Question about Panasonic CX-DP801 8-Disc CD Changer
I receive error msg and cant eject magazine
As soon as I turn on the cd player, via the remote, I get error msg "E3" and nothing happens. The cd magazine also will not eject. It seems as though the problem is in the position of the cd magazine. Its jammed somehow. Is there an emergency release trigger somewhere to eject the magazine manually?
  • 1994Civic Mar 19, 2008
    Same problem as many others. After trying to read the CD, it then displays a "E3" error message. And, unless I unplug the unit, it won't eject.
  • 8310chev Apr 24, 2008
    i have the same problem i put in magazine cartridge, it will play the first 2 or 3 cd's then the error "E3" will show on remote and it won't play anymore. so far i have always been able to get the catridge out by putting a paper clip in the small hole that is about 1 inch away from blue eject button and pressing it in until i feel something reset inside, i tried scraping the edges of new cd's and using a disk cleaned but still have the same error ploblem
    Problem Solver:
  • 4 Answers
The magazine in our Sony CD player would not eject. I tried pressing two buttons at the same time etc., with no result. I uplugged the player, removed the screws that hold the black metal cover on and took off the cover (pull the metal up, out and away at the back bottom sides, then slide it back to release the lip from under the front pane.) Looked down inside and saw the problem, a CD disc extended about 1/2 inch from the magazine, blocking ejection. I pushed the extended edge of the disc back into the magazine with the tip of a kitchen knife. Plugged the player back in, pushed power and then the eject button, and the magazine ejected. Replaced the metal cover and it works fine. If it won't eject again I know what to do. Be sure to unplug before you work, you don't need an electrical shock.
All the best, Sonia Murray
Posted on May 06, 2008
LG DVD player LH-D6230 - displays "dvd error" soon
Eprom corruption. Replace eprom, and edit in mode service.
Jan 07, 2011 | LG Audio Players & Recorders
2005 s40 cd(holds 6) player stuck - reads deck error?
that is one of worse nightmare when you have a magazine loader in the systems when the cd get stuck. its common to all cd player some has better luck than others, Only thing I recommend is to take it to your local stereo shop or do it your self taking the unit apart and remove the cd. Keep in mind, when having magazine loader, some of the older unit will not read the new format or burn disk and it will read no disk or error and the cd will get lock. if the unit cant read the cd, majority of the time its does recognize there is a cd in unit. try tuning on and off couple of time and keep pressing eject button. you may have to do it 8-10 times to see if that will release the stuck cd.
Aug 27, 2009 | Car Audio & Video
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
CD ERROR DISPLAYS
CD Changers
E01:
E02:
E04:
upside down
WAIT:
Jun 14, 2009 | iLO CA3000V CD Player
CDC-3 magazine will not eject nor play, error on receiver indicates magazine error
1998 porchea boxter cdc-3 cd changer, The cd changer keeps on changing tracks as if their are no cd's in the changer. keeps going from 1 to 6 and then changes to radio.
May 19, 2009 | Becker Car Audio & Video
Can't eject cd magazine - E-99 error message
I put a small pin in the reset button a few times and that then got the catridge to eject.
Apr 14, 2009 | Car Audio & Video
I had the same problem. I opened up the unit and found out that there is a plastic gear that moves the loader. When worn the loader can not load tha magazines nor change cd's. I replaced the gear and the cd autochanger worked fine.
Gerald,
Kenya.
Dec 01, 2008 | Kenwood KDC-C717 10-Disc CD Changer
Kenwood KDC-C717 - E-99 error
Reset the unit ithe reset button is on the cd changer
Dec 01, 2008 | Kenwood KDC-MP205 CD Player
Error 99 displayed on cd player. CD player is a Denon DCH-520.
Normally you just hold down the eject button on your stock head unit and it resets the mico computer
Dec 12, 2007 | Denon Audio Players & Recorders
Toyota dashboard CD player won't eject
I had this say problem with my 2000 solara. Here is the fix, remove one of the car battery terminals for a couple of mins (3-4mins). The reattach the battery terminal back. This would make your cd player and car clock reset. once you start your car you should be able to eject the cds. You'll just need to reprogram all your preset radio station. Hope it helps
Oct 04, 2007 | 2003 Toyota Celica
Panasonic CX-DP801 8-Disc CD Changer Logo
1,527 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
