Question about Chevrolet 1972 Blue & White Chevy Pickup Truck Diecast Model Truck
I need to change a fuel pump in my 1972 chevy longhorn 350
I just need to know how to go about doing that if possible???
  • 130 Answers
Disconnect all linesfrom fuel pump remember where they came from remove the two bolts (some have 3)remove pump catch rod that comes out clean gasket surface glue new gasket to new pump cover rod with heavy grease insert rod if you used enough grease it will stay on its own install pump being careful to keep mounting surfaces clean reinstall bolts put lines back on crank over about 4 times no longer than 15 seconds if engine doesn't prime prime carb start done check for leaks
Posted on Feb 10, 2009
97 chevy 2500 truck; 350 vortex; trouble starting
Seem like your fuel pump can't keep up the pressure when engine is started. If you have a pressure regulator that isn't into the pump assembly i would change it if not then your going to need a new fuel pump assembly.
Dec 31, 2012 | 1995-1997 Chevy 1500 Truck Ignition...
I'm getting fuel though the small line that goes to my flame arrester from a mechanical fuel pump on a 350 Chevy
If the line is coming from the fuel pump and is not supposed to be pushing fuel into the flame arrester, the fuel pump has failed.
What I don't understand is why there is a small line going to the flame arrester in the first place. Its purpose is to dissipate heat to prevent exhaust gases from igniting any other gases that might accumulate.
Sep 25, 2012 | Aeromotive Fuel Pump - Billet Mechanical -...
My 1992 chevy g20 van surges and i'm not sure exactly why. I changed the pcv valve, fuel filter, spark plugs, and air filter. What are some possibilities
My first thought would be a vacuum leak in one of the hoses. Rubber hoses get brittle with age and even a small crack in a hose may cause surging. Happened to me in a Lumina.
Apr 26, 2012 | 1997 Chevrolet Astro
Hello i have a 1972 honda 350 four and im trying to remove the carbs what parts do i need to remove proir to removing the carbs
fuel tank
side covers
loosen air box mount bolts
throttle cables
manifold clamps
spray some lube to help
Apr 08, 2010 | 1972 Honda CB 350 F0
My 1993 Chevy 350 fuel injected pickup just quit
Check to see if there is any power getting to the fuel pump, if there is 12 volts going to the fuel pump then replace the pump, if there is no voltage present, the problem could be the fuel pump relay, a fuse, or a break in the wiring.
Jan 23, 2010 | 1993 Chevrolet C/K 3500
O2 sensor problem
I have a 97 gmc sierra .This truck is the same as the chevy ok.Its a 350 5.7 liter 4x4 Z71.I took it to auto zone which was my first mistake.They put it the scanner and said bad O2 sensor.Ok so which one is it i said.They dont know.Well there four (4) O2 sensors in this truck i hope you know that.I had to replace all four of them before i had to take it to a real shop.It seems the fuel pump i replaced a week earlier with an auto zone fuel pump was bad.Ive changed my feul pump 4 times now and have 235000 miles on still running.You need to get your fuel pressure checked.It should be 65 psi to start it and 55 psi to run it.If the pressures are good it could be a different O2 sensor or maybe the mass air flow senor.My last option would be the fuel pressure regulator because it seems to be a waste of time and money.I would get that fuel pressue checked first.Good luck.
Oct 30, 2008 | 1997 Chevrolet K1500
FUEL PUMP
Mechanical fuel pump? or electric ?
Chevrolet 1972 Blue & White Chevy Pickup Truck Diecast Model Truck Logo
990 people viewed this question
Top Chevrolet Toys Experts
Electric Dime
Electric Dime
Maxumized
jogp98
Are you a Chevrolet Toy Expert? Answer questions, earn points and help others
