Question about O2 Xda Atom Exec Smartphone
My o2 xda atom doesn't charge. i don't know if its the battery.
I just bought from my friend his xda atom.. i've charged it over night but then when i removed it from the charger, it shuts down... and the battery meter doesn't go up... i don't know if the problem is my battery or the charger... what shall i do? thanks...
  • 3 Answers
I think the problem is your battery... and you think that your battery is OK then you can try charging it the computer through USB.
Posted on Nov 13, 2008
O2 xda atom mobile problem
This is the most common problem with all the mobile phones. You can fix the same on your own. I advice you to buy a alcohol based cleaner (WD40) and clean the battery leads as well the leads on the phone. Then take out the panel and clean the ringer speaker terminals with the same. Make sure the battery should be good enough to retain the charge to drive the phone.
Jul 10, 2009 | O2 Xda Atom Exec Smartphone
HELP!!!! O2 XDA ATOM
push the reset button at bottom if no use hard reset by cam+reset button.
Nov 03, 2008 | O2 Xda Atom
O2 Xda Exec
It appears it has something to do with the flash continuely trying to operate. When charging (Red LED blinking in quick succession) the flash can be conitnuely seen to be operating.
Doesn't fix the problem but I think this is the cause
May 26, 2008 | O2 Xda Atom Exec Smartphone
While charging my O2 atom exec, the LED (Flash light) does not glow red ?
I have the same problem. What I did several time is to actually shut down the phone, remove the battery and leave it like that for several hours (3 to 4 hours). Then, I put the battery back in the phone, and it would charge again. However, due to the long time with no battery, the phone's clock would be reset to January 2007.
I found no other work around right now. However, I have to do this more and more often, almost once a week ...
Mar 21, 2008 | O2 Xda Atom Exec Smartphone
O2 atom battery won't charge
I would suggest you to buy a new battery, since the one you have is 2 years old. If that doesnot solve the problem, you could try checking the mini connector on the phone. Sometimes, due to heavy usage (connect and reconnect to the jack) it is damage/loose. Try bring them to a repair shop.
Jan 26, 2008 | O2 Xda Atom
My o2 celphone won't turn on
O2 XDA Atom / O2 XDA Atom Pure / HP rw6828:
To perform a hard reset, use the stylus while pressing into the reset hole, press the power on/off button at the same time. Screen will prompt you to press the Green call and Red end call button together to confirm on hard resetting the device.
*Note: Hard resetting the device will cause the device to be reset back to its original factory default settings and all data will be lost.
i hope it will help your prob.
Dec 01, 2007 | O2 XDA Mini S Smartphone
Water issues
Not repairable through warranty sorry
Jul 13, 2007 | O2 Xda Atom
Battery problem
preform a soft and if necessary a hard reset back info to pc first http://www.pdacortex.com/pocket_pc_sites.htm Pocket PC Sites
May 10, 2007 | O2 Xda Atom
O2 Xda Atom Exec Smartphone Logo
194 people viewed this question
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
zurysk8
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
