Fujitsu PlasmaVision P50XHA40US 50 in. HD-Ready Television Logo
A
Anonymous Posted on Apr 13, 2012
Connecting external sound bar to Fujitsu plasmavision
CONNECTING A SOUND BAR TO THE MONITOR
4 Related Answers
Anonymous
  • 124 Answers
  • Posted on Nov 02, 2008
SOURCE: Fujitsu Plasmavision 55"
Hi, The problem comes from the power supply board. The power supply board is a three phase unit. One phase on the power supply failed, that would be the reason for the no picture. You can have the power supply board repair or replace. If you are within the manufacturer warranty, they "should" replace the part ( power supply board) at no cost to you. Mike
Anonymous
  • Posted on Jan 26, 2010
SOURCE: Stuck on Standby, Fujitsu Plasmavision: Model pds4229e-b
I had exactly the same problem with a Fujitsu General PDS4208E. After looking at the forums etc bit the bullet and tracked down an ORIGINAL remote. Paid yesterday, arrived today - batteries in...screen back on!! One proviso here: Before you pay big money for an original remote (and ONLY they will work with these 2nd generation plasma screens not universal remotes) make sure that your screen WAS working before it was in the standby mode. try http://www.portables.co.uk/ on +44 208 968 1444. Ask for Andy. He seemed to know what he was talking about. About £50 +VAT plus next day delivery charge. Alternatively borrow mine at £5 a button press!! ;-))
Anonymous
  • Posted on Sep 21, 2011
SOURCE: Picture but not sound on my Fujitsu Plasmavision.
Picture but not sound on my Fujitsu Plasmavision. TV used to be hooked into a control 4 system that handled sound but now no system is attached. Help! Tried adjusting the sound settings for a while last night to no avail.
Anonymous
  • 2098 Answers
May I know if you haven't a sound in all inputs?
If you hooked up the sound input to other system before, you must hooked up now the audio input at the back of your TV to get the sound.
Please double check the audio hooked up at the back panel of your TV, try to hooked it first on Audio1 input, then to Audio2 input, and finally to Audio3 input.
Jdvillanueva
No audio on plasmavision
Simple things if no sound are speakers connected or turned off?
Does the set have sound with a DVD player connected to a rear audio and video input?
Picture but not sound on my Fujitsu Plasmavision. TV used to be hooked into a control 4 system that handled sound but now no system is attached. Help! Tried adjusting the sound settings for a while last...
1helpful
We have our cable box hooked up to the tv and get a great picture but no sound. The previous owners had a stereo system hooked up to the tv and we are simply trying to get any sound at all. We went into...
Ok, I need more verifications:
1) Your TV is Fujitsu Siemens PlasmaVision P42VHA40 Monitor which does not have tuner? If not, please provide the make and model of the TV.
2) What kind of cables you are using to hook between the cable box and the TV? HDMI? Component video (Red, Blue, and Green cables withe RCA plugs)? Composite video cable with Yellow RCA plugs?
3) Are you trying to get the sound to come out off the TV speakers or through the stereo system?
Plasmavision P42HHA10 42 in. Television: how do i get the external speakers to work ?...
Just connect speakers directly to the audio output connectors at rear of display. Ensure display's audio volume is set mid range (and not muted).
I have a fujitsu 42" pds4229e-b and trying to set my wii up on it but when useing the video component conections i can only get a black & white picture and no sound any ideas?? i don't have a remote at...
Have you got component cables specially for the wii? if so, then the screen should work fine.
As for audio. You'll need to use separate RCA's Red and white into the audio input if your using external speakers, if your using a surround sound amp then put them into the input there.
1helpful
Vertical bar about 3/4" from top to bottom of monitor
panel is done. economical to repair. new panel is about 90 percent the cost of the tv new
1helpful
How do i set up my nintendo wii to a fujistu plasmavision
http://www.plasmavision.com/Plasma_PDF/OMP50XHA(42VHHA)Home.pdf this is the users manual for your componant under usage refer to connecting external equipment to display thanks for stopping bye at fixya!
Top Fujitsu Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
