Question about Canon Cameras
I have a canon Power Shot S50. The mechanical slider that covers the lens is loose. When I open it, it doesn't power up the camera. I suspect there is a switch underneath the cover is broken.
  • 225 Answers
The open door button on a circuit board is usually micro. A loose cover will likely not make contact with this small switch. Take the cover off and tighten the screws on the inside. Try to locate the switch to inspect if it has been wore off, broken, or missing even.
Posted on Nov 13, 2008
My cannon power shot sd780 lens cover does not open when turned on. Just a black screen. The barrel does extend. Is there something I can do to fix it?
Its not easy to dismantle this kind of gadget, a broken gear inside or some mechanical parts of the lens assembly caused lens not to open or a motor controller itself, so better to find a cannon service center ear you.
Jan 05, 2011 | Canon PowerShot SD780 IS / IXUS 100 IS...
Partly open lens
the mechanical part that is trying to open the lens cover is having a problem
1. a lodged piece of foreign material
2. A broken piece within the camera is interfering
3. A piece in the camera that helps control the lens or another piece by the lens is out of place
Please check this out if you are comfortable doing so and let me know what comes of it
Thank you
Mar 31, 2008 | Canon PowerShot A540 Digital Camera
Camera will not power on with battery or ac
Theres a 1.6 amp fuse on the circuit board that needs replacement, and also two transistors kz 3 b1 and jp 3 b2, but I can't find the transistors online anywhere. If you find them tell me. Thanks.
Dec 28, 2009 | Canon PowerShot S50 Digital Camera
The lens cover on my Canon Power Shot A530 will not close completely. The camera still works fine, but I am concerned about damage to the lens. Is this fixable?
A stuck lens cover is a fairly common problem, but it is normally easy to fix. A single grain of sand jamming the cover mechanism is normally the culprit, and you want to try to dislodge it: 1) Try blowing lots of compressed air around the lens cover to clean the mechanism. Or use a hair dryer for a few seconds (don't want to heat up the camera). Use no heat mode if possible. 2) Slide a thin strip of paper between the lens cover shutters and the outer support ring. Work it around 360 degres to clear out any debris that may be in there. 3) With the lens barrel extended and pointed downward, tap the lens barrel with a pencil while you extend and retract the lens by powering the camera on and off. Repeat the above three steps several times. If repeated tries don't work (keeping in mind that it usually does), it then may be necessary to open the lens barrel to access the lens cover mechanism.
You can open the lens barrel up to fiix the covers, but only as a very last resort. The above procedures normally work if you try them enough. But for those particularly nasty stuck mechanisms, here's an example repair on a Canon Powershot A400 (do this at your own risk, and it will void your warranty).
Oct 13, 2009 | Canon PowerShot A530 Digital Camera
Internal problem of mechanism of lens assembly. May be caused by grain of sand, or anything else, probably you will have to let it repaired.
Sep 18, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Canon lens cover won't open
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jun 09, 2009 | Canon PowerShot A630 Digital Camera
Sliding Lens Door Problem -- Canon S50
I had the same problem with a S50, where the lens door would not operate properly and would not open enough to cause the camera to activate. I took it apart and found that there are two small gears that keep the door on track, one had split in half and jammed the mechanism. They were white plastic, perhaps nylon? I found another S50 on ebay with broken electronics but a working lens door and took parts from it to fix my system. Getting the tiny gear in place was tricky as there are several springs used to activate the camera on switch.
Jan 18, 2009 | Canon PowerShot S50 Digital Camera
Canon Powershot S50 -lens extends and then retracts
There is a common problem with the A series Powershots, that the lens assembly jams in the telescoping zoom, or in the digital imaging module, in which the lens assembly has to be replaced. I'm not sure if the S series has these issues. You can check with Canon support to find out.
Aug 08, 2008 | Canon PowerShot S50 Digital Camera
Canon sliding lens cover door
I have been having the same problem. Once opened, the sliding door will not close and the lens won't retract. But I have found that if you plug the camera into a computer via a USB, the lens then retracts enabling you to close the lens cover.
I'm still trying to find a way to fix this problem, since this is a great camers and still takes fantastic pictures.
Apr 21, 2008 | Canon PowerShot S50 Digital Camera
Lens cover slide stuck closed
Take a butter knife and slide it where the crease is. move the close/open button till it open it could just be stuck due to moisture. Hope this helps.
Mar 09, 2008 | Canon PowerShot S70 Digital Camera
Cameras Logo
93 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
