Question about Innovage Touch-panel Phone 1502084
I cant get the caller id on
I pressed set, than up, than the eight, than set again and it never tells me the on or off. What do i have to do? is there somthing im missing...? Also can you change the little song on hold...?
  • chesneg Nov 15, 2008
    no number displays on the screen, and the talking feature not working either
How to change the ring
Posted on Dec 17, 2008
When phone rings it used to announce the caller ID, but now it doesn't.
Hi Steve
Find "Caller ID"
Press the phone icon.
Press the menu icon.
Press Call settings.
Press Additional call settings.
After a moment the current settings are displayed.
Press Caller ID. Turn your own caller identification on or off
Press Hide number or Show number. Return to the home screen
Press the home icon to return to the home screen.
May 10, 2016 | LG G3 VS985 32GB Verizon wireless CDMA /...
HOW TO GET CALLER FOR MY PARTNER 18 D PHONE
Please press "Feature 59" on a display phone. That will tell us the release of the phone system. Your system may not be caller ID capable. The reason you are getting caller id on your cell, when the phones are forwarded is because you are paying for caller ID on your cell phone....and your cell phone is caller ID capable.
Jun 04, 2009 | Avaya Corded Phone avaparp18d
How to set date and time
Voice Time/Day Stamp
1. Make sure the answering system is ON.
2. Press flash/answerer/call waiting button on the handset to enter answerer remote mode.
3. Press key [8] to enter Time/Day set menu on handset.
4. To set Hour, key in [00]-[12].
5. To set Minutes, key in [00]-[59].
6. To set AM/PM, press the CALLER ID-VOLUME (5or6) button.
7. Press #PAUSE/ringer button to confirm the setting.
8. Press Caller ID-Volume to set Day
9. Press #Pause to Confirm
10. Phone will then Announce the Day & Time
Feb 02, 2009 | GE 25932 Cordless Phone
KX-TG6052 two handsets. Can't get Talking-Caller ID to turn off!
to turn the talking caller id off go to the menu press 0 then * then 4, then press 0 again to select off.
to turn the ringer on the handset back on, go to the menu, prees 1, 1, then press 1 for a low ringer, 2 for medium and 3 for high.
Mar 15, 2008 | Panasonic KX-TG6052B Phone
Blue light
Press the mute/program button, then press the caller ID-volume button to select handset setup (then press mute/program again to select this option). Next press tye caller ID-volume until you get to Default settings (its the last setting so pressing the up arrow is the fastest way to it). Press the mute/program button again to select the option. Use the caller ID-volume button to select 1yes. This will return the phone to the factory settings and for took care of the blinking blue light, however you will loose any custom setting or numbers you entered.
The first time I did this it didn't work, so I did again and toward the end of the steps above the phone beeped at me and stated "Reset Default Settings" (or something like that) then time I hit the mute/program button again and everything worked great. I think that last beep maybe have been a are you sure you want to restore to default question.
Remember tis will erase any custome settings you made on the phone (ring tones, ring volume, memory, etc.)
Jan 31, 2008 | GE 28111 Cordless Phone
Cant get the talking caller Id
I lost the talking caller id after a thunderstorm. Can you tell me how to program it? I don't have a maual.
thank you.
Jan 13, 2008 | Sakar HT-848CL Corded Phone
Phone does not ring or show caller ID
From extension 10 or 11.
Press feature 00
Press left intercom twice
Then right intercom once.
enter your extension number
You will see the lights blinking green on the phone, where your lines are. Touch them until they are solid green. If you want to program another extension, press the right intercom button again and enter the new extension number.
Once done, press feature 00 to exit programming.
As far as the caller ID, there is no way to turn it off on the Partner system. My guess is the provider isn't sending caller ID.
Jan 04, 2008 | Lucent PARTNER18 Corded Phone
How do I view caller ID?
The KX-T7731 is a proprietary system phone. You have a Panasonic phone system. Caller ID is transmitted between the first and second ring but the phone system itself is the only part that gets this information. The system has to be compatible for caller ID and it has to collect the caller ID data and send this information to your phone(s). Your phone can be used on many different Panasonic phone systems. The phone's part number does not help you. First thing you need to do is find out what system you have and if it has caller ID. The phone system part number should start with KXT like your phone.
Sep 17, 2007 | Panasonic KX-T7731 Corded Phone
Caller ID doesn`t talk
only thing i can think is the IP function might be on. ( and of course, u do have the caller id through the phone company activated, right,,,,just checkin) . this funtion is not available in the USA. to turn it off, press SET/SAVE, press UP to select SET 4 AUTO IP, press SET/SAVE to select, press UP to turn on and off, then press SET/SAVE to confirm. hit DELETE to return to main screen. hope that helps.
tammy
Aug 29, 2007 | Innovage Speaker/Caller ID* LCD Touch...
Blinking blue light
Press the mute/program button, then press the caller ID-volume button to select handset setup. Next press caller ID-volume until you get to Default settings. Use the caller ID-volume button to select 1yes. This will return the phone to the factory settings and for took care of the blinking blue light, however you will loose any custom setting or numbers you entered.
Jul 10, 2007 | GE 28111 Cordless Phone
Innovage Touch-panel Phone 1502084 Logo
Top Innovage Lands Phones Experts
wiccan8thhouse
wiccan8thhouse
Computer Repairing
Computer Repairing
george  peters
george peters
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
