Question about Epson Stylus Photo R1800 InkJet Printer
Can't find my software for printer utility to clean my printer
Heads the printer is not on my taskbar so I can mantain my printer therefore I do not know where to go to find it
    Scholar:
  • 121 Answers
Go to START.....SETTINGS........PRINTER AND FAXES......rite click the printer you want to work with select properties...
keep me posted if this didn't work...
Cheers!
Posted on Nov 13, 2008
How to take out an ink cartridge that won't work even if it says it's full in an epson nx115
If the printer recognises the cartridge as full but it is not working, am I right in assuming that the ink is not coming through? If so I would recommend doing a couple of head cleans from your printer/printer software before replacing it.
If this doesn't help...
1. Windows: Right-click the printer icon in the bottom right corner of your screen (the taskbar) and select Printer Settings. Click the Maintenance tab.
Macintosh: Open the Applications folder, open EPSON Printer Utility3, select your printer (if necessary), and click OK.
See image at bottom of solution.
2. Click the Ink Cartridge Replacement utility icon and follow the on-screen instructions to replace your ink cartridges as necessary.
Dec 06, 2012 | Epson Office Equipment & Supplies
My epson workforce 520 is acting like its printing but nothing is on the page. I have replaced the black ink cartridges and the color ink is fine. What do I need to do?
The print head is probably blocked. If cleaning does not help then download the SSC Utility from the net (its free). Installed the prog but access it by the taskbar by right clicking on the printer icon. Select the model of printer and use deep cleaning. if that does not cure it then a new head is required.
Jun 19, 2011 | Office Equipment & Supplies
Document has blue high lights but is printing in pink Why?
Try a nozell and head cleaning from the printer utilities its under printer properties /mantainance tab
Dec 13, 2010 | HP DeskJet 930c InkJet Printer
How to clean printer heads
You can try and clean the printer head by holding down the maintenance button on the printer control panel for three seconds.
If that doesn't work then make sure the red light is off. If it is blinking, check the cartridge to make sure there is nothing wrong with it. Otherwise, either right click the status monitor 3 icon in the windows taskbar and select clean head, or on a Mac use the print utility.
When the green light stops flashing run a nozzle check.
If the nozzle check gives you 4 clean boxes your good, if they are grainy or lined rerun the cleaning. You may have to run this several times and the cleaning uses a lot of ink, so be prepared to replace the ink when it is all over.
Dec 09, 2009 | Epson C64 InkJet Printer
How do I clean the printer heads on epson c 60 printer
Dec 07, 2009 | Epson Stylus C60 InkJet Printer
Won't reconize new ink cartridge rx680 printer
hi friend,
Run the Head Cleaning utility to clear any clogged ink nozzles. To run the Head Cleaning Utility, follow the instructions below.
For Windows users:
1) Make sure that your printer is ON and the error light is off.
2) Access the printer software.
3) Click the Utility tab, then click the Head Cleaning button.
4) Follow the on-screen instructions
5) When the power light stops flashing, click Print nozzle check pattern in the Head Cleaning dialog box to confirm that the head is clean and to reset the cleaning cycle
If you find that any segments are missing from the nozzle check pattern, you may need to repeat the head cleaning and print the pattern again.
Or u could consult the user manual
u should let the ink settle for 12-24 hrs???
hope this helps u
please rate me..........................
thank u for using fixya
regards
sivaranjini
Nov 25, 2009 | Epson Stylus RX680 Color All-in-One InkJet...
Prints look washed out .Plus cartridges show empty even though they have just been filled. Noel
If using generic cartridges, try using original manufacturer's.
If utility software installed, try running the head/nozzle/check/cleaning/realigning functions.
(look for an icon in taskbar or in directories installed by your printer software)
Jul 03, 2009 | Canon PIXMA MP470 All-in-One Printer
I have an HP 6122 Printer that has problems printing in black. There are streaks and gaps in the print. I went to the self-help and they state to run a program from the Tool Box. I do not have this...
The original CD for this printer includes maintenance and utilities programs. If you do not have the original CD, you should be able to access the HP6122 maintenance and utilities programs online at the HP service website http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=83028&prodTypeId=18972&prodSeriesId=88749&swLang=8&taskId=135&swEnvOID=228
Select the full-feature version of the driver package. This kind of software generally is available free of charge from HP, but might require a small fee if you need the CD itself.
Within the HP6122 printer utilities are head-aligment and head-cleaning routines. One or both may be required to solve -- most likely head cleaning is required. Might require more than one cleaning event. Once clean, you can also print a test graphic from the printer utilities that does a good job of testing all colors and black.
Jan 21, 2009 | HP DeskJet 6122 InkJet Printer
Epson 1290 Head Cleaning
Just download the software from Epson's site. I don't think there's anyway to run the utility from the buttons, I'm afraid.
Sep 02, 2008 | Epson Stylus Photo 1290 InkJet Printer
Epson Stylus Photo R1800 InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
