Question about NetGear DG834G Router
My iternet was working and now it doesnt
I am using a netgear dg834g and i can connect to it throw a cable and throw wireless and when i conect to it and use the router status page it tells me the router is conected to the internet and is conected to my pc but my computer cannot conect to the inernet still. it says local only.
    Genius:
  • 1,124 Answers
Test connection, see if you pulled an IP address
Go to the Windows desktop
Select Start then Run
In the text box type: cmd (WIN98/SE type command)
At the command prompt type: ipconfig
4. What does it read as the IP address?
* If it reads 192.168. something dot something then you are pulling
an IP address and are connected to the network. The problem is
software related, check your firewall, and wireless card configuration.
Also check any WPA or WEP encryption keys. Check with the respective
manufactures.
* If it reads 0.0.0.0 for the IP address you are not connected to the network.
* Check your connection configuration and the adaptor.
* Check with the respective manufactures.
STEP TWO/ Basic troubleshooting continued....Testing the adaptor
1. Go to Windows desktop
2. Select Start then Run
3. In the text box type: cmd (WIN98/SE type command)
A DOS window will open.
4. At the prompt type: ping 127.0.0.1 (reserved IP address for all adaptors)
5. Check the line that reads "packets sent = 4, Received = 4, Lost = 0
A. Zero is good, the adaptor is working. Again check the connection
configuration,and the adaptor configuration.
It may be a power issue especially with older or less expensive computers
or wireless cards.
* Check the antenna location, are you inside or outside, look for interference.
B. If it reads all 4 packets lost, the adaptor is not functioning.
* Check and update the drivers, Contact the respective manufactures.
* If it shows any number of packets lost (you are dropping packets)
it is an adaptor or signal strength issue (generally form the laptop side,
not being able to reach back) especially with older or less expensive
computers or wireless cards.
* Update the drivers
* Check antenna location, or distance from the signal
* Contact the respective manufactures.
Posted on Nov 13, 2008
I cant connect to the netgear router even the wifi was unsecured.
check your network adapter settings to make sure your set to automatically obtain ip address, if this doesnt work, try connecting with a cable and go into your router settings to see if there is an access control list for the wireless side
May 05, 2011 | NetGear DG834G Router
I use my net gear router wireless,but every now and then i loose the wireless conection,i try to log into the router but it takes me to web sites with the same numbers,why does it drop out and i carnt get...
I understand that your Netgear wireless connection drops every few minutes. This could be due to the RF channel conflict. Try changing the wireless channel to 1 on your router.
Thanks,
Shiva
Dec 18, 2010 | NetGear DG834G Router
Hiya could you tell me how i can put a password on my wireless conection (it is netgear and i use sky broadband,) so only people in my house can log onto my broadband
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Dec 10, 2009 | NetGear DG834G Router
Cant play online games
Here are few things that you can try:
1. update the firmware on the router/modem
2. Open ports on the router/modem for P2P
Jun 10, 2009 | NetGear DG834G Router
I canot conect wirelessly from my laptop to router
ohhh!!! ok, well then just go to your browser and type in "http://192.168.0.1" and if that doesnt work go here
http://www.routerlogin.com/CA_HiddenPage.htm
it should ask you for a username and password
user name should be " admin " and password should be " password" by default. if it was changed your gonna have to find out what the user names and stuff are, you should be able to find out what the key is from their, or change it.
Jan 12, 2009 | NetGear DG834G Router
Connecting another router
i would'nt recommend it, theres no need for two unless you have mote than 4 hardwired pc's and 8 wireless, especially if they are both modem/routers, you cannot use two, only one modem/router and one router
Sep 15, 2008 | NetGear DG834G Router
Connecting to a netgear DG834G with vista
so u r triying to login to ur netgear router>check with conn>connect the pc through the lan and login to the net gear and configured ur w/l part and dis the laptop restart and check
Oct 12, 2007 | NetGear DG834G 802.11G Wireless ADSL...
NetGear DG834G Router Logo
74 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
