Question about Maytag MMC5000 Microwave Oven
Sharp Microwave R-520L stopped working
Microwave stopped in middle of rice program. Timer works and light comes on for operation, but no fan, no turntable motion, and no heating. This happened suddenly with no previous problems.
  • Anonymous Dec 11, 2008
    I was cooking potatoes and the last 2 minutes it stop working. The timer and light was still working, but the fan and turntable stop working. I had no previous problems with my microwave.
  • castleberrys Dec 14, 2008
    Had same problem with Sharp R-520L. Microwave suddenly stopped working with no previous problems. Lights and timer working, but no turn table motion or fan/heating.
My parents had the same problem. It turned out that a switch went bad. When you take the case off, there are 3 switches where the door latches. The bottom switch went bad. It is an Omron D3V-16G-3C25 switch.
Posted on Nov 15, 2009
My sharp 1214 won't heat anything. power is good - timer and clock are fine. stopped working in the middle of heating something. we use often. carousel is not rotating anymore either.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Aug 10, 2010 | Sharp R-1214 Microwave Oven
SHARP Microwave- doesn't rotate, fan does not come on, oven light comes on, timer works
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Dec 07, 2009 | Sharp R-520KS Microwave Oven
Had problem with Sharp R-520L. Microwave suddenly
One of the door switches is the problem. Open the casing, and you should find the schematic diagram. Find the switches, and test if you can. If you cannot - replace all of them except the monitor switch.
Nov 17, 2009 | Maytag MMC5000 Microwave Oven
Timer works, but no turntable no fan and no heat. Light comes on when I hit start but that is all.
Chances are that the magnetron has stopped working. Unless it is under the guarantee or is a very expensive micro it really wont be worth fixing.
Oct 03, 2009 | Sharp R-520LK Microwave Oven
My Sharp Model R-520LW microwave will not cook. The timer, light, clock all work. The turntable, fan and microwave do not.
Hi! the problem you have mentioned indicates that your microwave magnetron is not working. check for busted fuses.
Sep 15, 2009 | Sharp R-520LW Microwave Oven
Sharp Microwave Lights Up, But Won't Rotate or Cook
Hi. I would suggest checking out the door switches. There are usually 3. If one of those has failed then the microwave won't operate because of safety reasons. Best to replace all three. If the display on the unit is still fully operational I'd say go for the repair.
Mar 18, 2009 | Sharp Microwave Ovens
SHARP MICROWAVE R9H20 STOCKED FOR LONG
if the problem is tempermental then is sounde like you may have a failing interlock switch. this is a series of switches that are activated then the door closes. there are normally 3 and you would be looking for/ replacing the middle the Primary interlock...
Hope that helps
Jan 11, 2009 | Sharp R-510HW Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
No Heat
This is probably due to a bad door switch, most likely the top one. The microwave got hot because the cooling fan was not running. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://www3.sears.com/
Apr 26, 2007 | Sharp R-1492 Microwave Oven
Maytag MMC5000 Microwave Oven Logo
896 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
