Question about Fujitsu Plasmavision P42HHA10 42 in. Television
Fujitsu Plasma Automatic turn off after 5 mins
My Plasma automatic turn off after 5 mins. When it turn off I can not turn on any more. Usually I have to wait 20 mins or more then TV can be turn on again.
  • 3 Answers
May be too Y-MAIN or X-MAIN damaged, must use freezer for cooling parts (open cover)
Posted on Mar 17, 2009
Faulty power supply usually
Posted on Oct 24, 2007
  • 534 Answers
Fujitsu have issued Service Bulletin covering these shutdown problems- see link below :-
http://tomtom2k5.free.fr/fujitsu/PDP-0035-06.pdf
I suggest implementation of this bulletin by a service technician may cure your problem.
Posted on Jun 02, 2009
  • John Bloomfield Sep 02, 2009
    See recent Fixya P42HHA service tips for this model.
    It may assist fix of your problem. JohnB1111
I have a reverse cycle 4 year old fujitsu air con and when I turn it on it automatically just blows air not cold air - it seems to divert to sleep almost immediately can u help.
It should still be in warranty as Fujitsu usually goes for 5 years. Get in touch with Fujitsu to find a local warranty agent. There's not enough info in your post for a diagnosis. Are the lights flashing? If so, what sequence are they flashing? Does the indoor unit otherwise work normally in 'fan' mode? What model do you have?
Jan 13, 2018 | Fujitsu Heating & Cooling
Head lights wont turn off even if the keys are removed
Can be caused by the switch or the relay. Cannot say more without knowing model and year.
Nov 08, 2017 | Cars & Trucks
Are 1996 4x4 jeep an 1994 4x4 jeep transmissions compatible with each other?
well both transmission have a name. as does car.
there are many offered new.
stick shift or auto.
what jeep you never said which one,
the wranger, the cherokee or the grand?
what? (a 96 wranger is 95 , they skipped 96 year)
ill roll the 3 sided dice for you and lands on XJ
amazing huh? that many.! min had #3 and other jeep has #2
4-speed Aisin AX-4 manual
5-speed Aisin AX-5 manual
5-speed Peugeot BA-10/5 manual
5-speed Aisin AX-15 manual
5-speed NVG NV3550 manual
3-speed Chrysler A904 automatic
3-speed 30RH automatic
4-speed Aisin AW-4 automatic
Aug 27, 2015 | Jeep Cars & Trucks
ASTA09JEC Fujitsu model number operation light not on but time light (red/orange) flashing turns on then turns off automatically I have tried the reset button and turned the timer off on the remote
This is a serial signal error which means the outdoor unit is not talking to the indoor unit or vice versa. Most likely the outdoor board is stuffed but you need to count how many times the timer flashes to be absolutely sure which error it is. If you turn power off at the isolator for 5 mins then restart, this can sometimes clear an error caused by power supply fluctuations. If not, you will have to replace one of the boards. Indoor board allow around $200 - $250, outdoor board allow around $300 - $400.
May 09, 2015 | Fujitsu Heating & Cooling
How to change time on a Kindle
The Kindle Fire is usually set to automatic date and time sync, this is how to override the automatic time set on the Kindle Fire.
Step 1: Pickup the Kindle, unlock if the device is locked
Step 2: Pull down the upper status Bar
Step 3: Select Date and Time
Step 4: Turn "Automatic" to Off
Step 5: You may now set the date or time by selecting the appropriate submenu item below "Automatic"
Apr 21, 2013 | Amazon Kindle Fire HD
I was installing a windows updtae and my laptop locked up. I couldn't get the ntask manager to respond at all. So I turned it off, waited 5 mins then turned it back on and all I have is a blank screen...
it usually happens if the OS is not genuine, the update contains some patch that blocks the OS from starting. U have to reinstall the OS again,and make sure ur automatic update is turned off.
however if u were using a genuine windows OS this should not happen. cant figure
Dec 08, 2010 | HP Pavilion dv6000z Notebook
My heater/blower on my 2003 Impala will not start right away. Usually, I drive for like 5 minutes and then it will go on. When I turn the car off, the same thing happens -- I have to wait 5 mins or so for...
If it has automatic climate control this is normal. The blower motor will not come on until there is heat for it to actually blow. During the first few minutes of driving you would only get cold air if it was blowing as the engine coolant has not warmed up. You should be able to set it to manual control.
Nov 27, 2010 | 2003 Chevrolet Impala
42" Fujitsu Plasma TV (About 10 yrs old)
You have not fully identified the model number of your unit, but
this is most likely caused by the Main Power pcb.
For models P42HHxxxxx and P42HCxxxxx see Fujitsu Service Bulletin on this problem. -see link below
A competent service technician should be able to implement the service bulletin.
Sep 29, 2008 | Fujitsu Plasmavision 42" TV
My panasonic tv got problem
when it is warm, shut off, then after take a rest it will automatic on again, probably you need change the on anf off switch.
How long have you had the TV?
Jul 10, 2008 | Panasonic TH-42PX75U 42 in. Plasma...
Fujitsu Plasmavision P42HHA10 42 in. Television Logo
517 people viewed this question
Top Fujitsu Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Fujitsu Televison and Video Expert? Answer questions, earn points and help others
