Question about Sony VAIO VGN-FJ170/B Notebook
Can not log into the system
Hi, when i turned on my laptop, it showed the welcome screen, and I have to type my password, after that instead of loading my personal setting or the main screen, it just showed loading my personal setting for like 1 second and it changed to saving my setting and logging off return to the welcome screen. I tried to type my password again, it still repeat that problem. Please help me with this. I can not use my laptop now. Thank you very much.
Locked administrator
For Windows Password:
1. Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box.
2. Type \Administrator\ (without quotes) in Username and leave Password field blank.
3. Now press Enter and you should be able to log in Windows.
Now you should be able to reset your account password from \Control Panel - User Accounts\.
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Log in screen.
Oct 10, 2013 | HP Compaq nx7300 Notebook
My labtop is locked
Unlock Windows password with Windows built-in Administrator account.
Here's how this admin unlocks forgotten Windows password:
Start your computer and wait for the Windows Login or Welcome Screen. Once it shows, press Ctrl+Alt+Delete twice and then type Administrator in the pop-up username box, but leave the password column blank. Next you could successfully log onto system. The following steps for resetting the forgotten password are quite easy. You can make it from "Start->Control Panel->Users Accounts".
Besides, Windows Password Reset is a great choice .
Jun 20, 2012 | Acer Aspire One Netbook 8.9" Notebook
The compuyter made a very funny running sound and then the screen with black. I can not start up the laptop, but 2 blue power buttons are on.
You got 2 options:
1-Start the pc and when you see Windows Welcome screen / Login screen, press ctrl>+alt>+del> keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows. Now you can reset your account password from "Control Panel -> User Accounts". Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2-Some computer systems have a setting in the BIOS Setup to disable the password. The BIOS Setup is accessed with the F1, F2 or DEL key during boot up. If you have forgotten your password, most systems have a jumper on the motherboard that can be pulled off to clear the password. If there is no jumper available, you can also remove the battery for 5 minutes to clear CMOS.
If you need more help post back!
Thumbs and testimonial are welcome!
Aug 05, 2011 | Dell Vostro 1500 Notebook
Hello, I have a Dell Studio 1537. I can turn it on but I can't get the user password to open into Windowsw. Help????
You got 2 options:
1-Start the pc and when you see Windows Welcome screen / Login screen, press <ctrl>+<alt>+<del> keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
For assistance with this process we recommend that you contact Technical Support for more interactive support or you may choose to go to a Authorized Service Center. There may be a consulting charge for this service.
Aug 05, 2011 | Dell Studio 1537 Laptop
I have a studio 1537 Dell laptop and I can not open nor can I change the password to get to Windows. Can you help
You got 2 options: 1-Start the pc and when you see Windows Welcome screen / Login screen, press ctrl>+alt>+del> keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows. Now you can reset your account password from "Control Panel -> User Accounts". Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen. 2-Some computer systems have a setting in the BIOS Setup to disable the password. The BIOS Setup is accessed with the F1, F2 or DEL key during boot up. If you have forgotten your password, most systems have a jumper on the motherboard that can be pulled off to clear the password. If there is no jumper available, you can also remove the battery for 5 minutes to clear CMOS.
Aug 04, 2011 | Dell Studio 1537 Laptop
Forgot password
1. Start up into safe mode (press F8 at startup) 2. log in as 'administrator' 3. go into control panels, users, and clear the password on the account that you have a problem. 4. restart.
Aug 18, 2010 | Dell Studio 1535 Notebook
Ex boyfriend reset login password. cannot get
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt and hit the del key twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Please post back if need anymore advice or this does not work.
Good luck.
Feb 04, 2010 | Compaq Presario M2000 Notebook
I bought a toshiba laptop that is lock from the previous owner
If it's at bootup:
You need to temporarily remote the CMOS battery from the motherboard to reset the bootup password.
If it's at login:
http://www.howtogeek.com/howto/windows-vista/change-your-forgotten-windows-password-with-the-linux-system-rescue-cd/
Dec 03, 2009 | Toshiba Satellite A205-S4617 Notebook
Start Menu Picture Disappeared Suddenly
Turn the Welcome screen on or off It sounds as if you accidentally turned off the welcome screen. Here's how to turn that function on and off:
To turn the Welcome screen on or off
You must have a computer administrator account on a computer that is a member of a workgroup or is a stand-alone computer to turn on or turn off the Use the Welcome screen feature. Logging on at the Welcome screen is not available on computers that are members of a network domain.
  1. Open shortcutcold.gifUser Accounts in Control Panel.
  2. Click Change the way users log on or off.
  3. Do one of the following:
    • To specify that users log on to the computer using the Welcome screen, select the Use the Welcome screen check box. A user logs on to the computer by clicking his or her user account name on the Welcome screen. If a password is assigned to the account, the user is prompted to type it.
    • To specify that users log on to the computer without using the Welcome screen, clear the Use the Welcome screen check box. The Welcome screen will no longer appear when you start the computer. To log on to the computer, type your user name (and password, if you have one) in the standard Log On to Windows dialog box.
note.gif Notes
  • To open User Accounts, click Start, click Control Panel, and then click User Accounts.
  • Fast User Switching is available only when the Welcome screen is turned on. For more information, click Related Topics.
I hope this helps. Please let me know if you require further assistance.
Feb 26, 2009 | Microsoft Windows XP Professional SP2
Sony VAIO VGN-FJ170/B Notebook Logo
80 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
