Question about 2wire 802.11b+ Wireless Ethernet Client Gaming Adapter1000-100046-000 (1000100046000)
It just wont work
Ive installed it and everything, it says its getting a signal but when i plug it into my xbox the xbox says there is no connection i have quest wireless internet
    President:
  • 2,961 Answers
Check on the X Box website to see if your router and firmware is supported.
Posted on Nov 21, 2006
I have just got in broadband but my xbox aint picking up my wireless signal upstairs,ive got the wireless adapter for the xbox,its picking up a few neighbours network connections,surely my xbox should be...
It is possible that the Xbox will be unable to pick up the wireless signal being transmitted by your gateway because the signal is too weak.
The connection speed of your internet has nothing to do with the strength of the signal. The best way to test this would be to try to connect to your wireless internet on a laptop while sitting near the xbox. If you cannot, you will know that the signal isn't powerful enough to reach that location.
There are three common options to amplifying your signal if necessary.
1) Purchase a High-gain antenna for your wireless gateway
2) Purchase a wireless repeater
3) Purchase a new router/gateway with a longer range capability. A "Wireless N" enabled router would be optimal for this application.
Apr 12, 2011 | Microsoft Xbox 360 Console
One of my xbox controllers wont connect to the xbox the controller turns on but it wont connect ive tried everything thats been posted but nothings worked. i have two controllers and the other one works...
You've attempted to sync it right? You click and hold the sync button on both the xbox and controller until each one is spinning around. Then it should grab and connect. hilldav9.jpg
Mar 02, 2011 | Microsoft Xbox 360 Controller
Our internet is working fine with everything except my xbox. I either cant connect to xbox live or i cant stay connected. ive tried everything i can think of to fix it.
First of all, the wireless thing for the Xbox is a waste of money, when i had mine, it would always lose connectivity. Anyway make sure the device is not next to anything that gives off frequencies as that may cause the connectivity issue (microwaves etc....)
Dec 29, 2010 | Microsoft Wireless Network Adapter Xbox...
Backwards Compatability
Do you have a harddrive for your xbox? if not, you cannot get it to work
Mar 06, 2010 | Microsoft Xbox 360 Console
Xbox live on netopia router
Okay, to connect to Xbox Live using Wireless Internet you will need this:
One Xbox Wireless connection unit, There are two types, the black and white versions. The black one is able to pick up the most diverse signals and has a higher potential for speed so I recommend that one.
You will also need, of course, a high speed internet source (modem) and a wireless router connected to the modem. When looking for wireless routers look for ones with marks claiming to be compatible with Xbox Live or a Windows OS. Those have been tested to work with Xbox.
Before trying to set up your Xbox Live, make sure your Router is set up with your computer, and set to be used as a wireless router. That's another tip all together but just follow your installation CD.
Okay so here we go!
First, Connect the wireless networking adapter to the back of your Xbox.
If you have a network cable plugged into your xbox, unplug it. Check to make sure the adapter's light is on.
Here's what the light's mean:
On the gray adapter:
No light: It's not getting enough power( try plugging it another USB slot)
Green light: It is connected to a wireless router, gateway or wireless access point.
Red light: It is not connected, and is ready for configuration.
Flashing red: There is a malfunction. (try again, if the problem persists return it for a replacement)
On the black adapter:
Green light: It is connected to a wireless router2_bing.gif, gateway or wireless access point.
Flashing green: The adapter is attempting to connect to a wireless router, gateway, or access point.
Now the CONFIGURATION, the reason most of you are reading this:
Turn your Xbox on and go to "My Xbox"
Go to "System Settings"
Go to "Network Settings"
Go to "Configure Network"
On the basic settings tab select "Wireless mode"
Select "Scan for Networks"
Select your Wireless source.
NOTE: If your Network isn't listed you will have to manually enter it.
To do this select "Specify unlisted network"
You will need to enter your SSID
Then choose which security you used to set it up on your Computer (ie: WPA, WEP...) Then enter your security code. If there is no code then select "no security"
Your adapter should have a green light now.
Now go back to "Network Settings" and select "Test Xbox Live2_bing.gif Connection"
If it works your good to go!
If not read visit: http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xlcsv1
Hope this tip helps :) Tell your friends and ratings are nice. Just kidding, I just hope I helped.
Jan 10, 2010 | Netopia 2247NWG-VGx Wireless Router...
I have a siemens gigaset se587 wireless router and a xbox360 network adapter it does not connect up to my network where am i going wrong I have connected it up using the ethernet cable and it works fine...
sorry to bother but i cant get xbox live to work with the ethernet cable, where did u plug the ethernet cable into? ive tried different places and none seem to be working
Oct 17, 2009 | Microsoft Wireless Network Adapter Xbox...
My xbox 360 wont recieve a signal from my computer.
if your laptop get a signal than buy a eithernet cable and coonect your xbox 2 the laptop and go 2 your network settings and check the box that say share connection than wait a few mins. and try to connect to xboxlive this should work because thats how i get on xboxlive at my house.
dalvon78@yahoo.com
Jan 05, 2009 | Microsoft Xbox 360 Console
Connecting to xbox live
Try this Dns Address
4.2.2.1
4.2.2.2
Oct 02, 2008 | Microsoft Xbox 360 Console
Xbox 260 wont turn on
Hello.
It sounds like one or more of the GPU connections has a bad connection. This means it is very close to dying from the 3 lights of death. Your unit needs to be sreviced by a professional or Microsoft.
Aug 04, 2008 | Microsoft Xbox 360 Console
Im having a problem w/my wii
Is it not getting an IP from the Router? Try resetting the router and see what that does...
Mar 25, 2008 | NetGear WGR614 Wireless Router
Computers & Internet Logo
118 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
