum causing internal parts to vibrate and resonate.
    I haven't been able to fix this problem. Unfortunately, the excessive vibration caused a control board to fail which controls the agitator. At this point the vacuum is useless. Poor design by Kenmore.
    If you know of a solution, let me know
I have the same vacuum - it's a clog in the brush area, or where the hose connects to the base. Unhook the hose, like you're going to use a tool. Lay the vacuum flat, so you can stick something in the plastic tube (at the base where you disconnected the hose) without the awkward angle. I use a dryer vent cleaner, but you could probably use a wire hanger. Push through until it comes out through the brush area...should fix your problem.
Posted on Dec 03, 2008
  • 281 Answers
Disconnect the tube an see if you hear the same sound.put the tube back together 1 section at a time and try to hear the noise after each section.that will narrow it dow where the noise is coming from
Posted on Apr 10, 2009
Loud noise coming from cyclonic cap
sounds like you'v lost a rubber seal check this diagram on the link below see if you can see anything missing
http://www.vacpartswarehouse.com/Dyson-DC24-Upright-s/3888.htm
Apr 01, 2013 | Dyson Ball DC24 Bagless Upright Vacuum
My vacuum is making a loud whirring sound and is hotter than normal.
Hi Kelsey! I understand how frustrating this must be. Dirty filters or a clog can cause the vacuum to change sound and be hotter than normal.
Here is a quick link to troubleshooting the excessive noise:
http://www.bissell.com/FAQDetail.aspx?id=1362&cid=ccsocial
Mar 28, 2013 | Bissell Cleanview Helix Bagless Upright...
Dyson DC17 making loud noise
Hi Liz,
I'm sorry to hear that you're concerned about the noise your DC17 is making. It will be difficult for us to help without hearing the noise, so it's probably best if you get in touch with us directly. One of our Helpline experts will be able to determine the cause of the issue, and will be able to recommend the best course of action.
You can call us free on 1866MYDYSON, or email askdysonUS@dyson.com. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Oct 27, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
While on the carpet setting- when the arm is released- there is a loud noise...doesn't matter if it is on bare floor or carpets-- if on the bare floor setting there is no noise on floor or...
I'm sorry to hear you're having difficulties with your DC14 Animal. The cleaner's brush control system is designed to make a ratcheting sound to alert you if the brushbar is jammed. Although you've already cleaned the brushbar, it's a good idea to follow the steps shown in our online support guide to make sure you haven't missed any obstructions in the cleaner head:
http://www.dyson.com/support/help.asp?article=650&product=DC14-ANIMAL_US
This should allow you to resolve your issue without further assistance. However, if you've checked the brushbar and cleaner head are clear of threads, hair, or other obstructions, but the cleaner still seems to be making the ratcheting noise, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you to identify the cause of the issue, and will be able to recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Sep 04, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
Loud noise and appears the belt is slipping
Generally you will find soil and string of some sort wrapped around the drive spool. Make sure you unplug it before starting and it might be quite hot.
Dec 12, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Loud noise
When the motor bearings start to go bad, they will make a loud noise. Some motors if a piece broke off of the fan, then it also will make a loud noise. You may have to replace the motor.
Dec 25, 2007 | Westinghouse WST1500 Wired Special Edition...
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
2,118 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
