Question about Sony UP DR100 Thermal Photo Printer
Mecha Error 0005
When I turn my printer on everything is fine, until I go to print a photo on my Sony DR-100 thermal printer. When I go to print, it makes noises then comes up with a mecha 0005 error.
    Problem Solver:
  • 17 Answers
Oooohhhh k
1) when you turn the printer on does the printer make a lot a noise and then display "ready"
-If not there may be mechanical issues with your printer
Posted on Mar 12, 2009
Mecha error 02 605
kodak 605 mecha error 02 how a problem solving
Aug 31, 2013 | Kodak 6800 Thermal Photo Printer
Mecha trouble problem cutter pos
- in my case I received the error "mecha trouble cutter pos"
I removed both side panels and the panel directly in front of the cutter
this gave me access to the cutter assembly where I found that the cable that runs the cutter had fallen off of the pulleys.
I was able to get the cable back onto the pulleys and now the printer works perfectly
Feb 20, 2012 | Sony UPDR150 Thermal Photo Printer
I'm getting a "Mecha Trouble
checking the gear by taking off both side panels and the panel directly in front of the cutter helped me - in my case I received the error "mecha trouble cutter pos"
problem was, the cable that runs the cutter had fallen off of the pulleys and after a bit of fussing, I was able to get the cable back in place and a working printer.
Sep 15, 2011 | Sony UPDR150 Thermal Photo Printer
Mech error 12 in kodak 6800
Mech error 11 in kodak Problem with the Kodak Photo Printer 6800 Thermal
Sep 18, 2010 | Kodak 6800 Thermal Photo Printer
Me presenta mecha error 12 que sera por favor ayuda gracias
mecha error 11 o 12 significa k algo pasa con la cuchilla, debes de desarmar la impresora y ver si hay algo que la este trabando
Jul 09, 2010 | Kodak 6800 Thermal Photo Printer
MECHA ERROR 003
i need best solution for mecha error 03 kodak printer 6800
Mar 15, 2010 | Kodak 6800 Thermal Photo Printer
Kodak printer 6800 mecha error 11
this is error created at ur printers cuter unit , so open the frot cover and clean the all 3 sensors
Jul 03, 2009 | Kodak 6800 Thermal Photo Printer
Mecha error o3
Mecha error 03 is a malfunction of the main pinch motor. Ninety-Five percent of the time the problem is that the motor has failed. The machine will more than likely have to be sent in for maintenance.
Nov 27, 2008 | Kodak 6800 Thermal Photo Printer
Sony up-dr 100 error 0007
This may well be a failure of the cutter switch sensor to reset. This worked for me.
Turn Off the Printer.
Remove both side panels and the plastic panel on the INSIDE of the DOOR on the right hand side. Then close the door and remove the plastic panel UNDER the door. This is held in place by two screws.
You will see a white gear on the bottom right hand side of the door. It is on the underside of the door. Turn this gear untill you can see the cutter move smoothly across the bottm of the door and return to the right side of the door. Listen for a click. This is the switch resetting. Close the door and power up the printer if you still get an error code 0008 or 0007 repeat the resetting process by turning the gear. BE SURE TO TURN OFF THE PRINTER!!
Dec 11, 2007 | Sony UP DR100 Thermal Photo Printer
Sony UP DR100 Thermal Photo Printer Logo
262 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
