Question about Lenovo ThinkPad T61 Notebook
Game Says I Fail Minimum Video Card Reqs
I have a Intel GMA X3100 video card intstalled in my Lenovo T61
Which I believe is sufficient for a 128 MB Video Card, with support for Pixel Shader 2.0--- this is the requirement for the game.
And yet the game says it fails the minimum requirements
  • 928 Answers
It is quite possible that you may have to update the drivers for your video card. It is true that the device supports upto pixel shader 2.0 that is the DEVICE but if the DRIVER installed does not then the computer will not know how to use the video card in the right way. So update the driver and you should be ok.
Posted on Nov 13, 2008
Sims 3 wont install onto my powerbook G4
Sims 3 will not run on a mac that isn't using an Intel based processor. You will have to upgrade from a Power-PC processor in order to use the latest version of sims.
Oct 15, 2012 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Intel g41 express chipest not compatible
Sounds like your computer has an integrated video card and the game is looking for an extended graphics card. This type of card plugs into the motherboard via the AGP, PCI, or PCIE slots. Depending on the type of video card and computer, you may need to upgrade the power supply when you put the card in. If this is a laptop there is no good way to upgrade the video card.
Hope this was helpful
Feb 01, 2012 | Computers & Internet
Vice city game is not playing
Does your system support the following minimum requirements for playing the game?
800 MHz Intel Pentium III or 800 MHz AMD Athlon or 1.2GHz Intel Celeron or 1.2 GHz AMD Duron processor
128 MB of RAM
8 speed CD / DVD drive
915 MB of free hard disk space
(+ 635 MB if video card does NOT support DirectX Texture Compression)
32 MB video card with DirectX 9.0 compatible drivers ("GeForce" or better)
Sound Card with DirectX 9.0 compatible drivers Keyboard & Mouse
Your motherboard has Intel® Extreme Graphics 2 controller as the onboard graphics controller. Search the Internet whether it is capable of rendering the graphics in order to play the game and latest drivers for your onboard graphic card are installed.
Jun 03, 2011 | Intel D865GSA (BOXD865GSAL) Motherboard
I'm not sure if my computer can run starcraft 2 minimum settings are fine just not too much lag 2.1GHz processer Intel GMA 4500M
Unfortunately, it does not meet the minimum system requirements.
PC: Windows XP/Windows Vista/Windows 7 (Latest Service Packs) with DirectX 9.0c
2.6 GHz Pentium IV or equivalent AMD Athlon processor
128 MB PCIe NVIDIA GeForce 6600 GT or ATI Radeon 9800 PRO video card or better
Please comment if the information provided has been helpful for the improvement of my support assistance. Thank you and regards.
Aug 22, 2010 | Acer Computers & Internet
Sims 3 crashes
Hi. Well that is obvious if the memory as well as the virtual memory drops below the required level. Your VGA settings (Graphic Adapter) might also making the game crash. It is a good thing to disable AVG temporarily while you play the game. (Please let me know your System's specifications as well. Like RAM size, VGA size, Processor Speed and Hard Drive Capacity - Both free and used capacity. If you have default specs for the Dell I6400 no need to include). Otherwise it will use the memory and virtual memory to scan the activities of the game.
You have to keep some vacant area in your System Partition (In which you have install the Operating System). Virtual memory page file is 1.5 x the size of RAM. But you can increase the size. But you have to have a faster hard drive as well because it will be used more when you increase it. The other option is to upgrade your RAM (installing an additional RAM if the PC supports). Most of the modern games require way too high performance PCs. Most of the time RAM and VGA.
To increase the Virtual Memory:
  1. Right click on My Computer icon and go to Properties.
  2. Click on Advanced tab.
  3. Click on Settings under the category, Performance.
  4. Click on Advanced.
  5. Click on Change under Virtual Memory.
  6. Select a free Partition (Which had more than the size x 1.5 of your RAM)
  7. Select the option System Managed size if you do not wish to do it manually. If you want to configure manually, select the Custom size option and enter the size which I mentioned before in BOTH the boxes.
  8. Then click on SET.
  9. You may be asked to Reboot the machine. Do so if asked to.
  10. Then play he game.
  11. If possible please upgrade your RAM.
Sims 3 System Requirements are as follows:
  • FOR WINDOWS XP
  1. 2.0 GHz P4 processor or equivalent
  2. 1 GB RAM (512 should be enough however)
  3. 128 MB Video Card with support for Pixel Shader 2.0
  4. The latest version of DirectX 9.0c
  5. Microsoft Windows XP Service Pack 2
  6. This one is very important: At least 6.1 GB of hard drive space with at least 1 GB of additional space for custom content and saved games.
  • FOR WINDOWS VISTA
  1. 2.4 GHz P4 processor or equivalent
  2. 1.5 GB RAM
  3. 128 MB Video Card with support for Pixel Shader 2.0 (not enough)
  4. Microsoft Windows Vista Service Pack 1
  5. At least 6.1 GB of hard drive space with at least 1 GB of additional space for custom content and saved games
  6. For computers using built-in graphics chipsets under Windows, the game requires at least:
  • Intel Integrated Chipset, GMA 3-Series or above
  • 2.6 GHz Pentium D CPU, or 1.8 GHz Core 2 Duo, or equivalent
  • 0.5 GB additional RAM
  • FOR MAC OS X
  1. Mac OS X 10.5.7 Leopard or higher
  2. Intel Core Duo Processor
  3. 2 GB RAM
  4. ATI X1600 or Nvidia 7300 GT with 128 MB of Video RAM, or Intel Integrated GMA X3100.
  • This game will not run on PowerPC (G3/G4/G5) based Mac systems, or the GMA 950 class of integrated video cards.
Windows Supported Video Cards NVIDIA GeForce series FX 5900, FX 5950 6200, 6500, 6600, 6800 7200, 7300, 7600, 7800, 7900, 7950 8400, 8500, 8600, 8800 9300, 9400, 9500, 9600, 9800 G100, GT 120, GT 130, GTS 150 GTS 250, GTX 260, GTX 280, GTX 285, GTX 295 ATI Radeon™ series 9500, 9600, 9800 X300, X600, X700, X800, X850 X1300, X1600, X1800, X1900, X1950 2400, 2600, 2900 3450, 3650, 3850, 3870 4850, 4870
Intel® Graphics Media Accelerator (GMA) GMA 3-Series, GMA 4-Series
Laptop versions of these chipsets may work, but may run comparatively slower. Standalone cards that are installed in vanilla PCI slots (not PCIe or PCIx or AGP), such as some GeForce FX variants, will perform poorly.
Integrated chipsets such as the ATI Xpress and the NVIDIA TurboCache variants may default to settings that are higher than what would be optimal for them. Graphics settings can be lowered to improve performance.
The NVIDIA GeForce FX series is unsupported under Vista. MAC OS X Supported Video Cards NVIDIA GeForce series 7300, 7600 8600, 8800 9400M, 9600M GT GT 120, GT 130 ATI Radeon™ series X1600, X1900 2400, 2600 3870 4850, 4870 Intel® Graphics Media Accelerator (GMA) GMA 3-Series.
So make sure to meet at least the minimum requirements.
Enjoy Gaming.
Please feel free to ask anything related to this. Please rate the answer as well if you feel that it helped to solve the issue.
Thanks for contacting Fixya!
Jul 10, 2010 | Dell Inspiron 6400 Notebook
Video card....
Most cheaper laptops do not include a full-blown graphics board with expensive dedicated graphics memory. Instead, system memory is shared between the CPU and the graphics subsystem.
How much memory actually is reserved for graphics purposes depends on the software you are running. The frame buffer (the memory used to store the pixels on your desktop) is only part of it - games, for example use a lot of memory to store textures and geometry data.
  • Minimum Graphics Memory: 128 MB
    The smallest memory size your system must reserve for CPU/Graphics sharing.
  • Maximum Graphics Memory: 1341 MB
    The largest chunk your system can configure for sharing.
From the DirectX report you can see, it currently uses 27 MB only.
Your laptop lacks the CPU and graphics power to run high demand games anyway, so 128 MB of shared memory should be sufficient. You can configure this to 256 or 512 MB in the BIOS configuration menu, but I doubt it will make any noticeable difference for you.
Feb 07, 2010 | Toshiba Satellite Laptop
PC will not run Sims3. DO I need a graphics card? if so, what type of card?
Hi friend The SIMS 3 minimum hardware requirements are:
1. FOR WINDOWS XP
* Windows XP (Service Pack 2)
* 2.0 GHz P4 processor or equivalent
* 1 GB RAM
* At least 6.5 GB of hard drive space with at least 1 GB additional space for custom content
* 128 MB Video Card with support for Pixel Shader 2.0
2. FOR WINDOWS VISTA
* Windows Vista (Service Pack 1)
* 2.4 GHz P4 processor or equivalent
* 1.5 GB RAM
For computers using built-in graphics chipsets, the game requires at least:
* Intel Integrated Chipset, GMA X3000 or above.
* 2.6 GHz Pentium D CPU, or 1.8 GHz Core 2 Duo, or equivalent
* 0.5 GB additional RAM
SUPPORTED VIDEO CARDS
FX 5900, FX 5950
6200, 6500, 6600, 6800,
9600, 9800, GTX 260, GTX 280
OR
ATI Radeon™ series
9500, 9600, 9800
2400, 2600, 2900
3450, 3650, 3850, 3870,
4850, 4870
OR
GMA X3x00 series
Please cross check your system with this requirements and upgrade accordingly.
I hope this will help you out. Plz vote for me.
Thanks
Oct 06, 2009 | EA - Electronic Arts Sims: Complete...
I am lookng for a increase in graphics in my acer aspire 4315
The video card is part of the motherboard and cannot be up graded.
The video RAM uses part of the main RAM but you might be able to increase the allocated video RAM to the max configuration in the BIOS.
Refer to the video specs I copied for you.
Video
  • Graphics Processor / Vendor Intel GMA X3100
  • Video Memory Dynamic Video Memory Technology 4.0
  • Max Allocated RAM Size 358.0 MB
Aug 12, 2009 | Acer Computers & Internet
Cant get sims 3 to work on laptop
Could be your laptop doesn't have the necessary horsepower to run SIMS 3 (mine doesn't)
THE SIMS 3 MINIMUM HARDWARE REQUIREMENTS
FOR WINDOWS XP
* 1 GB RAM
FOR WINDOWS VISTA
* 1.5 GB RAM
FX 5900, FX 5950
ATI Radeon™ series
9500, 9600, 9800
2400, 2600, 2900
4850, 4870
GMA X3x00 series
Jul 05, 2009 | Acer Aspire 3690 Notebook
Video card
the requirements are
FOR WINDOWS XP
  • Windows XP (Service Pack 2)
  • 2.0 GHz P4 processor or equivalent
  • 1 GB RAM
  • At least 6.5 GB of hard drive space with at least 1 GB additional space for custom content
  • 128 MB Video Card with support for Pixel Shader 2.0
FOR WINDOWS VISTA
  • Windows Vista (Service Pack 1)
  • 2.4 GHz P4 processor or equivalent
  • 1.5 GB RAM
  • Intel Integrated Chipset, GMA X3000 or above.
So what does your computer have?
Jun 02, 2009 | Microsoft Windows XP Home Edition
Lenovo ThinkPad T61 Notebook Logo
153 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
