Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Defrost timer location for a amana model SR25F1L
I can not find the dfrost timer on this appliance
    President:
  • Amana Master
  • 2,651 Answers
Part number (d7004112), its located under unit, remove back panel should be mounted to a metal plate along side compressor
Posted on Nov 16, 2008
DT11 timer turns on aplliance but will not shut it off.
1) DT11 is older timer, and may be may be copied by foreign manufacturers. Timer has 1 year limited warranty.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#DT300
2) Don't buy timers from ebay or local drug store.
Don't buy used timers.
3) DT11 timer may not be rated for appliances. Usually this type timer has rating for 600-1200 watt incandescent bulb, and will overheat and fail quickly with higher load, such as appliance load.
Buy Intermatic appliance timer for appliances:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#appliance
4) Always reset timer before programming.
5) Review programming for conflicts and overlaps that would cause timer not to function as expected.
Dec 16, 2012 | Hardware & Accessories
When i start my vehicle when it's cold and turn on the dfrost it does not clear the windshield
I would suspect you have the controls set for defrost, if no hot air is blowing from vents, you could have a blend door that is not functioning, switch from defrost to panel to floor and listen to hear blend door moving, if you hear the door moving...do you have hot or warm air on any other setting? if not check the antifreeze level under the hood, some vehicles can be very finicky even if a little low on antifreeze. DW Mylin
Nov 24, 2012 | 2005 Pontiac Aztek
I bought timer model #402A. It says 1250 watts tungsten rated. Here is my question: I have a demhumifier that draws 1800 watts-can I use the timer and what does 1250watts tungsten mean? Thank you.
1250 watt tungsten: Tungsten is the tungsten filament in light bulb.
So 402A timer is rated for light bulb only and not dehumidifier motor load.
1800 watt dehumidifier will burn 402A timer, and could start a fire.
I suggest Intermatic heavy-duty appliance timer HB113C:
http://waterheatertimer.org/pdf/070-appliance-timers.pdf
http://www.smarthome.com/25071/Intermatic-HB113C-120V-20A-Heavy-Duty-Mechanical-Appliance-Timer/p.aspx
Jun 24, 2011 | Tork 402A 24 Hr Mechanical PlugIn Timer ...
Freezer not defrosting
try to rotate manually defrost timer possible stock up or the thermo disc defective replace it or the dfrost heater busted need technician for replacing this parts conduct observation after.
Mar 04, 2011 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Coil frozen up on Kenmore mod# 596.72282200. Where is the defrost timer?
this model dosent have a rotart defrost timer its an adaptive dfrost control board located in the temperature contol housing located on the ceiling of the refrigerator about the size of a wallet incased in white plastic case part number #12566102 adc control-timer
Jan 27, 2011 | Kenmore Refrigerators
My refridgerator wont get cold and i keep hearing a clicking noise as if the dfrost timer or some type of timer is not switching to cool mode
not a expert just trying to help,, if you are hearing a clicking noise then timer stuck,,most models timer is in the back(may have to take panel off) to see it,it will have a slot in it try turning it and see what happens,, if no good need to replace it,, hope this help you
Oct 07, 2009 | Refrigerators
Water on base of the refigerator
find the drain hole and unblock it faily easy on a fridge on the side by side more difficult need to unplug defrost it remuve the bottom panel inside in the freezeer side of the appliance to access the drain tray do nort attemt to remuve the panel while iced up dfrost is must or coud cause serious damage
Nov 13, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Fridge leaks
your drain is clogged,you need to get to the drain and use a hanger or shop vac to **** the clog out,let me know-mike
Jul 08, 2008 | Refrigerators
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
330 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
