Question about Homelite Consumer Products MightyLite Handheld Gas Blower with Quicker, Easier Starting
Cant keep my mccollough airstreamIV running please help!!!!!!
Every time start it with ether, it starts and then it dies. I checked the spark plug and put tIhe right mix in it ,but it still dies and acts like it doesn't get gas. I also checked the air filter and sprayed carb and choke cleaner in it (nothing).
  • 4 Answers
First of all NEVER use ether on any 2 stroke engine . it sounds like u have a carb thats clogged but be for u do n e thing u r going to have to do a compression test on the unit .it needs to be a min of 130 psi if its below that u need to replace the piston rings and cylinder head . u might wanna get a new one if thats the case! when u have a 2 stroke its very important that the gas mixture is perfect and u have to shake the gas be for u use it . that will make the unit last 4 a long time ehter will kill the machine fast
Posted on Nov 14, 2008
My 359 etech will start running bad after cuting one or two sticks of wood then die. If it sets until the next day It will again start. It has a good blue spark even when it won't run. It won't even...
If it still has a good spark it must be a fuel issue, replace the filter in the fuel tank check the fuel hose up to the carb for cracks or splits, if this does not help the next step is to service the carb, let me know if you need help with this.
Apr 03, 2011 | Husqvarna Garden
The bike is a 2005 suzuki 125 dr-z. it has had problems for a while now. we took it in the shop 3 times already and it is the same story everytime... we get it back home and it runs like a dream and then...
There is a big possibility that there is a fault in the cdi unit or it is to do with engine firing. So basically something wrong to do with electricity from magneto up to the spark plug. It is quite a difficult thing to spot as there is no ECU like new vehicles which can tell you more exactly where the fault is. It is more to do in terms of trial and error, like changing parts and test until you find the cause of the problem. A good idea is to find another bike of the like to like model and swap parts around and test. Hope this helps and good luck with this.
Sep 25, 2010 | 2004 Suzuki DR-Z 125 L
1999 Dodge Intrepid 2.7L Replaced starter,
If there isn't much pressure, cycle the ignition without turning the engine over and try again. If it is still weak, you may need a new fuel filter. If it is strong, you may have dirty or clogged fuel injectors.
It may be spark, but I'm inclined to think it is fuel related.
Good luck, and keep us in the loop!
JT
Mar 15, 2010 | 1999 Dodge Intrepid
Wont start
Hi and welcome to FixYa,
Appreciate the direct "Ask Me".
Your described problem based on the bike being a 1982 model could be varied, among them are:
  • weak spark - not necessarily weak battery. Culprits could be loose loose connector to the CDI, low IGN +12 to the + terminal of the coil (check with a voltmeter while just switch on and when cranking/starting), or even a loose ground terminal. Check spark by removing plugs, reconnect the plugwires, let the threaded end touch metal part of engine, crank. Sparks should be strong;
  • corroded/poor contacts in the ignition switch resulting to the above. You can test by running a jumper wire straight from the battery to the + terminals of the ignition coil;
  • too lean air/fuel - plugs should be brownish in color;
  • air or vacuum leak - resulting to the above and high or poor idling;
  • unbalanced carbs - carb check/clean, verify air adjustment screw number of turns,
  • compression low - have a compression check.
Would look forward to your updates. Good luck and thank you for using FixYa.
Feb 02, 2009 | 1982 Suzuki Gs 550 L
** Help Starting **Yard Machine 21inches 139cc
amiseybold;
First check for spark. Remove the spark plug. Leave the spark wire connected. Hold the plug against the metal of the mower engine so you have a ground and can see the gap of the electrode where the spark jumps across. Have someone pull the starter cord and verify that you have a spark. Hold it by the threads of the plug so you don't get a little spark jolt yourself.
go to an auto parts store and get a can of starter spray (it's actually ether), Remove the lawnmower spark plug and spray a little ether in the plug hole. Put the plug back and tighten it and see if it starts.
It will probably start, run for 5 or 10 seconds and then die. Repeat this procedure once or twice again and eventually it will start to draw gas from the lawnmower tank.
A seasonal tip. when you put the mower up for the winter, **** the remaining gas out of the tank, start the engine and let it run until it uses up the gas in the carburetor. This will make iot much easier to start in the spring
Hope this helps Good Luck Loringh PS Please give me a rating
Nov 08, 2008 | Yard Machines 158cc Push Lawn Mower #11a...
Won`t crank
check your fuel pressure and also check your plug gaps and make sure you have a stong spark, you say it stays running once started on ether? does it run well or poorly? is it drivable or not please explain in more detail -please rate -jeff
Aug 16, 2008 | 1994 Oldsmobile Achieva Special Edition
Buick lesabre nightmare
Need to get a scan tool and look at the data stream while it is running for alot more info.Also any trouble codes.Sounds like initially,the engine isn't getting any fuel.I would have a pressure gauge connected to the fuel rail on the engine,so i could monitor the fuel pressure while all this is going on.Items to look at on the data stream would be timing,what timing is the PCM commanding for the engine.Also,have you checked for continuos power feed to the coils during this no start condition,and fire at the plugs while cranking.You could possibly still have spark,but maybe it is extremely weak?I have seen bad ignition switches cause weird problems before too.Many things power up through the ignition switch,just a thought.Have also seen bad PCM's cause strange problems..38 volts is a little on the low side for GM.Usually see those at,at least .50 and up,and rise steadily while pressing the throttle,up to just under 5.0 volts.Potentiometer with 5 volt supply.Vacuum leak can be checked with engine running at a steady idle speed,spray brake cleaner all around the intake manifold and listen for engine speed change.
Jul 31, 2008 | 1992 Buick LeSabre
Saab 900i 1992 model won't Start
sounds like a fuel problem check for spark and try to get the car running on ehter (aerosol starting fluid) spray it into the air intake (makesure not to spray the filter just take it out) and have a helping hand turn the key if the car runs, then its a fuel problem prbly the fuel pump, NOTE: When running only on ether the car will sound very funny this is normal, IF the car wont start problems are elsewhere such as a timing belt slipping, no spark, no compression, Bad coil, weak starter, bad valve ect etc HOPETHIS HELPS feel free to e-mail me at fixya@whypayforhelp.org
Jun 19, 2008 | 1998 Saab 900
Homelite Consumer Products MightyLite Handheld Gas Blower with Quicker, Easier Starting Logo
99 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
